37's with a Dana 30? - JeepForum.com
post #1 of 18 Old 09-02-2006, 09:37 PM Thread Starter
PJTJ
Hey all,
I found a great deal on some MT's 37inch Baja Claws. I really want to get them but i'm wondering if my front dana 30 will hold up. I'm running 35 MT/R's now with no probs!
I was thinking it might if I put in alloy axle shafts and a truss?
I know a 44 and a 30 share the same u-joint which usually is the weak link.
I'm wheeling mostly in rocks.
Any thoughts would be great!
99 Black Flat Fender TJ
TERALOW 4:1, Teraflex SYE,
35in MT/R's Gale Banks Exhaust, Skyjacker Lift
Poison Spyder Protection, Dana 44
Detroit Locker,Alloy Shafts,Warn M8000
PJTJ is offline
post #2 of 18 Old 09-02-2006, 09:40 PM
stevensinger
stevensinger's Avatar
Be careful after 35s on them, I would look for stronger u-joints though... I agree with them being the weakest link.
stevensinger is offline
post #3 of 18 Old 09-02-2006, 09:48 PM Thread Starter
PJTJ
Well if i went with a stronger joint wouldn't my ring and pinon be the new number 1 on the weak list? I don't know if that would be a good thing.
PJTJ is offline
post #4 of 18 Old 09-02-2006, 09:55 PM
kaketj
beef jerky and grease....
kaketj's Avatar
personally,I wouldn't run a 37" tire on a D30 without a super kit and ujoint upgrades and maybe a truss,by the time your done though you could of purchased a D44 w/a hub conversion from warn,but that's just me,maybe alloy everything and go easy on it?
I just don't see it being a long term solution for rocks?
"shoot first,we have shovels"
2004 X w/ RESF 4.5- super 44/44 w/arb 35x12.50R15mt/r- all armored up! Warn 9.5 ti(front) 9.5xp(rear) (SOLD)
1999 Cherokee sport (build in progress)
New toy. ZO6
kaketj is offline
post #5 of 18 Old 09-02-2006, 09:59 PM
NH Jeep Junkie
I think it all depends on your driving style. I have seen (retards) people running 44" swampers on dana 30s without busting them.
IMO, DO IT If you bust you upgrade. At least you'll have some more time to save up.
I am not doing any of this to impress you!
NH Jeep Junkie is offline
post #6 of 18 Old 09-02-2006, 09:59 PM Thread Starter
PJTJ
well if i went with a front 44 that would be
housing = 500
shafts = 450
hub conversion = 900
u-joint upgrade = 300-500
so thats over 2G!
If I built a truss = maybe 75 bucks
shaft upgrade = 500
thats only 575!
Will that hold up?
PJTJ is offline
post #7 of 18 Old 09-02-2006, 10:00 PM Thread Starter
PJTJ
I like that thinking!
I just don't know if my wife would!! Oh, well what she doesn't know can't hurt her!
PJTJ is offline
post #8 of 18 Old 09-02-2006, 10:33 PM
kaketj
kaketj's Avatar
they always find out
New toy. ZO6
kaketj is offline
post #9 of 18 Old 09-02-2006, 11:03 PM
BNovak
BNovak's Avatar
housing = 500
shafts = 450
so thats over 2G!
shaft upgrade = 500
thats only 575!
Will that hold up?
Too bad the D44 still has the same lousy U joints that the D30 does.
Find some junkyard shafts as trail spares and be easy on the throttle.
'97 Forest green. ~6" total lift, 8.8, etc. 36" TSL's, winch. You get the drill.
BNovak is offline
post #10 of 18 Old 09-02-2006, 11:07 PM
The Mean Fish
The Mean Fish's Avatar
You're talking about the 44 out of a Rubicon, I think he's talking about something out of a full width narrowed for a TJ which doesn't share steering knuckles or u joints with a 30. You can build a front 44 for a TJ from a full size Ford truck or Wagoneer.
The Mean Fish is offline
post #11 of 18 Old 09-02-2006, 11:19 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
With my low ratio axle gearing gearing, sufficient lift height, and goal of converting to an automatic transmission that probably would be a 3-speed, I asked those whose advice I trust about 37" tires for my well-built rig to lower the RPMs after installing that 3-speed automatic. I thought the 37" tires would be a cool solution to slightly lower my engine RPMs from the new 3-speed auto with my present 4.88 axle gearing.
As TJs go, mine's built for strength and durability. Hardened AlloyUSA axleshafts in the rear Dana 44, hardened Warn axleshafts and hubs in my Front D30. Currie tie rod and drag link, steering bracing, RE LA suspension, 4.88 gearing, etc... all seemingly strong enough and geared properly to convert from my present 35" tires to 37" tires. After much counsel against my 37" idea (more for lower RPM reasons for the proposed 3-speed auto), I accepted the group advice to avoid the 37" tire. The Dana 30, steering, etc. just aren't up to 37" tires if you wheel your rig. A friend did go to 37" tires with his equally well built TJ and after a year of constant headaches, went back to 35" tires where his headaches mysteriously disappeared.
Maybe 37" tires would be ok for a street Jeep but if the rig is wheeled in demanding terrain, the Jeep may not hold up all that well.
Just what I learned after having nearly the same thoughts very recently.
Gone on vacation until August 25.
Jerry Bransford is offline
post #12 of 18 Old 09-02-2006, 11:55 PM
UCTJ
UCTJ's Avatar
I agree with Jerry, and you may get a good deal on the 37s but in the long run it wont be much of a savings when you break parts. Also dont forget you need to address your brakes espc. with 37s but really at 35s....Id say just build your 30 up and keep your 35s...
UCTJ is offline
post #13 of 18 Old 09-03-2006, 08:08 AM
ocezam
ocezam's Avatar
I agree with Jerry completely. With any piece of equipment there is a point where more is not better. 35's on a D30 is already pushing this envolope.
As for the idea of "do it...if it breaks upgrade", that depends on where you are when it breaks. I don't even like traveling with people whose rigs have a high chance of not making it back.
'01 TJ. 4"Full Traction. 1" BL/MML. 35" BFG Muds. ARB's front & Rear. Full skids. Warn Winch. Lots of other crap!
ocezam is offline
post #14 of 18 Old 09-03-2006, 08:21 AM
Spartan302
Spartan302's Avatar
You can only polish that turd so much. 37's will still destroy it eventually.
Spartan302 is offline
post #15 of 18 Old 09-03-2006, 10:10 AM
ErikJordan
Pimp Hand
ErikJordan's Avatar
37's are too much for the dana 30. the steering, and brakes are not up to the challlenge.
___________________________________________
What is all of this talk of Savvily designed products?
ErikJordan is offline
Dana 35 with 37's? IH8ROADZ TJ Wrangler Technical Forum 66 10-29-2009 01:33 PM
Got my 37's Brent_f70 JK Wrangler Technical Forum 26 06-01-2009 10:44 AM
37's on a D30 Chris @ GATR TJ Wrangler Technical Forum 19 12-14-2007 10:03 PM
is anyone running 37's or bigger on dana 44s codymparmy TJ Wrangler Technical Forum 11 07-07-2007 08:04 PM
37's 05fulltraction TJ Wrangler Technical Forum 28 01-27-2007 07:30 AM
