4.0 high output - JeepForum.com
post #1 of 12 Old 02-21-2007, 04:21 PM Thread Starter
karbu
4.0 high output
I used to own a 1993 Cherokee that had a 4.0 high output engine. It seemed to have alot more power than the 4.0 in my 97 Wrangler. Does anyone know what they did different in the high output 4.0?
Steve Draper
'97 Wrangler
karbu is offline
post #2 of 12 Old 02-21-2007, 04:23 PM
Crashnburn80
Crashnburn80's Avatar
The 97 4.0 is also considered a 'high output'.
Crashnburn80 is offline
post #3 of 12 Old 02-21-2007, 04:24 PM
Rule303
Basically the same engine. Mine has the 2.5L "low output" version.
Rule303 is offline
post #4 of 12 Old 02-21-2007, 04:48 PM
1BadJeepX06
Gears could be the "more power" you were feeling.. Your '97 may have crappy gears.. Cause the "high output" was just to make you feel better about yourself...
DH
Coming soon: 2000 Jeep Sport (modifications soon after) :-)
1BadJeepX06 is offline
post #5 of 12 Old 02-21-2007, 04:57 PM
jm708
2014 JK Wrangler
I had a 93 HO wrangler and it had a lot more balls. I think emissions and the gearing play a large roll in how well the jeep preforms. Just my opinion though.
jm708 is offline
post #6 of 12 Old 02-21-2007, 05:00 PM
Crashnburn80
This is probably the case, especially if you have 3.07s
post #7 of 12 Old 02-21-2007, 05:03 PM
Hunter9
Hunter9's Avatar
Anyone know the stats of both engines (HP and Torque)?
My 93 YJ had 3.55 gears (IIRC) and seemed to have good power, I would almost say it was better that my TJ. Both were 4.0l Autos YJ had 3.55 and TJ is 4.10.
But I am also nearly 10 years removed from driving the old yj so my memory could be off.
97 Sport 4.0l Auto D30/D35
RE 3.5 SF, 1" BL, 1" MML, 285/75/16 (33") MTRs, 16x8 MT Classic Locks, 4.10 gears, Lockrite Front, Warn Front and Rear Bumper w/ Tire Carrier, Warn Diff Skids, Rock-it Man Rockers, Jeeperman Front Hoop, M8000, A to Z winch mount, Hella 500s, H4 Conversion
Former 3.07 Gears Club Member #1
Hunter9 is offline
post #8 of 12 Old 02-21-2007, 05:07 PM
Rasta_Coty
here are the stock specs of the cherokee
4.0L I6 MPI "Power Tech HO" (High Output) - 190 hp @ 4750 rpm, 220 ft lb @ 4,000 rpm - used in 91-95 and updated in 96-01 to 225 ft lb torque @ 3000 rpm (00-01 models use a distributorless ignition system)
1996 Jeep Cherokee || 4.5 in. RC || 4.0 liter I-6 high output || 33 x 12.50 BFG All Terrain T/A KO, 16x8 American Racing rims || Rusty's Air Tube w/ K&N 9in. Cone Filter || Throttle Body Spacer || Bored TB || Flowmaster Regular 40 || 99+ Intake Manifold Swap || Auto Meter (Trans Temp. | Water Temp. | Volt) Gauges || Pioneer 5800 HU || Hifonics 1606 Amp || (2) Kicker Comp Cvr 15's || 1/0ga. wiring || Vented box || Yellow Top || Tranny Cooler || Bushwackers ||
Updated 2/4/07
Rasta_Coty is offline
post #9 of 12 Old 02-21-2007, 05:18 PM
Crashnburn80
Your TJ with 4.10s is on 33s, which would make a difference.
According to Autotrader tech specs for Wrangler:
93 4.0L: 180 hp @ 4750 rpm, 220 ft-lbs @ 4000 rpm
97 4.0L: 181 hp @ 4600 rpm, 222 ft-lbs @ 2800 rpm
Also TJ weighs about 150lbs more than a YJ yet gets 18mpg hwy, vs YJs 16mpg.
post #10 of 12 Old 02-21-2007, 05:26 PM
SecondTJ
SecondTJ's Avatar
The 2000-06 4.0L Wranglers are
190 hp and 235 lb-ft
Increase was due to a re-designed cylinder heard, re-designed intake manifold, re-designed exhaust manifold and the distributor-less ignition
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #11 of 12 Old 02-21-2007, 06:20 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
also look into the more emmissions in the newer ones which takes some power
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #12 of 12 Old 02-21-2007, 07:14 PM
Rule303
Any noticable difference between the two probably had more to do with the gearing and curb weight than the engine itself. They are basically the same engine with some minor differences.
Rule303 is offline
4.0L high output vs 4.0L stargazer3141 YJ Wrangler Technical Forum 4 02-09-2010 01:56 AM
how do you know if engine is 2.5 high output or low output? yjwrangler YJ Wrangler Technical Forum 16 08-27-2009 01:56 PM
high output 4.0L sportman TJ Wrangler Technical Forum 13 12-19-2008 03:50 PM
high output or low output j85rule YJ Wrangler Technical Forum 9 09-21-2006 09:56 PM
'93 YJ again..."high output?" SSJeep YJ Wrangler Technical Forum 4 03-28-2001 04:17 PM
