37's lift recommendation - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 37's lift recommendation
Time To Save On Yukon Lockers!Rough Country Lift Kits and Parts!Ruffstuff 10 year sale
Unread 03-04-2010, 07:37 PM   #1
Unlimitedlou
Unlimitedlou's Avatar
Alright, I just boutgh my about eighth Jeep and I want to run 37's. Been researching it for a while. I am going to run tube fenders up front and a Genright or Poison Spyder crusher in the rear. I am going to get the one that makes the wheel opening larger by cutting it out. My lift will be one that has a 4 link in the rear. I want a LA lift. I am looking hard at Clayton or Rockcrawler. The question is, what is the smallest lift i can run without rubbing? Any suggestions? I am pretty sure I need wheel spacers. What are the pros and cons of wheel spacers?
2005 Unlimited Rubicon, too much junk to list!-sold
2012 JKU Orange Crush
Unlimitedlou is offline   Reply With Quote Quick reply to this message
Unread 03-04-2010, 07:53 PM   #2
TheSherp
I'm running 1.5" wheel spacers now without any issue, other that a STUPID national tire store NOT living up to there warante to rotate them with wheel spacers like the store manager "Garenteed" LMAO enough whinning.
I am running a 2.5 SL and a 1.25 Sl from looking at Rokmens website and there LCG (low center of gravity) jeep there, with the tube fenders I shold be able to run them with that.
TheSherp is offline   Reply With Quote Quick reply to this message
Unread 03-04-2010, 08:05 PM   #3
mrblaine
Wizard of Brakes
mrblaine's Avatar
Really? What did this research reveal to you about your axles?
I am Savvy
blackmagicbrakes.com
mrblaine is offline   Reply With Quote Quick reply to this message
Unread 03-04-2010, 08:53 PM   #4
RedRubiconLJ
RedRubiconLJ's Avatar
2015 JK Wrangler
He has a rubi with 44's and air lockers which IMO would be fine with the usual gears and alloy upgrade.
Im surprised you didnt ask what his research said about brakes......
My trial and error research has proven brakes to be more important than the axles.
2015 Red JKU Rubicon RK X-factor, Adams, Rockhard4x4, PSC, LoD, BFG, WARN
SOLD 2013 JKUR
Sold 2005 Rubi Unlimited
Jeep Pics
2004 TJ sold
1993 YJ sold
RedRubiconLJ is offline   Reply With Quote Quick reply to this message
Unread 03-04-2010, 09:05 PM   #5
mrblaine
Wizard of Brakes
mrblaine's Avatar
Do the brakes attach to the axles in any way?
I am Savvy
Unread 03-04-2010, 09:09 PM   #6
RedRubiconLJ
2015 JK Wrangler
HA! That aint gonna cut it mrblaine!!! You must be slippin in your old age since I have read your posts that say you dont drink!!
The axles and brakes are a separate function just like the steering.....and thats attached to the axle as well!!
SOLD 2013 JKUR
Jeep Pics
2004 TJ sold
1993 YJ sold
Unread 03-04-2010, 09:22 PM   #7
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Good to see another Louisville person. If you want to keep it low, you can run the high line tube fenders.
Clayton makes a good kit and they are about to or have released a 3 link for the front.
I say depending on your fender choice either a 3.5 or 4.5 springs (or less with the highlines) with proper bumpstops. A brake upgrade is basically a must.
check out K&I Fourwheelers.com website if you are interested in some local wheeling.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
My TJ Build Thread.
www.kifourwheelers.com
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline   Reply With Quote Quick reply to this message
Unread 03-04-2010, 09:31 PM   #8
mrblaine
Wizard of Brakes
mrblaine's Avatar
Neither will those axles on 37's if you wheel where they make a difference.
I am Savvy
Unread 03-05-2010, 02:54 AM   #9
never monday
Blaine, he's in Mudville
start here
http://www.jeepforum.com/forum/f9/i-...-my-tj-751873/
go here
http://www.jeepforum.com/forum/f9/lo...basics-879206/
then come back to the discussion. 37's REQUIRE a lot more then just clearance.
Get Savvy
never monday is offline   Reply With Quote Quick reply to this message
Unread 03-05-2010, 03:49 AM   #10
97casteeltj
so you're on your eighth jeep and you still don't know the basics????
needing a new rig....
97casteeltj is offline   Reply With Quote Quick reply to this message
Unread 03-05-2010, 06:32 AM   #11
03rubiconMG
Here is my jeep. 37" Iroks on 4.5"rubicon express suspension, 1" body lift. TNT tube fenders on the front. IF you put full replacement tube fenders front and back you wouldnt need the body lift. but the body lift does make some things easier like working on the top of the rear shocks when the bolts break, putting in a MML, a tummy tuck, a gas tank skid and other things.
2003 white rubicon on 37s
http://farm4.static.flickr.com/3374/...376a0a33_o.jpg
03rubiconMG is offline   Reply With Quote Quick reply to this message
Unread 03-05-2010, 07:53 AM   #12
Alex74012
my toaster on wheels
37x12.50x17 truxs mt's
that dd rubi on 37's
Alex74012 is offline   Reply With Quote Quick reply to this message
Unread 03-05-2010, 09:04 AM   #13
Unlimitedlou
Thanks to most of you. There are a couple of guys on here that must be from the pirate web site.
Unread 03-05-2010, 09:08 AM   #14
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
that means they speak from experience. just because you don't get the answer you want to hear, doesn't mean it's not the right answer.
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 03-05-2010, 10:28 AM   #15
Peterpsc
Unlimitedlou, don't take comments here too personal. Most are here to help.
I'm very experienced and nonetheless I've gained important insights here while lurking in the background especially from the likes of Mrblaine, unlimited04, Bransford and others. When you preface your questions with what appears to be solid wheeling experience, i.e., on your "eighth" jeep, many of us expect your jeep knowledge base to be deep and significant. With 37s on D44 axles and wheeling a little on the hard side, even if they're built and geared right, is probably pushing the limits of that axle...and that's not considering the very likely material upgrades required for brakes, steering, suspension, and so forth.
Doesn't mean it can't be done, many have done it, but running D44s w/ 37s and wheeling hard probably isn't wise.
Peterpsc is offline   Reply With Quote Quick reply to this message
