4.0 Compatibility - JeepForum.com
post #1 of 4 Old 08-20-2010, 07:54 PM Thread Starter
leedurr
leedurr's Avatar
1987 YJ Wrangler
4.0 Compatibility
I am trying to replace a 4.0 in a 2001 and having a hard time finding one. My question is do I have to use a 99-04 block or can I use an older on with the newer style head and assesories. I know the head it different due to the Coil pack but I don't see an differences in the block with a blind eye. Believe it or not the engine still runs even with a window now in the the number six cyl. I am doing this a for a friend of mine who is retired and limited on funds so I am trying to keep it down price wise. Thanks for any help I can get
Lee
87 YJ, 4.5 RE lift with monotube RE shocks, 33 LTB's, 258 w/4.0 head, HEI, and Weber carb, Header, Comp 252H cam, Dynomax, cat back and much more.......
leedurr is offline
post #2 of 4 Old 08-31-2010, 08:14 PM Thread Starter
leedurr
leedurr's Avatar
1987 YJ Wrangler
Well after some research I have answered my own question. For the 99 and up models you have have to use the 99 and newer block for mounthing of the accessories. You can go back with a newer block but not forward with and older block. You have have to use the newer 99 and up head casting 0331 also due to the nounting holes for the coil rain.
Lee
leedurr is offline
post #3 of 4 Old 08-31-2010, 08:26 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
You need the 2000 and newer setup to have the ability to do a bolt-in...
Knuckelhead is offline
post #4 of 4 Old 08-31-2010, 08:27 PM
Brown Dog
Vendor
Brown Dog's Avatar
You are correct
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
4.0 , engine , swap , compatibility , tj , wrangler
compatibility between my tj ax-15 and xj,yj ax-15? subzeroedj TJ Wrangler Technical Forum 9 02-23-2015 10:07 PM
ax5 compatibility dhc6 YJ Wrangler Technical Forum 2 01-01-2010 12:38 PM
Oil Pan Compatibility Delta347 YJ Wrangler Technical Forum 1 12-07-2009 05:08 AM
97 TJ 2.5 compatibility florida-xj TJ Wrangler Technical Forum 2 07-01-2009 11:08 AM
TJ and XJ Compatibility? mknherhappy TJ Wrangler Technical Forum 2 10-18-2007 02:51 PM
