33x9.50R15 - JeepForum.com
post #1 of 32 Old 09-22-2008, 01:59 PM Thread Starter
SOLIDJP44
33x9.50R15
is it worth me going from 31 to 33s i wan tto stay narrow bc i think my mpg wont drop as bad and i wont lose so much horsepower. I do like the narrower tires. i hardly do any wheeling anymore and is mostly a dd. Will a 33x9.5 look silly or what? I know it will probably run when disconnected , any other worries with jumping to a 33. the bf are really 32.7 and my maxxis is just about 30.6 so is that big diffrence in everyday driving...input please let me know whats the best route, 32s are to wide for me and my stock wheels so either 31x10.5 or 33x9.5
-00 Mildly Modified Wrangler SporT-Sold
2011 GMC ALL/Terrain Sierra z71-Current
SILVER JEEP CLUB MEMBER #55
SOLIDJP44 is offline
post #2 of 32 Old 09-22-2008, 02:06 PM
Xlr8n
1986 TJ Wrangler
You won't lose any 'horsepower' when going to a larger diameter tire, however your engine will have to work harder to turn the bigger tires, making it seem less powerful. A narrower tire will get better gas milage than a wider tire due to the narrower tire having less rolling resistance, but the biggest variable relating to power/acceleration is tire diameter.
Xlr8n is offline
post #3 of 32 Old 09-22-2008, 02:08 PM
newbs
Jeepaholic
My girlfriend likes her 33x9.5's replaced her 33x12.5's and her mpg went up.
newbs is offline
post #4 of 32 Old 09-22-2008, 02:18 PM
IslandTJ
Pizza cutters are starting to gain in popularity. I run 33x10.5 BFG MTs and am very happy with the performance thus far. Here's how they look:
Now Jeeping in Oregon
IslandTJ is offline
post #5 of 32 Old 09-22-2008, 02:32 PM
Zoom By You
Zoom By You's Avatar
I think 33 X 9.5 will look fine but if you don't wheel-it much and it seems as though MPG is a concern, why even consider a larger diameter tire? I would think your MPG would suffer because your gearing would be less than optimal....
2001 TJ Sport Amber Fire, Dual Tops/Dual Doors, 4.0, Banks Ram-Air, Banks S.S. Monster exhaust, five speed, NV3550, A.A. SYE/Tom Woods, 4:56 D30/D35, Detroit Truetrac at both ends, Solid diff covers, 4.5 R.E. Super Flex W/3.5 springs, adjustable upper and lower control arms, adjustable front and rear R.E. track bars, TeraFlex shock relocation brackets, R.E. Mono tube shocks, R.E. front stabilizer, R.E. 3/4" front spacer, 33 X 12.5 TrXus STS, M/T Classic-locks, ShrockWorks Rock Rails, Hanson 52" front bumper, EPi9.0 Superwinch with wireless control, Olympic rear bumper, Olympic Mountaineer rack, Bushwacker 6" Pocket Flares, Optima yellow top, IPF headlights W/ Fatboys, upgraded relay/wiring harness, KC Slims, Bosch rear lights, Garmin c550 GPS, Garmin 76S GPS, Cobra CB 148GTL W/Astatic Mic, Pioneer Sound, 3A Racing fire extinguishers. Manhattan Rated....
Zoom By You is offline
post #6 of 32 Old 09-22-2008, 02:42 PM Thread Starter
SOLIDJP44
any other suggestions my biggest reason for going taller is for looks, i know that seems terrible but i want to stay narrow
post #7 of 32 Old 09-22-2008, 06:01 PM
cheapjeep06
Try it. From side will look like any other 33" of different width (for looks). May need bumpstop spacers too keep from rubbing if disco'd. Check out the pics thread, might be a pic of 33x 9.50's.
Rustys blows big, fat camel nuts.
cheapjeep06 is offline
post #8 of 32 Old 09-22-2008, 06:04 PM
Speed911
I don't think bfg makes any 33 x 9.5's anymore. Justt 10.50's right?
