#1 | |
35's on a 3.5''???
I found a 3.5'' rubicon express lift kit for the 04' tj. Is it possible to squeeze 35's underneath those well's?? Anyone have the same situation?
#2 |
yup.
I'm doing that. RE kits are larger than what they say...usually by an inch.
2000 Sahara TJ 1997 Limited ZJ |
#3 |
Demonic Jeep Freak!
It fits,but a spacer up front would make it better(or a BL).
![]() ![]() Last edited by TheBoogieman; 09-29-2009 at 08:43 AM.. |
#4 | ||
And/or a highline fender kit and some trimming in the rear. There's lots of threads about this sort of thing, just do a search for "LCG" or "low center of gravity". You'll see lots of options.
#5 |
I don't know for sure how 35's will fit. I have a good amount of room with the RE 3.5 and 33s. I'd say at the most you'd need a 1" BL, or front tube fenders/trimming, or extend the bumpstops a little. I bet if you don't disconnect you'll also be fine.
^I wouldn't listen to what I say. I don't know what I'm talking about. Please use the search feature. |
#6 |
Demonic Jeep Freak!
#7 |
TITS
Sure, I run 35's on 2.5" of lift and a 1" body lift. Plenty of room.
#8 | |
Just add the 1" body lift to that kit and 35's will fit perfectly.
2004 TJ | 5'' on 35x12.5's | Currie HD Steering| Smittybilt tire carrier | 4.56's | 1988 XJ | 6'' on 33x12.5's | Locked and Loaded | Quote:
#9 |
I'm doing the same. 2.5 OME, 1.25in BL, 3/4 spacer in front. I run 35's on and offroad no problem.
Khaki 2004 Wrangler X OME HD Kit,JKS BMML,1.25 JKS BL, adj. control arms RE Generation II Quick Discos 35x12.5x15 Goodyear MTR's w/ Kevlar, MT Classic II's D44 rear axle w/ ARB, alloy shafts, 4.56 gears Dana 30 with ARB, 4.56 gears, alloy shafts and ujoints |
#10 |
Nom Nom Nom
Thats what Im running. Look at the pic in my sig.
#11 |
I have the same set up. I wanna go with the Metalcloak tube fenders when I bump up to 35's. I really dont want to lift my rig any higher.
Jeep! |
#12 |
Nom Nom Nom
x2 exactly what Im saving for
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
