33x12.5 VS 33x10.5 & true 2 in. BB puck
| Rock Krawler Suspension's for BLOW OUT prices!!! | Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com |
#1 | |
I've searched but can't find info about the BB pucks. I remember reading certain brands are 1.75 with others being 2.25...anybody know the brand names?
Opinions on the 33x10.5 tire size?? pics anybody? No specific brand in mind yet--recommendations? FYI: 3.07 gears, d30 & d35 axles, w/ 3spd auto) I'm wanting to run my stock Canyon rims with out spacers( heard some horror stories about the spacers). wheeling plans: dd with trail riding once/twice a month.
#2 |
my build/timeline thread http://www.jeepforum.com/forum/f22/re-8-la-36-iroks-341619/ |
#3 | |
[SIZE="4"][CENTER] [B]_____ [U]l JEEP l[/U] [U]OllllllllO[/U][/B] [SIZE="1"]2006 Unlimited[/SIZE][/CENTER][/SIZE] [center][B]Black Jeep Club V2.0 Member #2006 [URL="http://groups.jeepforum.com/LJ_Owners"]LJ Owners, join the group and click here.[/URL][/B][/center] |
#4 |
Thanks to you both for the info and the pics!
#5 | |
Now in the 937
![]() ![]() The goodies are in my sig along w/ a link to my build-up... more pics in there With 3.07s, you'll be wanting as little rotating weight as possible, so going for a lightish weight 33x10.50 will probably be your best bet. If you play in mud skinny tires work better as they dig down for the traction instead of float on top and spin for nothing. I'll also recommend a body lift in the future so you can get more flex from your suspension. I decided to just do a 3" lift the first time and get a BL if I needed it or for more clearance down the road. I'm good as it is
The lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase Build thread here. Quote:
Pictures of it wheeling at Bill's 491 And more pics from that trip here! |
#6 | |
#7 |
I had 33 x10.50's on stock 7" wide steel wheels for years with no problems.
Recently I put a set of Gamblers on with the same tires. The Gamblers have a little more backspacing than the steel wheels. They were too close to the upper rear spring perchs for my liking so I added spacers. Jim
03 Sport |
#8 | |
But it's easily taken care of with minimal washers behind the steering stops. I'm running 33x10.5" on stock 5.5" bs Grizzley wheels and had some rubbing on the LCA which I cured with steering stop washers. The left rear tire may be too close to the rear spring perch, but that's a function of the lift offsetting the axle to the right. This is easily corrected with a rear trackbar relocation bracket. My left rear 33x10.5 was too close because of my 3" lift, but is now spaced out evenly with an OME bracket. Didn't have to trim the perch.
2000 2.5 TJ, 5spd, 33s, 8274 |
#9 |
I'm running 33x12.50s on stock wheels with a 1.5" spacer on each wheel. 3" lit. No rubbing at all.
That being said.. I'd probably go with a 10.50 next time for the sake of reducing the weight to gain a hair of acceleration and they will probably track a little better since they'll fit the wheel better. |
#10 |
33x10.5" BFG AT T/A KO's -- check sidebar for lift info
Formally JeepinTJ99 ... Go Anywhere: 2012 "Crush" Clearcoat JK Rubicon, loaded to the hilt || Thread Carve Time: 2009 "Racing Red" Buell 1125CR — 150 RWHP Will be missed: 1999 "Deep Amethyst" Pearlcoat TJ +3" on 33's |
#11 |
heres mine as stated above..
#12 |
When you take into account the cost and performance of a 2" budget Boost and some 33x10.5's it turns out to be a pretty good mod. I did this back in 2002 with my first TJ. A couple of things I recomend. The teraflex budget boost comes with front and rear extended bump stops. You'll need them. I also recomend either a .5" 2nd spacer for the front or another rubber stock spring isolater for the front. That should sit the Jeep up level. I think the wheels I had back then were called ecco's they were a 5 spoke aluminum gray in color. I needed one washer under the steering stops to prevent rubbing.
In the rear the BB shifts the axle to one side just enough to cause concern about the tire hitting the upper coil bucket on one side. You can either add a rear track bar bracket to center the axle, buy an adjustable rear track bar. Or simply grind off the portion of the bucket thats close to the tire. I remember my first run with that set-up and 33x10.5 TSL radials. There was one other jeep there that had 33x12.5 SSR's and like 5" of lift. I remember him having to winch uo a couple of hills that I had been able to climb.
http://jeep4playoffroad.org/index.php --your local oregon coast club |
#13 | |
nice jeep omg... i've got black steelies on my 03 and i was thinking about putting the orig rims back on with 32x11.5's. wheel spacers are going on as well. to the point: those are the exact rims i have and i've been wondering what they would look like. to the original poster: i've got the 4wheelcustoms bb of 2.25. no rubbing at all for me. then again, i'm running 32's and 3.75bs. good luck with whatever you decide... |
#14 |
i got my 2.25 inch spares and RE monotube shocks from 4wheelcustoms. the spacers were here in a few days but the shocks took longer to get here. the kit was pretty easy to install but a few bolts for the upper shock mounts broke off so that was an annoyance. sorry i can't help you with the tires i'm staying with my 31x10.50's for a while (just got um a month ago). good luck.
also omgsideburns great looking pics...nice jeep! |
#15 |
I went with the 33-12.50s. Happy so far.
98 TJ Sport: 2" Skyjacker spacers w/Rubicon coils, Rancho RSX shocks, 33-12.50 BFG MT on 15X8 Mickey Thompson Classic Locks, Borla header, Flowmaster Mufler, Pioneer sound W/12" RF P3 sub and MTX amp 06 Nissan Frontier NISMO CC 4X4: 2.5" lift with Rancho RS9000X shocks, 285/75-16 BFG ATs, Alpine sound Mdawg's 98TJ @ Cardomain, http://www.mississippi-mud.com/forums/index.php? |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
