4.0 Engine sputtering/losing power - JeepForum.com
post #1 of 16 Old 12-23-2011, 11:10 PM Thread Starter
beserkur
hello everyone,
This has happened twice so far,today and yesterday,
Leave for work in the morning,little traffic so no idling.Leave work,stuck in traffic for at least 15 mins,then suddenly engine is pinging,shuddering,no power(500 to 1100 rpms max)Turned off engine,restarted it right away-everything's fine,drove home ok.
This morning,same as yesterday,left work,caught 20mins traffic(bumper to bumper)was almost home (was driving at 100km)same symptoms,again,pull off to the side,turn motor off,restarted,ran fine as if nothing happened.
So,the second time when I pulled off to the side,I tried a few things to see if I could diagnose this-I floored it to see if my rpms would go any higher,nope but the motor pings something fierce.Next i tried just letting off the gas completely to see if it would stall on it's own-nope,kept running rough but wouldn't stall-let it for at least 3 mins.
then I kept "goosing" it to see if I could get it to stall that way-no dice.
The first time it did it-I had fueled up that morning,at the same place I always do-but the station is not a banner type-just an independent.
I believe it's either bad gas or water in the gas.since it has never happened before it just reaffirms my belief.
Another interesting fact is that about 2 weeks ago my CEL has come on and stayed on ever since.I now believe that was an early indicator that the gas is poor quality or contaminated with water.
I'm gong to check more thoroughly tomorrow but I wanted to know if anyone has any ideas on this.
.[__]
OlllllllO
[]__[]
Jeep "Improvise,Overcome,Adapt"-Recon Motto
beserkur is offline
post #2 of 16 Old 12-23-2011, 11:54 PM
HarryJeepGuy
What code is it throwing?!? If the light has been on for 2 weeks I doubt it's bad gas.
I'm assuming you don't know the key trick to get the CEL code. With the Jeep parked and off, turn the key from off to on 3 times fast without starting it, and leave it in the on position. It will display the code(s) where the odometer is.
HarryJeepGuy is offline
post #3 of 16 Old 12-24-2011, 09:14 AM
Cassafrass
I had basically the same problem with my 4.0. It happened twice within a few days. One time I pulled over, turned it off and it ran fine. The second time a few days later it happened, the CEL flashed, I pulled over, let it chill out (never turned it off) pulled back on the highway and it hasn't done it since. Mine was throwing a code for a cylinder misfire. Its been months since then. No CELs, no loss of power, nothing.
Cassafrass is offline
post #4 of 16 Old 12-24-2011, 11:14 AM
mightydog78
Spark plugs, o2 sensor, catalytic converter, dirty intake, TPS, IAC
2013 JKU Sahara
Charlotte, NC / Southport, NC
Mechanical Engineer
mightydog78 is offline
post #5 of 16 Old 12-24-2011, 02:05 PM
JPNinPA
May just be bad gas like you think. Being it does it only while idling, I'd clean the TB and IAC. Did you note any temp issue or battery voltage issues?
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #6 of 16 Old 12-26-2011, 02:13 PM Thread Starter
beserkur
Hi Harry,well I do know how to get the codes,and there are several,but it's all related to misfiring and insufficient voltage etc....
But I still maintain it's bad gas.The crank and cam sensors are new.
I also gotta let you know that I am a mechanic,so I have a very good knowledge of what is going on,just wanted some input from you guys to see if I'm right.
It seems these crank and cam sensors fail quite often(twice in my case)
I;m going to drain my tank and put some fresh gas from a good known source and try it out.I'll get back to you guys and let you know what happens.
Just for fun I'll throw out the codes I've got....
P0353
P0352
P0351
P0301
P0302
P0303
P0304
P1391-this is crank/cam sensor codes.
.[__]
OlllllllO
[]__[]
beserkur is offline
post #7 of 16 Old 12-26-2011, 02:50 PM
HarryJeepGuy
That's why I hate to assume... Lol. I don't know your year or milage, but if you have changed your cam and crank sensors twice already, 0351,0352,and0353 make we think your coil rail could be going bad. Not enough spark causing misfires.
