33x12.50's on Canyons..........Wheel Spacers? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 33x12.50's on Canyons..........Wheel Spacers?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFather's Day & Moving Day Sale!Engo winch sale-- Best deal you will find. and FREE SHIPPI
Unread 05-14-2007, 11:04 AM   #1
VaLoRiaN
I will soon be putting 33x12.50's on my Sahara's stock Canyons and I was wondering what size wheel spacer do I need? I've talked to a few people and I'm pretty sure the 1.25" Spidertrax are the way I will be going but I see there are ones from 1" to 2" and I just wanted to make sure I was making the right choice. Any advice would be greatly appreciated. Thanks!
VaLoRiaN is offline   Reply With Quote
Unread 05-14-2007, 11:06 AM   #2
Rocky529
Jeep
Rocky529's Avatar
Spidertrax 1.25" wheel spacers are ideal.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Unread 05-14-2007, 11:16 AM   #3
silverjeep
what about spacers 32 x 11.5 on stock canyons???
silverjeep is offline   Reply With Quote
Unread 05-14-2007, 11:17 AM   #4
Rocky529
Jeep
Rocky529's Avatar
Same thing. Spidertrax 1.25" are recommended.
Unread 05-14-2007, 11:20 AM   #5
VaLoRiaN
So the size of the tire makes no difference at all? In what case would I use 1" or 2" Spacers?
Unread 05-14-2007, 11:21 AM   #6
Rocky529
Jeep
Rocky529's Avatar
1.25" spacers will work with 11.5" tires and 12.5" tires.
Unread 05-14-2007, 11:22 AM   #7
jzmtl
You will need to cut the front stock studs shorter if you use 1" spacer.
jzmtl is offline   Reply With Quote
Unread 05-14-2007, 11:31 AM   #8
VaLoRiaN
What if I went with 1.5", 1.75", or 2" Spacers? I'm going to get the Spidertrax but I'm just wanting to learn about these because I don't quite understand all of this right now. Thanks!
Unread 05-14-2007, 11:38 AM   #9
Bhelliom
If you go with wider spacers your tires will stick out more. Could be an issue if you have laws concerning tire coverage.. Ie you may have to get new fender flares to be legal.
Basically for every TWO inches wider your tire is over 10.5 you need an additional 1 inch spaced out.
so... 11.5 you technically only need a .5 inch spacer. 12.5 you only need a 1 inch spacer. 14.5 you need a two inch spacer etc. (with stock wheels at 5.5 inches of bs)
It's basically compensating for your wheel backspacing.
Adding a 1.25 spacer will take your 5.5 inches of backspacing in your canyons and basically make it 4.25 inches. Which is enough for 12.5 tires.
[COLOR="DarkRed"]Old Guy Jeep Club #1026[/COLOR]
[COLOR="Red"]Canadian[/COLOR] [COLOR="White"]Jeep[/COLOR] [COLOR="Red"]Club[/COLOR] [COLOR="White"]Member[/COLOR][COLOR="Red"]#1026[/COLOR]
[QUOTE=schitzangiggles] But since you are barely able to vote, are younger than some of my socks and as inteligent as the fecal droppings from a retarded Chimpanzee you go right ahead and keep on keepin on. [/QUOTE] - Posted in response to a moron wheeling illegally.
Bhelliom is offline   Reply With Quote
Unread 05-17-2007, 05:30 PM   #10
VaLoRiaN
Thanks a ton I really appreciate the help. You said 1.25" would be enough for 12.5's but is it the best to get for 12.5's or would 1.5" be better? Just making sure before I click that "submit order" button. Thanks!
[COLOR="Black"][B][CENTER][FONT="Arial Black"][SIZE="3"]2003 Jeep Wrangler Sahara[/SIZE][/FONT][/CENTER][/B][/COLOR] [CENTER][COLOR="Wheat"][B][FONT="Arial"][SIZE="2"] Khaki [/SIZE][/FONT][/B][/COLOR] with [B][FONT="Arial Black"][SIZE="2"][COLOR="Sienna"]Brown Soft-Top[/COLOR][/SIZE][/FONT][/B][/CENTER]
[B][FONT="Arial Black"][SIZE="1"]4.0L I-6, 5 Speed, D30/D44 with 3.73 Gears, 33x12.50x15 BFG All-Terrains on Canyons, ARB Bull Bar with Warn x9000i Winch & Fog Lights, T-Case, Oil Pan, and Gas Tank Skids, Fully 7-Speaker Upgraded Sound System with Amp & Clarion 6 CD Changer and Rock Shifter Knob :), Soon to Come: ARB Rear Tire Carrier, Shrockworks Rocker Guards, Pioneer DVD/CD Receiver, 2.25" Suspension Lift, 1" PA BL, 1" JKS BMML, 1.25" Spidertrax Wheel Spacers, and MORE! [/SIZE][/FONT][/B]
Unread 05-17-2007, 06:19 PM   #11
otisdog
The 1.25's will work great for you. Spidertrax are the best.
You don't want to go out any farther because of the stress it can put on wheel bearings etc and also on the spacers themselves. This is why the 1.25's are perfect - they are just thick enough to clear the wheel studs and give your tires clearance but not so thick as to cause undo stress and other safety concerns.
Jim
03 Sport
otisdog is offline   Reply With Quote
Unread 05-17-2007, 06:28 PM   #12
jmreagan
I have spidertrax 1.25 inch spacers on stock canyons with 33x12.50's and I love the stance and the spacing in mho is perfect. Trust me you will enjoy the combo of the wheels, spacers and tire width!
03' Sport, 4.0L, 3.73, 5 speed, D44/D30, 3 inch coil/shock lift, RE track bar, Tera disco's, 35x12.50's Dunlap Mud Rovers MT's, Spidertrax spacers, Viper 5000 alarm, Tuffy console, LOD extreme bumper/tire carrier and front bumper, A-Z rockers, AA SYE, Tom Woods DS, JKS Rear UCA's.
Originally Posted by KKiowaTJ
Sorry master, Dont whips me, I's do betta next time..
jmreagan is offline   Reply With Quote
Unread 05-17-2007, 06:37 PM   #13
txboy72
any suggestions if ill need any spacers with the 3'' full traction economy and 33x12.5 MT baja claws on the 15x8 MT classic lock?
txboy72 is offline   Reply With Quote
Unread 05-17-2007, 06:40 PM   #14
Rocky529
Jeep
Rocky529's Avatar
What is the backspacing on the wheels?
Unread 05-17-2007, 07:45 PM   #15
Bhelliom
If i remember correctly the MT classic locks are 3.75-4 inches BS shouldn't need spacers at all.. but i'll double check
Edit 3 5/16 no spacer needed