-Dane
Speed911 is offline
post #9 of 32 Old 09-22-2008, 06:22 PM
PSYCH0
PSYCH0's Avatar
2009 JK Wrangler
Currently running 31x10.50's
Will 33x10.50's work on a TJ with 8" wheels with 4.5" without rubbing the flares (don't disco)?
Running 3.09 gears with a 6 Speed Manual Tranny so gearing may be an issue...
2009 Jeep Wrangler JK, 2-Door, Soft Top, Automatic, Black Procomp Aluminum Wheels with 315x75R16 Goodyear Wrangler Duratracs, 2" Black Diamond Lift, JKS Adjustable Track Bars, Smittybilt Rock Rails
PSYCH0 is offline
post #10 of 32 Old 09-22-2008, 06:23 PM Thread Starter
SOLIDJP44
i think yur right just a 10.5, im might consider those how does yours with 12.5 handle and mpg????
post #11 of 32 Old 09-22-2008, 06:27 PM
newbs
Jeepaholic
um nope they make a 33x9.5r15 in an at but not mt currently.
newbs is offline
post #12 of 32 Old 09-22-2008, 06:34 PM
IslandTJ
You are correct
IslandTJ is offline
post #13 of 32 Old 09-22-2008, 06:49 PM
rubidriver
the only horsepower that counts is rear wheel horsepower. with the 33s he will be loosing rwh and rwtorque. he will see mpg drops as well as power loss
2005 Black Rubicon - OME 933/942 - 4" Bilstein 5100 (canister up) - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline
post #14 of 32 Old 09-22-2008, 07:59 PM
buddy
Just a guess, but I think that manual's in 06 had 3.73 gears. So probably not as bad as you might think.
Later,
Buddy
Henderson, NV
- Needs Time, Place, Help & Parts!!
1997 TJ DD - RIP - hit n run victim
2003 Discovery SE7 - Wife's
buddy is offline
post #15 of 32 Old 09-22-2008, 08:57 PM
Nazdreg
Nazdreg's Avatar
I 100% agree that the only thing that counts is the power that hits the asphalt (dirt in our world) but I also agree with Xlr8n your Jeep isn't loosing any horsepower.
This is how I see it, and if I am missing something please chime in.
Let's disregard the weight, rolling- and wind-resistance of a larger wheel for now, the larger wheel will act just as a higher overall gearing, like starting your Jeep in 2.nd instead of 1.st - it takes longer time since 2.nd puts the engine outside the powerband at low speeds, where 1.st over revs the engine at higher speeds...... my point is that the gears has their strength at a different speeds.
So when driving 65 down the freeway in 5.th with a stock vehicle, the engineers designed the overall gearing so the engine was at the optimal rpm at this speed with the stock tires.
Once you change the overall gearing with larger tires you more or less take the engine out of that powerband, and you'll find yourself dropping into 4.th more often to get back into the power to get more torque onto the road.
So to put the engine back in it's powerband you need to change the overall gearing. I went from 30" tires to 33" tires (an approx. 10% increase in circumference), I think the engine rpm dropped about 10% at same speed. The differential gearing I have is 1:3.73 and if/when I re-gear to counter the 10 % increase in overall gearing by the larger tire, I should mathematically go with a 10% lower gearing such as the 1:4.1 gear and should pretty much put the engine rpms back to where they were before the larger tires.
Yes ? No ?
Nazdreg is offline
33X9.5 w/2" BB? or need a BL too? spokanistan TJ Wrangler Technical Forum 13 09-26-2008 09:59 PM
How to go from 33x9.5 to 33x10.5 MaineYJ YJ Wrangler Technical Forum 12 01-20-2006 12:04 PM
33x9.50 on a TJ JeepN2 TJ Wrangler Technical Forum 21 06-09-2004 06:46 AM
Goodrich 33x10.50R15/C kaybone TJ Wrangler Technical Forum 7 06-27-2003 10:39 PM
