38's on a Rubicon - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 38's on a Rubicon
Genright at JeepHutMemorial Day Weekend Sale Starts Friday-Tuesday 10% off + New DEAL OF THE WEEK at ROCKRIDGE 4WD!
Unread 04-25-2009, 09:55 AM   #1
strokinout
38's on a Rubicon
How many of you would trust putting 38's on a rubicon with, let's say 5.13's and a stock motor and auto tranny?
Ever sneezed with Copenhagen in?
Now looking for a another Jeep soon
In memory of:
1997 Jeep Wrangler 6-cyl.
1994 Jeep Wrangler 4-cyl.
strokinout is offline   Reply With Quote
Unread 04-25-2009, 10:01 AM   #2
robncar
Bolts right on, no problem...
[CENTER][SIZE="5"][COLOR="DarkRed"][B]DON'T FEAR THE RE-GEAR!!![/B][/COLOR][/SIZE]
[CENTER][B][COLOR="DarkRed"][SIZE="3"]______[/SIZE]
[SIZE="3"]|_____|[/SIZE]
[SIZE="2"](O|||||||O)[/SIZE]
[SIZE="1"]|______|[/SIZE][/B][/COLOR]
[SIZE="5"][][/SIZE]===[SIZE="5"]o[/SIZE]==[SIZE="5"][][/SIZE][/CENTER]
[SIZE="4"][COLOR="DarkRed"][B]RED JEEP CLUB MEMBER #430[/B][/COLOR][/SIZE][/CENTER]
robncar is offline   Reply With Quote
Unread 04-25-2009, 10:03 AM   #3
strokinout
Would the dana 44's hold up to the 38's for daily driving, light trail use and some mud running? Sorry. I just read my first post and didn't realize I didn't even ask what I was trying to.
In memory of:
Unread 04-25-2009, 10:04 AM   #4
robncar
Originally Posted by strokinout View Post
Woudl the dana 44's hold up to the 38's for daily driving, light trail use and some mud running?
Perhaps? Why 38's, if I may inquire?
Unread 04-25-2009, 10:04 AM   #5
Unlimited04
Read tech links in my sig
Unlimited04's Avatar
x2 bolts right on. don't even need a lift or anything. you can even stop on a dime and lock up all 4 tires.
Unlimited04 is offline   Reply With Quote
Unread 04-25-2009, 10:04 AM   #6
Unlimited04
i'm going to go with a big NO on this one.
Unread 04-25-2009, 10:05 AM   #7
RubiconRazorbac
RubiconRazorbac's Avatar
Assuming you have the clearance, you'd definitely want to upgrade brakes, steering components, and axles. Otherwise you'll snap the tie-rod and blow the axle yokes trying to steer clear of the truck you almost ran into because you couldn't stop fast enough...
I'd love to see the rig though...
Your shaft isn't long enough to handle that kind of droop...
My build thread: http://www.jeepforum.com/forum/f9/ru...thread-792423/
KOH EMC thread: http://www.jeepforum.com/forum/f22/p...build-1476559/
RubiconRazorbac is offline   Reply With Quote
Unread 04-25-2009, 10:05 AM   #8
strokinout
There's a Jeep I'm lookin' at that comes with 38" Parnelli dirt gripz. Thanks!
In memory of:
Unread 04-25-2009, 10:06 AM   #9
2005X
37s are pretty much the limit on D44s. as asked before why 38s
www.youtube.com/kgries
2005X is offline   Reply With Quote
Unread 04-25-2009, 10:06 AM   #10
strokinout
I'll see if I can post any pics.
In memory of:
Unread 04-25-2009, 10:07 AM   #11
Unlimited04
don't forget the ball-joints and C's on a Rubi D44 aren't adequete, the tubes are too thin and too small in diameter.
if you want 38s, get 1-tons.
Unread 04-25-2009, 10:08 AM   #12
RubiconRazorbac
DD and light trail use, ok with the aforementioned supporting cast of steering, brakes, and axle upgrades. Mud running though--maybe one good run then a loud BANG...
Unread 04-25-2009, 10:09 AM   #13
strokinout
http://www.autotrader.com/fyc/img_po...&isStock=false
In memory of:
Unread 04-25-2009, 10:10 AM   #14
2005X
needs to be JPEG file
Unread 04-25-2009, 10:14 AM   #15
robncar
Why stop at 5.13's, I'd go right to 5.38's with the 4-speed auto.
If that's the Jeep, it looks like an RE LA, perhaps even a tri-link rear?
