33x12.50 - What PSI do you run?? - JeepForum.com
post #1 of 22 Old 10-01-2007, 03:48 PM Thread Starter
bman9089
bman9089's Avatar
Afternoon guys,
I'm wanting to get some advice on PSI to run in the tires. I think I'm sitting at about 33 right now, but want to have the best wear/ride quality possible.
So, what do you think is the best?? What's your PSI on road?
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline
post #2 of 22 Old 10-01-2007, 03:52 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
If you have 8" wide wheels, 24-28 psi will typically get you the most even tread wear.
Wheelin98TJ is offline
post #3 of 22 Old 10-01-2007, 03:56 PM
McLovin
Originally Posted by bman9089
Afternoon guys,
Alot will depend on the wieght of your rig, sounds pretty much stock wieght. Then it will depend on the width of your wheels 15x8's or 15x10's. Also depends on how big of hit you wanna tak ein the gas mileage dept.
I'd drop them down to about 25 and see how you like it. 33 is really high.
McLovin is offline
post #4 of 22 Old 10-01-2007, 03:57 PM
silverjeep
I had to reaserch the same thing when I went to 33's. I came to the conclusion that 25-26 is good. You can also do a chalk test.
Jeep parts and accessories
silverjeep is offline
post #5 of 22 Old 10-01-2007, 05:18 PM
95BadBoy
bman9089
Played with this a little while, finally found 28# worked well for me running the same tires as you. Rolling resistence was less at higher PSI, but looked like it was going to produce a poor tire wear pattern (bad center wear). Too low and it handled for crap on the street (much like driving on marshmellows).
95BadBoy is offline
post #6 of 22 Old 10-01-2007, 05:30 PM
BlackJeephunter
28PSI, ditto on what the others have said. A bit lower if it snows, which it never does around here.
Palmetto Tree Stickered Black Jeep Owners Club, Hunting Chapter Member #1110010
BlackJeephunter is offline
post #7 of 22 Old 10-01-2007, 05:43 PM
solarpower
Chalk test works best for all tires if you want to extend tire life. Too many factors involved to decide what is best for what your rig weighs, load range, MPG vs ride, weather, tire brand/compound blah blah...
but yeah 28 is a good starting point, and tracking your tire wear and checking PSI often will tell you what is ideal for your particular condition.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #8 of 22 Old 10-02-2007, 02:03 PM Thread Starter
bman9089
bman9089's Avatar
Sounds like mine is sitting a little bit high. I'll air 'em down a bit this afternoon then.
Thanks!
bman9089 is offline
post #9 of 22 Old 10-02-2007, 02:15 PM
Jonny Jeep
Jonny Jeep's Avatar
Varies by tire manufacturer too. Depends what the maximum load and pressure of the tyre is. 18 psi is right for my rig on 33 x 12.5 MTRs. Did the maths first and then the chalk test. 20 psi lifted the outside edges of the tread off the road, with no contact till an inch from the edge.
Jonny Jeep is offline
post #10 of 22 Old 10-02-2007, 02:18 PM
Tinker
Tinker's Avatar
trXus on 8" wheel TJ SE pretty well loaded. 24psi in the front and rear unless I have the hardtop on then its 26psi in the rears
"Does this look broken to you?"
Tinker is offline
post #11 of 22 Old 10-02-2007, 02:23 PM Thread Starter
bman9089
bman9089's Avatar
Where can I find manufacturer recommended PSI ratings??
bman9089 is offline
post #12 of 22 Old 10-02-2007, 02:31 PM
Wheelin98TJ
JEEP FREAK
The manufacturer will state the max load rating at a certain PSI right on the sidewall of the tire, for example 3,000 lbs at 50 psi.
So 3,000 lbs x 4 tires = 12,000 lbs total weight carrying capacity of all 4 tires.
A TJ weighs about 4,000 lbs (1/3 of the total 12,000 lb capacity of the tires), so you would inflate the tires to approximately 1/3 of the max psi.
post #13 of 22 Old 10-02-2007, 04:01 PM
brianw7
What's a 'chalk' test? Would you reccomend the same psi for 33 x 10.5's?
brianw7 is offline
post #14 of 22 Old 10-02-2007, 06:59 PM
BoKnows
BoKnows's Avatar
28 in mine
1997 TJ White
3speed auto, RE Long Arm with ACOS...5" of lift, 35x12.50 PC XAT on 15x8 wheels, Bilstein 5100 shocks, rubicon D44 with front and rear ARBs, AA SYE, Coast CV Driveshaft, 4.10 gearing, ORO Swayloc, ARB Snorkel and K&N filter, magnaflow exhaust, Fabtech front bumper, LoD Xpedition Rear bumper, LoD Rocker Guards, hella lights, 6" Xenon flares, HULA GIRL on dash...........she makes me smile
BoKnows is offline
post #15 of 22 Old 10-02-2007, 10:05 PM Thread Starter
bman9089
bman9089's Avatar
This afternoon I checked and found out that I had 35psi in every tire!
Good thing I haven't driven but around 1000 miles on my set of tires. I've taken them down to 28 PSI and the on road ride is noticeable better. It makes a huge difference (so much softer!), and makes my OME set up even better!
Thanks guys for the heads up! Much appreciated!
bman9089 is offline
2.5L with 4.11 and 33x12.5? iceman123187 TJ Wrangler Technical Forum 21 04-14-2008 06:26 AM
33x12.5's fit? wessy YJ Wrangler Technical Forum 5 04-22-2007 09:24 PM
33x12.50 JeepPirate TJ Wrangler Technical Forum 3 11-15-2006 11:28 PM
33x12.5? Max1775 TJ Wrangler Technical Forum 3 03-28-2006 01:59 AM
33x12.50 on a 7 '' rim blevinsbulldog YJ Wrangler Technical Forum 12 09-25-2005 09:10 PM
