4.0 exhaust downpipe 'cans' - JeepForum.com
post #1 of 5 Old 12-30-2011, 06:02 PM Thread Starter
RockScar
I'm trying to finish up an engine swap ('00 TJ 4.0) into my CJ, and exhaust is up next. My motor has the manifolds, going down to twin openings. I've seen the stock TJ setup, and the downpipe has two 'cans' on it. What are these? Cats?
In a nutshell, I need to determine whether or not I need the stock downpipe with the 'cans'.
Thanks in advance for the help!!
Live free or die. Death is not the worst of evils.
RockScar is offline
post #2 of 5 Old 12-30-2011, 06:20 PM
TJJP77
TJJP77's Avatar
The cans are indeed small catalysts called "pre-cats"....
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #3 of 5 Old 12-30-2011, 06:52 PM Thread Starter
RockScar
Do you know if they're needed? Needed, as in regardless of emissions. I just need it to run properly.
RockScar is offline
post #4 of 5 Old 12-30-2011, 07:23 PM
tbburg
They're not necessary for proper engine operation, but you won't find a down pipe that will bolt to the manifolds without the pre-cats.
Are you trying to make the TJ computer run in a CJ, or just swapping the motor over? The TJ is OBD-II, which makes a difference. While it will run without the catalytic converter, the computer will throw a code if it "sees" a non-functioning(or missing) catalytic converter. It has "upstream" and "downstream" O-2 sensors, they up-stream sensors to check A/F ration by exhaust gas analysis, and the down-stream set to confirm the catalytic converter is functioning properly. Remove the upstream sensors, the engine runs open-loop(crappy) remove the cat or downstream sensors, and you get a check engine light.
In addition, the OBD-II system has a gas tank evap. system monitor(Ever have a check engine light because the gas cap was left off?) without all that crap, you get another code and a check engine light also.
"Never attribute to malice that which can be adequately explained by stupidity, but don't rule out malice."
My other car is also a Jeep,.. and so is the other one,.. and that one too. How many do you own before it's "a herd" ?
tbburg is offline
post #5 of 5 Old 12-30-2011, 10:39 PM
Andy-WhiteTJ
You CAN get the down pipe without the cats for the 2000 exhaust. Napa and Rockauto has them. It's made by Walker.
http://www.napaonline.com/Catalog/Ca...(P_RecType%3aA)
However, as stated above, it will most likely throw a code unless you've done some modifications to the wiring and computer.
1998 White TJ with a whole lotta stuff...
Just another member of:
(a 501(c)(7) Not-for-Profit Corporation)
Member:
(Northeast Off-road Vehicle Alliance)
Andy-WhiteTJ is offline
4.0 swap , cj , downpipe , exhaust , tj
exhaust downpipe help JSBlu974X4 TJ Wrangler Technical Forum 4 11-16-2008 01:54 AM
Exhaust leak at downpipe? Need a donut? cmorganf64 TJ Wrangler Technical Forum 1 03-11-2008 07:37 AM
Exhaust downpipe rattle HuntingForDeer TJ Wrangler Technical Forum 3 08-04-2006 10:15 AM
Exhaust downpipe options wwiihistory YJ Wrangler Technical Forum 2 05-29-2006 08:21 PM
Exhaust downpipe from the manifold CanukYJ YJ Wrangler Technical Forum 26 11-13-2004 10:04 AM
