11-23-2005, 11:53 AM
#16
Yippy for you!!!!!!!
Originally Posted by MR.CLIFFORD
I swapped my front axle in under 2 hours.
I had a problem with the bolts on the upper control arms, They had a clip that is supposed to hold the bolt so it won't turn. it just spun when I turned the nut and was a PITA to get it off so I could get a wrench on the bolt.
The above post is my opinion and I have no facts to prove it... :)~
http://www.tjhardcore.com
The ultimate TJ owners only forum
11-23-2005, 12:16 PM
#17
Originally Posted by jaburk
Yes, your brakes will bolt right up tp a TJ Dana 44. Here is what I did for my rear Dana 44 buildup:
Dana 44
•Alloy USA axle kit - $259 (Quadratec)
•Detroit Locker - $475 (DC4WD)
•Dana Gears 4.10 - $180 (DC4WD)
•Dana 44 Housing - $519 (PORC)
•HD Dana Cover - $25 (MAD4wd)
•Axle Retaining Plates – $8.06 each (MoparPart.com)
•Shim Kit - $85 (Randy’s Ring & Pinion, Dana #708193)
Why did you choose the detroit locker?
Originally Posted by Joonhoss71
Don't take their teasing, learn how to out-wheel them, then serve them a frosty-cold mug of STFU at the end of the day!
'97 TJ, 4 squirrels, 31X10.50s, hand throttle, home-built front/back bumper/tire carrier, home-made rock rails, 1" BL 4"susp. lift, KC slimlights, T-Max EWI-10000 Winch, 143,000 hard miles.
11-23-2005, 02:31 PM
#18
Price, durability, and good street manners.
1998 XJ, RE 3.5" Lift
11-23-2005, 05:10 PM
#19
I did mine with a sears 2ton a couple of HF stands and craftsman ratchets with crappy ratchet cams and a hacksaw. I think I could have done it in 2 with a set of snap ons, some pnuematics and a lift.
I will qualify my time estimate:
day and a half each in the driveway
2 hours in a decent shop.
[COLOR=Navy][SIZE=2]03 Patriot Blue Sport[/SIZE][/COLOR]
Rubi d44 both ends, Crane Diff Covers, Rock trac t-case
Tom Woods CV DS, Alloy USA rear axles (waiting for install) ARB front bumper, Rock-it-Man Rockers
knoblock rear bumper, OBA in process,
bestop tire carrier, 35-12.5-16 trXus MT's on MOABs with 1.25 spidertrax
Currie HD steering
Nth Degree 6" LA kit. Garvin Wilderness Rack w/hi-lift mnt
HEMI & 5spd Auto
11-23-2005, 05:33 PM
#20
Do it right or not at all
I swapped my rear axle in about 90 minutes. And that was before I had air tools.
11-23-2005, 05:34 PM
#21
I feel like a real slug now  , and I thought I was a pretty decent mechanic
Currie HD steering
HEMI & 5spd Auto
11-23-2005, 05:40 PM
#22
I should include that a friend helped.
11-23-2005, 05:48 PM
#23
I lack money
Where in Illinois are you chaoticdefekt? I like wrenching and I have done a rear axle swap before. I am impressed with these low axle swap times and I don't doubt them. However, living in the chicagoland area meant I had to deal with some rust. Also, everytime I turn a bolt on my Jeep something goes wrong. For instance, taking my skid plate off took 2 hours. 6 bolts were rusted in the frame and through a skyjacker t-case drop kit. I had to drill through...anyway, just leave yourself plenty of time and it is a very straightforward swap.
A side note, junkyards around the chicagoland area (if you live around here) are not very good for finding Jeep axles. It took me quite some time to hunt down a decent HPD30 for a reasonable price. I just built up a D44 from the housing up for the rear axle; IMO that was the best way to do it. Also, if you are going with some taller tires, you may want some lower gears. So, even if you keep the D30 in the front, you'll most likely be re-gearing that as well. Oh, and don't run out of money. I have a HP30 sitting in the garage along with my t-case shifter linkage. No money to regear the front axle...
Red Jeep Club Member 111
'99 TJ - work in progress...see profile
'08 WK - Silver RME, DD.
