#1 | |
4.0 Hemi swap
I have a 98 4.0 sport and I just bought a grand cherokee that was totaled in a rear ender. I'm planning on putting the Hemi into my sport. What key things do I need to pay attention to and does anyone have any hints or suggestions to make this job a little easier? Thanks
#2 |
Running Secretly Amok!
A search maybe? http://www.jeepforum.com/forum/search.php?searchid=4860477
#3 |
Me and you are going to be close friends by the time we're done.
I just bought a 5.7 hemi, w5-45 rfe, t-case, harness and computer out of a wrecked ram. I started here http://www.fourwheeler.com/projectbuild/129_0507_1997_jeep_wrangler_tj_57l_hemi_v8_swap/index.html found this http://www.hotwireauto.com/?page=sales-tj I have to send my fuse block harness out of my tj and the computer from the hemi. I also am buying all of the conversion items they have (looks like one stop shopping to me) You'll need a instrument cluster out of an 01 tj or newer. I lucked up and found one at a local you-pull-it place. I was going to build a stroker but it would have cost about the same and been a larger pain in the posterior, besides hemi's sound cooler.
[quote][color=black][FONT="Franklin Gothic Medium"][I]"What good fortune for governments that the people do not think." Former Tyrannical German Furher [/I][/FONT][/color][/quote] [CENTER][COLOR="White"][FONT="Franklin Gothic Medium"][B]White Jeep Club Member #999[/B][/FONT][/COLOR][/CENTER] [CENTER][COLOR="Red"][B][FONT="Franklin Gothic Medium"]FireMedic[/FONT][/B][/COLOR][/CENTER] [CENTER][I]Si vis pacem para bellum[/I][/CENTER] [CENTER]slinky + escalator = everlasting fun[/CENTER] |
#4 | |
For other looking for this conversion, here's a bit of info I just got today from Advance Adapters, who are currently working on a TJ Hemi swap conversion kit:
Formally JeepinTJ99 ... Go Anywhere: 2012 "Crush" Clearcoat JK Rubicon, loaded to the hilt || Thread Carve Time: 2009 "Racing Red" Buell 1125CR — 150 RWHP Will be missed: 1999 "Deep Amethyst" Pearlcoat TJ +3" on 33's |
#5 | |
1998 TJ, 4.0L Auto | 3" Nth Springs | JKS QDs | D30 Detroit True Trac | Nth Tummy Tucker | 35x12.50r15 Goodyear MT/R | JB Super Short SYE| 1.25" BL | Novak Tcase Shifter
Rolled Red Jeep Club Member #7 |
#6 | |
Web Wheelin'
You didn't need it, or, your wallet didn't need it??
98 Jeep ZJ Laredo 4.0L, Auto, Stock for now. Totaled :-( Parting Out 96 Jeep XJ Sport, parted out and scrapped Tummy Tuck without a body lift. Finished!! |
#7 |
I just fired my Hemi conversion for the first time Tonight! I used Squire for most parts, Alumarad for the Radiator only $500 Built to hemi specs w/trans cooler- they build them for the big companys that just mark them up to $700 and Moperunlimited.com for the factory parts very good prices! This is the fourth Hemi I have done but this is the first of my own!
#8 |
ok help us first timers out Do we (I) need to spend all the money on the terra stuff? Do I need to use hotwireauto.com? I have a budget (and marriage) to watch. I would like to do this right but as budget minded as possible.
#9 |
lol Probably both. Already been plotting an LJ project for next winter since my SWB is getting further and further from streetable
#10 |
I LOVE having a 5.7 HEMI in my Rubicon.......... It is awesome..... BUT, i just blew out my rear end a few days ago. It couldnt take the power.
The swap is not that bad. Tony at Hotwire is a god at Hemi swaps. He knows all that you can every need to know about this swap and has made the wiring harness for about 90% of all Hemi swaps to date. If you do the math, you can get ALL the parts you need for around $7,000. NOT INCLUDING the hoses, belts, fluids, scrap metal, and custom things like exhaust, and AC lines. If you are competent mechanically, you can do this swap yourself for $9-10,000. If you have a shop do it, you can expect, I would say, about $12-15,000. Either way you go, when you are done.... you WILL LOVE IT. Hey, N8RB8R..... what kind of MPG are the 4 swaps you did getting? I am trying to see the average, because I really dont think mine is what it should be. |
#11 | |
I Peter 3:15 ... are you ready? meverhart@vecoplanllc.com |
#12 |
I would plan on spending the money for the wiring harness mods and computer programming. You don't want to try and chase wiring problems and the harness that Hotwire sells is first class and simple! I had to buy a fuel tank and pump out of a wrecked 05 TJ for my 97 conversion.
#13 |
5.7 swap and down stream damage
Was the 5.7 engine swap the reason for the rear axle failure or was it more foot related?
More importantly are you rebuilding the D44 or replacing with a D60, D70 or 14bolt? Reason for the questions, I have driven a 325i with a late Corvette 5.7 / 6spd on a Solo track with no damage to the original qualif diff or gear set. (And I beat on it.) Hondo78 |
#14 | |
JEEP FREAK
A Hemi motor with a 4:1 reduction transfer case, 4.56 axle gearing, and 36" tall tires is much harder on a rear axle than a Bimmer with a Vette motor.
98 TJ |
#15 |
Yup... sure is.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
