Quantcast 36'' tires on a 4'' lifted tj????!!!! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 36'' tires on a 4'' lifted tj????!!!!
Old 11-06-2008, 08:53 PM   #1
swampdonky
i had a guy offer me some 36 X 12.50s i have 4 '' of lift on my 03 tj is this a posable fit???
swampdonky is offline   Reply With Quote
Old 11-06-2008, 08:54 PM   #2
jeepkidd9
If you put a highline kit on your jeep then sure
Firefighting Jeep Club #26
jeepkidd9 is offline   Reply With Quote
Old 11-06-2008, 09:02 PM   #3
swampdonky
what is a highline kit
Old 11-06-2008, 09:04 PM   #4
never monday
or good tube fenders
Get Savvy
never monday is offline   Reply With Quote
Old 11-06-2008, 09:05 PM   #5
vtjeepguy97
Vermonter
search it on the site. basically it involves moving your wheel wells up a few inches. Lifting your fenders. A bunch of guys have done it themselves on the site, or you can buy the kit, but thats pretty pricey i think.
vtjeepguy97 is offline   Reply With Quote
Old 11-06-2008, 09:07 PM   #6
Tinman641
http://www.quadratec.com/products/12503_300_07.htm
I don't think I've seen 36" in a 4" lift, i would think that it would be like putting 33s on stock springs. If your lift is all spring, maybe go with a 1 1/2 or 2 inch body lift. just some money saving thoughts
[COLOR="Blue"][FONT="Franklin Gothic Medium"][I]"God made Police so Firemen could have heroes" [/I][/FONT][/COLOR]
Tinman641 is offline   Reply With Quote
Old 11-06-2008, 09:14 PM   #7
never monday
36" Iroks on 2.5" springs and a 1" BL
Get Savvy
Old 11-06-2008, 09:29 PM   #8
mudb8
want it rite or rite now?
mudb8's Avatar
here's a couple I've done..
37's on 3.5" with a DIY highline, cost of materials is about 20 bucks....
34's on a 2.5" lift with DIY highlines clearanced for also for 37's....
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
In need of work... 11/2/11
mudb8 is offline   Reply With Quote
Old 11-06-2008, 09:38 PM   #9
MuddyJeepZJ
MUD SUCKS!
MuddyJeepZJ's Avatar
I run 36" SXs on a 4.5" lift 1.25"BL and stock flares.
1998 Jeep Wrangler Sahara
2003 Dodge Ram 3500
My Build Thread
New Jersey Jeep Association
MuddyJeepZJ is offline   Reply With Quote
Old 11-06-2008, 10:10 PM   #10
mudb8
mudb8's Avatar
heres a link to my highline thread... the title doesn't exactly give it up..
http://www.jeepforum.com/forum/showthread.php?t=621996
Old 11-06-2008, 10:11 PM   #11
vtjeepguy97
Vermonter
is it just me or did muddyjeep loose his snorkel?
Old 11-06-2008, 10:49 PM   #12
JeepinRRT
it would appear he did so after he found some mud
03 TJ silver, 4.0 5 speed, RC 3.25" lift, JKS 1.25" BL, 1" MML, RC 2.2 Steering stabilizer, 33x12.50 BFG AT T/A KO's, 15x8 MB Razor Wheels
Optional D44 rear
Custom switches in sound pods for when doors are off
JKS Disco's, Infinity's in the pods
JeepinRRT is offline   Reply With Quote
Old 11-07-2008, 02:25 AM   #13
dawnskaybug
I ran 37s on a 4.5 RE and 1 inch BL..
Never again Tore my stuff up (with tractor tires) ..
Yeah I could of adjusted my bump stops but a tire in the air kinda removes the whole ya need lockers..
Im running 35 boggers now,,
05 LJ
RE 4.5 SA 1inch BL
Aussie front Detroit rear 4.88s
1200 series Tractor tires (37x10)
Warn winch stinger
Lotsa trail damage
dawnskaybug is offline   Reply With Quote
Old 11-07-2008, 08:24 AM   #14
jcssurf
What kind of tubes do you have, Monday?
2004 TJ-L with 3-4" of lift, 35's, and no money
The Unlimiteds shall inherit the earth.
jcssurf is offline   Reply With Quote
Old 11-07-2008, 08:34 AM   #15
rtyler13
you can run 36s on your jeep with that lift, however if you start to get into flexing when offroading you are going to rub and will start to tear stuff up...i have 35s on my 4inch lift and i rub at full flex on the front with the sway disconnected...not enough to tear anything up but anything bigger and i would
simply to say on the street you should be fine
2000 TJ
and more family than fits in it
1991 Chevy Suburban
rtyler13 is offline   Reply With Quote
Glock Forum
