4.0 5spd trans removing engine - JeepForum.com
post #1 of 2 Old 01-15-2012, 03:02 PM Thread Starter
Landrunner01
Hey, Guys I have everything removed and I am ready to remove the engine from the transmission. If anyone got any helpful info I would love to hear it. This is my 1st time removing a Jeep engine. I have worked with some 350s and chevy stuff.
Ty
Dwight
Landrunner01 is offline
post #2 of 2 Old 01-15-2012, 03:12 PM
dragginwagon406
Lift a little, check a lot. I had trouble getting my clutch to separate from the input shaft on the transmission (5-speed), the splines had rusted in place. I wiggled the engine while a friend pushed the clutch until it broke loose. I set a jack stand under the bell housing to help support it.
dragginwagon406 is offline
engine , transmission
Trans swap - 5spd to 6spd? gcfishguy TJ Wrangler Technical Forum 17 12-17-2009 04:46 PM
does anyone have the trans gear ratios 5spd vs 6 spd vetteman9368 TJ Wrangler Technical Forum 3 07-15-2009 01:13 PM
will 5spd trans bolt to 4.0 w/auto? RnEmOvr TJ Wrangler Technical Forum 4 06-06-2008 12:38 PM
engine possibilities 93' 4.0 5spd garoughrider YJ Wrangler Technical Forum 2 08-11-2006 06:11 PM
YJ trans swap 5spd to auto???? Rockdaddy YJ Wrangler Technical Forum 1 10-19-2005 10:43 AM