P0351 (M) Ignition Coil # 1 Primary Circuit Peak primary circuit current not achieved with maximum dwell time.
P0352 (M) Ignition Coil # 2 Primary Circuit Peak primary circuit current not achieved with maximum dwell time.
P0353 (M) Ignition Coil # 3 Primary Circuit Peak primary circuit current not achieved with maximum dwell time.
post #8 of 16 Old 12-26-2011, 05:25 PM Thread Starter
beserkur
well my odometer just hit the 100,00 kilometer mark(60,000 miles)
It would surprise me that the coil rail would fail at this early stage,but it is a possibility,just seems peculiar that it would be so intermittent and also that it runs just fine if I stop and restart.
Anybody have a coil rail fail that has the same symptoms as mine?
It seems to me that it would happen more and more as I drive it and be less intermittent.
I'm still sure that it was bad gas/water in gas-this would surely screw up the O2 sensor,causing my CEL to illuminate.I could care less about that idiot light since they malfunction all the time,meaning any little thing can cause it to come on,not necessarily affecting performance.
.[__]
OlllllllO
[]__[]
beserkur is offline
post #9 of 16 Old 12-26-2011, 06:00 PM
JPNinPA
I haven't experienced those codes but what is your battery voltage? Also what about checking the ground to the engine and to the rail?
JPNinPA is offline
post #10 of 16 Old 12-26-2011, 08:05 PM
HarryJeepGuy
I'm surprised you had to change your cam and crank sensors twice already at 60k miles. I changed my coil rail at 100k troubleshooting a misfire code. It ended up being a fuel injector, but I left the new rail on and kept the old one for a spare. I've had a tank of bad gas before, and it ran like **** the entire time, backfiring and stalling. I guess you have plenty of things to look at, good luck. I'd try resetting the codes to see what it throws next. If it's been 2 weeks you're on a different tank of gas by now right?
post #11 of 16 Old 12-26-2011, 08:43 PM
JPNinPA
http://www.jeepforum.com/forum/f13/h...351-x2-704058/
Was interested being I never experienced this myself. Here is a link to help you out.
JPNinPA is offline
post #12 of 16 Old 12-28-2011, 12:19 PM Thread Starter
beserkur
Battery is 2 months old and battery load test gives me 12.4v and a 15 sec load drops it to 11.6-then right back up to 12.4.
The grounds are all good.
.[__]
OlllllllO
[]__[]
beserkur is offline
post #13 of 16 Old 12-28-2011, 12:26 PM Thread Starter
beserkur
Yeah I was really surprised too,it just decided not to start one morning,no forewarning at all. about year apart I'd say.
But anyways,I went out for a test drive yesterday,after about 30 mins driving time-no traffic,it started doing it again,put it in neutral and turned off engine,restarted and it was fine.still 1/2 tank left of that same gas.
I think I'll just run it dry,then fill up.
.[__]
OlllllllO
[]__[]
beserkur is offline
post #14 of 16 Old 12-28-2011, 04:47 PM
JPNinPA
If the gas doesn't correct it look at the link I posted up. Skip to the end and see they bought the CPS from the dealer. The others didn't fix the issue or failed quickly.
JPNinPA is offline
post #15 of 16 Old 01-17-2012, 08:17 PM Thread Starter
beserkur
UPDATE: Replaced the crank sensor-all is well,problem solved.
.[__]
OlllllllO
[]__[]
beserkur is offline
1991 YJ sputtering and losing power..please help! sirfoulsalot YJ Wrangler Technical Forum 15 12-19-2012 06:20 AM
Engine losing power and sputtering randomly Tblair23221 YJ Wrangler Technical Forum 27 07-19-2011 11:05 AM
engine losing power becketkf TJ Wrangler Technical Forum 1 06-24-2009 02:41 PM
losing power? lizard20 TJ Wrangler Technical Forum 6 03-18-2009 09:16 PM
Losing power at 60mph..engine light flashes sneakerpimp TJ Wrangler Technical Forum 5 02-23-2009 02:34 PM
