3rd brake light/plate relo, no tire carrier - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 3rd brake light/plate relo, no tire carrier
Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiWarn, Smitybilt, Engo, Rugged Ridge Winches at CCORIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 08-12-2014, 01:32 AM   #1
MrSundays
Anyone have a link for a thread about running a setup with no tire carrier (tire stays strapped in the back) where I can use a center 3rd brake light with my plate under it or something? Ive searched but cant find one. If I had the resources I would just make something. Possibly a sheet metal tab with a light at the top and I could drill some holes in it to mount the plate.
Thanks
[URL="http://www.jeepforum.com/forum/f22/syd-tj-slower-than-molasses-2368441/#post22540729"]Syd the Sloth Build[/URL]
[B]F-22 Specialist[/B]
MrSundays is offline   Reply With Quote Quick reply to this message
Unread 08-12-2014, 08:17 AM   #2
UnlimitedMatt
How about simply removing the 3rd brake light completely? That is what I did, and have had no legal issues yet.
2005 Unlimited Rubicon, Sahara Edition #556, Colorado Jeep Club Member #556
Rusty, if you are reading this, I am still waiting for my $249 refund from 06/2010. Pm me for my address to send the check. Thanks!
UnlimitedMatt is offline   Reply With Quote Quick reply to this message
Unread 08-12-2014, 08:30 AM   #3
2jhanna
Another thing to consider is that if you relocate the license plate to the tailgate, you will need additional power for a license plate light.
Not a big deal to do to run an additional "button contact" like the current ones for the 3rd brake light.
jhanna
denton county, tx
2jhanna is offline   Reply With Quote Quick reply to this message
Unread 08-12-2014, 08:34 PM   #4
MrSundays
Meh, I was thinking of not running one because itll be right in headlight territory and should be able to see. We will see, theres a couple license plate brackets that have a built in light, just need the power.
Unread 08-12-2014, 08:45 PM   #5
2jhanna
Don't know about your state, but here in Texas, license plate light is checked as part of required safety inspection.
jhanna
denton county, tx
Unread 08-12-2014, 10:49 PM   #6
freeskier93
freeskier93's Avatar
Older pictures but I ditched the third brake light and use the button contacts to power the license plate light. If I were to add the third brake light back I'd probably use an LED strip under the rear valence.
Build Thread
My life in 2010: Chronicles of painting my Jeep
Axle Re Gear and Swap
CU Boulder Aerospace Engineering
freeskier93 is offline   Reply With Quote Quick reply to this message
Unread 08-12-2014, 11:05 PM   #7
hustler905
That's exactly what I have - an LED strip under the valence. It works OK and only cost $4.
hustler905 is offline   Reply With Quote Quick reply to this message
Unread 08-12-2014, 11:49 PM   #8
MrSundays
Im going with the TNT bracket so I can also mount the cb antenna in the center for better RX/TX. Also installing the ORFAB license plate light/third brake light combo. It will give it a much cleaner look.
Unread 08-13-2014, 07:24 AM   #9
2jhanna
Free skier, I did not realize there is a large square hole behind the tire carrier as shown in your second picture above. Is that hole present on all TJs?
jhanna
denton county, tx
Unread 08-13-2014, 10:26 AM   #10
hustler905
The hole is there on 03-06 TJs. That's where the vent is.
Unread 08-13-2014, 11:20 AM   #11
jeepinjeffrey
Here's what I did using off-road onlys third brake light and license plate relocation bracket. I really like it
2003 Wrangler Sport
4.5 Rubicon Express Lift|33" BFG KM2s|Ion Alloy 174|And never ending wish list!
jeepinjeffrey is offline   Reply With Quote Quick reply to this message
Unread 08-13-2014, 11:50 AM   #12
freeskier93
And so nobody is confused I swapped an 03-06 tailgate onto my 97 because the original was damaged.
Build Thread
Unread 08-13-2014, 05:08 PM   #13
2jhanna
Ok, thanks. Makes sense now. I have had my spare and carrier off my '02 a number of times and don't remember seeing the hole.
jhanna
denton county, tx
Unread 08-13-2014, 10:08 PM   #14
MrSundays
Im going to be throwing this on with the light setup here next week hopefully. Not sure how long shipping takes to here.
TNT Customs License Plate Bracket
