#61 | ||
I can't offer any first-hand experience, as my TJ doesn't have Jeep axles under it. 3/4 Ton Chevy discs at all 4 corners for me.![]() It's nice to see that you've determined (via this thread) the need for improving your stock brakes. I'm quite sure you'll be extremely happy with the Vanco kit.
#62 | |
Do it right or not at all
![]() Join Date: Jan 2003
The front OE brake assembly was discovered to be flexing under high brake pressure which when combined with the single piston caliper, could not keep the brake pads in full contact with the rotors which is what causes poor braking with large tires. The Vanco kit replaces the single-piston caliper with a dual-piston caliper whose larger surface are keeps the brake pad flat against the rotor. The kit also includes a substantially strengthened knuckle/caliper that resists bending/deforming under heavy braking pressure. That the OE power brake system's fluid pressure is capable of overwhelming and actually flexing the OE brake assembly so the pads could no longer maintain full contact with the rotors was a surprising find to the Vanco brake kit's developers as led by mrblaine.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#63 | ||
2.5L max gross trailer weight 1800kg (3960lb) 4.0L max gross trailer weight 1125kg (2475lb) ![]() Anyway, I didn't get a chance to test my brakes with the decelerometer we have at work and I'm off for a couple of days now, so it'll be next week. I don't have access to a stock TJ or one with uprated brakes so I was going to use the 03 Ford Focus we have for comparison. IIRC the decelerometer gives the braking distance too. It should give an idea of how far you'd need to be behind a car with good brakes, to be able to stop without colliding, if it were to do an emergency stop.
"Giving English to an American is like giving sex to a child. He knows it's important but he doesn't know what to do with it." Adam Cooper (19th century) Rockauto 5% discount code can be found here... http://www.markviii.org/LOD2/products_services.htm Online factory service manuals can be viewed at http://www.jeep4x4center.com/knowledge-base/index.htm#service Parts list PDFs available from http://www.berrysprinter.com/jeepparts.php |
#64 | |
I don't know much about the Vanco setup, but from the pics it looks like retains the single sided/sliding pin design, just beefier to prevent/reduce caliper flex. I'm guessing the pistons are smaller to maintain similar (or even reduce) piston volume?
'03 Sport, Patriot Blue '04 C5 Corvette |
#65 |
not sure what has been said in the last two pages, but all i ahve to add is if you think the stock brakes can hold 35's then you have to be kidding me.
i run 33's and until you know what its like to slam the brake pedal down as hard as you can and nothing happens.. then youll know how important upgraded brakes are.. and for all you who keep crying about the price i have two things to say.. what price do you put on your life and if its really that big of a deal then upgrade to v8 grand cherokee brakes.
99 XJ Sport - 3" lift, 31 BFG At's -DD 94 XJ Sport - 5" Lift, Locked on Swampers and beaten I Just dropped in to see what condition my condition was in... |
#66 |
Soo.... what about the stock brakes (assumably) being up for towing a 2000 pound trailer. How about the (LJ?) that can tow 3500 lb?
I would like to see those calculations (from earlier) with these factors introduced and some real numbers. |
#67 |
" It looks more like a personal preference related to driving style to me."
how bout SLOW DOWN!
FOR SALE:SOLD 2000 TJ 2.5" CLAYTON L.A. W/HYDROS, SYE/XJ SHAFT, 4:10 GEARS, 8.8 MINI SPOOLED, LOC-RIGHT FRONT, 1" BODY LIFT, 1" MML, 35" MAXXIS BIGHORNS, RE GEN 2DISCOs, BELLY UP, ALCOS IN FRONT, WARN X8000I |
#68 | |||||
Brake Wizard
Go in for the license during which I have to pass a vision test. Pop the glasses on and ace the test perfectly and get the corrective lens note in the process. For grins, I removed the glasses and read the chart again. Imagine my surprise, disgust, and astonishment that I could also pass it without glasses and had I done it first, I wouldn't have the Corrective Lens notation on my license. According to the State, I'm more than safe to drive without glasses. If you had kids and me driving around them or transporting them for you in my vehicle, you wouldn't be happy if you knew what I don't see without my glasses on. Yet, the State considers me perfectly safe and is willing to license me in the process without them. Essentially, I don't place a lot of stock in what the state considers GOOD and is willing to underwrite as SAFE. Quote:
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#69 | |
When backing my camping trailer up my driveway, which is sloped upwards towards my house, I use 4W Low because the auto transmission doesn't give me much oomph when in reverse on a hill. You can imagine my surprise the first time I shifted into drive to re-position the trailer and found that I had to literally stand on the brake pedal to keep the Jeep/trailer from moving forward. If I had had any momentum up before applying the brakes I'm not sure it would have stopped very quickly at all. My experience doesn't necessarily directly compare with driving the road or trail with no trailer and 35 inch tires, but it makes it very easy for me to believe that the stock brakes are at or past their safety margins under those conditions. Like others have said, some Jeeps may have brakes that do work under those conditions, but I know that mine sure don't. I don't think I'll have much trouble getting my wife to agree to spend the $$s on a Vanco Big Brake Kit this winter; she has seen enough of the stupendous idiocy shown by other drivers when a vehicle with a trailer comes in sight to want to have the best braking setup possible. |
#70 | |
So the point of this thread is to let people know that just because it is someones personal opinion (mr blaines, or jerrys) that 35s on stock brakes are unsafe, that doesn't make it so. I was letting people know that my local authorities both where I currently live and where I was living before, and from what nicholas says where he lives aswell (germany) have decided that the brakes on our vehicles are safe for use where we live. People should check with there local authorities to decide wether it is 'safe' or not, instead of just listening to someones personal opinion Luke. |
#72 |
I've never tried it at highway speeds, but at decent speed I can slam on the brakes and lock up the 35s. What more do I want? If stock brakes can lock the wheels up, how will I benefit from bigger ones?
#73 | ||
Brake Wizard
Actually it does make it so because my opinion is not so much personal as empirical. I've driven far too many TJ's on 35's that can't lock up the tires that I know better and if I were to let you drive them, you would not only pronounce them unsafe, you'd make me drive it back to my shop. Quote:
#74 |
Brake Wizard
Please try it twice at highway speeds back to back from 65 mph and report back to us. I've got some money I'd be interested in wagering that you won't make the same report or have the same opinion. Seriously.
#75 |
Personally, in this case, I don't need "the local authorities" to decide what is safe and what isn't safe for me. It's a matter of taking responsibility for yourself and other drivers.
Columbus: "You're one of those guys who always has to have a better story than anyone else, aren't you?" Tallahassee: "No way... I knew a guy who was way worse at it than me!" |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
