#151 | ||
#152 | ||||||||
Brake Wizard
So, here's what happens with a lifted TJ. As you start your braking event, the weight tranfers to the front axle. Since we're typically lifted with very compliant suspensions and you are unable to cheat the laws of physics, every pound that tranfers to the front axle has to come from somewhere. Guess where that is? That's right, it comes off the rear axle. The more compliant the suspension, the more exaggerated this effect becomes. Since the stock TJ combo valve is already set up to limit the self actuating nature of rear drums, it's typically pretty close and when you get the fronts working really well, the back stays balanced quite well with the stock combo valve. There are some, (not enough to make it a rule) rigs that can and do respond well to bypassing the rear limiting action of the combo valve by removing the o-ring from the plunger which gives full pressure to the rear. All of the kits have been tested extensively on TJ's with the stock booster, master, and combo valve. If anything different were needed to repair the bias, it would be provided. Since the system works pretty darn well as is, nothing is usually done. Quote:
Absolutely rear discs are better at resisting fade. But, the question wasn't which brakes will work better while running down the mountain and using them repeatedly and then the improvement will only be very slight. The question was whether or not you will notice a difference by switching to rear discs. Unless you're running the mountains or your rear drums were messed up, not only will you not notice a difference, you really shouldn't. Think for a second. If you get the rears working too much better in a lifted short wheelbase vehicle, what stops you from swapping ends in turns when the streets are wet? (that was rhetorical) Quote:
I started swapping on the ZJ rear discs because of how horrid the fronts are. I was operating under the misguided conception that rear discs would somehow improve my braking. Imagine my suprise when that didn't cure what ails the TJ nor did it improve braking. I still do and still recommend the swaps, but never for better braking. They are easier to work on, less maintenance, less adjusting, and are better at resisting fade which is really never an issue on the TJ because of how little work the rears actually do. Quote:
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#153 |
That is a very good quote. Inertia has a funny way of doing that. Maybe that is why a Jeep with 4 fat guys and stock tires is faster off the line than a jeep with 33"s stock tires, proper gearing and just bubba riding shotgun. Just like a train, slow to come to speed, slower to come back from speed.
JFI Member #7: Helping out the Scammed 2004 Rubi: Ready to Kill the Chrome! Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s Do the Jeep Wave :D 0|||||||0 Take 95% of what I say as a joke/sarcasm!-Thomas Last edited by LuckRider; 09-23-2009 at 12:08 AM.. Reason: clearing some ambiguity. |
#154 | |
I had a 1998 TJ which I used to tow an enclosed utility trailer stuffed with camping gear; don't know the total weight but I would estimate 800 to 1000 lbs. I had much much less stopping problems with that than my somewhat heavier camping trailer with the Unlimited (which also has more weight on it due to bumpers/winch) and has the larger tires. On the SWB TJ I had 15 inch wheels with much closer to stock tires (235 75R15). |
#155 |
newb
You are correct, the brakes are the same TJ to LJ (same year models)
... keeping an eye on you guys. |
#156 | |
JFI Member #7: Helping out the Scammed 2004 Rubi: Ready to Kill the Chrome! Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s Do the Jeep Wave :D 0|||||||0 Take 95% of what I say as a joke/sarcasm!-Thomas |
#157 | |
![]() [SIZE="3"BUT BEFORE I GO I WOULD LIKE TO SAY YOU STILL HAVE NOT PROVED ME WRONG ALL YOU HAVE IS OPINION[/SIZE] |
#158 |
I think more people on Jeep Forum need to take a college physics class.
-0|||||||0-
He who hunts in a pack is still a dog. The lion hunts alone, and so do I. - Napoleon Conducting an argument by appealing to authority is not using your intelligence; it is just using your memory. - Leonardo Da Vinci |
#159 |
i just wish they knew how to construct proper sentences.
#160 |
Nnnnghh. ..... I'm having trouble with Luckriders' "ambiguity" issues. I think it needs more clarification, yet. Also, I figured that overall weight (GVW) would have some bearing on brake performance.
As in: TJ with stock tires and brakes pulls a trailer weighing 2500?lb. just for laughs. Same tj swaps on 35" tires not pulling a trailer. How does the comparison result from the mathematical (physical) equation mentioned earlier? We can leave out engine braking. |
#161 |
OK so how bout this...
If you have the money to upgrade your tires, then suck it up and do the brakes. Outside of the fact that, by comparison, stock brakes on stock jeeps are iffy to begin with, upgrading the rotational mass of a car should mean upgrade of the braking system. Its basic logic people. I dont care if the government ok'd it, if you havent noticed, the gov can be pritty stupid at times, doesnt mean they know what their talking about. If your not worried about yourself then worry about the person infront of you in a mini that you will smash. EVERYONE has to deal with a panic brake every so often, i dont care who you are, so if you plan on just keeping distance, come down to DC and try and drive. People will cut you off and give you a foot of space between them. I think everyone here will agree that you can get away with no doing squat to your brake system, but its not wise, and your just going to put others at risk, or whoever you let drive your car. as i said before, I would not put 35's on mine, without having the brakes done... simply because i care about family members that i let borrow it.
1999 TJ BFG AT 31's | BDS 2" Lift | JKS Quick Disco's | Zone Rear Sway Links | TeraFlex 1/2" Drop+Washer | Warn M8000 | Viking 80' 3/8 Synthetic w/ Safety Thimble | Viking 350 Fairlead | MetalCloak AL Bumper | 99 Durango Steering Box | Uniden 520 CB w/ 3' FireStik | ebay header | Magnaflow Mid-Cat | Banks Cat-back | XJ Steering Linkage | Hella Black Magic (x4) 2011 Patriot FD1 |
#162 | |
My build thread: http://www.jeepforum.com/forum/f9/rubiconrazorbac-build-thread-792423/ |
#163 | |
JEEP FREAK
Blaine has demonstrated that he is well qualified to discuss TJ brakes. You keep asking for proof. The proof is in the product that Blaine helped develop.
98 TJ |
#164 |
newb
so will someone please tell me what brand pads will make a...
![]() stop like a... ![]() ![]()
#165 | |
'03 Sport, Patriot Blue '04 C5 Corvette |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
