33x12.5? - JeepForum.com
post #1 of 4 Old 03-27-2006, 08:06 PM Thread Starter
Max1775
Max1775's Avatar
33x12.5?
Okay, threw a 2"BB on my 05 Rubi this weekend, and figured I'd end up putting 32x11.5 tires on a 15x8 rim. After getting it on there though, it looked like it would have no problem fitting 33's. Stock tires were 31's. Anyone running 33x12.5 on a 15x10 with maybe a 3-4" backspacing without adding a 1" bl? I know the Rubicon sits a little taller, so I would think it's possible. Don't want to go with a big lift (not as young and spry as I once was, lol).
05' Rubicon Unlimited, 33" BFG M/T's
SAW 'EM OFF!
Max1775 is offline
post #2 of 4 Old 03-27-2006, 09:28 PM
hauganater2315
with just a BB i would go with the 32's, I run 33x12.50's with a 3" lift and at flex i get a little rub on the flares
2001 4.0L TJ
33"x 12.5" BFG Mud Terrains
BELTWAY JEEPERS
hauganater2315 is offline
post #3 of 4 Old 03-28-2006, 01:54 AM
drottie
I run 33 12.50 15's on my rig with out rub. I'm running a BB and using the same coils as you have, plus a 1"BL
1999 Jeep TJ .....pretty far gone from stock
drottie is offline
post #4 of 4 Old 03-28-2006, 01:59 AM
NEWtoTHEjeepLIF
Its not like you need flares...
NEWtoTHEjeepLIF is offline
2.5L with 4.11 and 33x12.5? iceman123187 TJ Wrangler Technical Forum 21 04-14-2008 06:26 AM
33x12.50 - What PSI do you run?? bman9089 TJ Wrangler Technical Forum 21 10-03-2007 06:25 PM
33x12.5's fit? wessy YJ Wrangler Technical Forum 5 04-22-2007 09:24 PM
33x12.50 JeepPirate TJ Wrangler Technical Forum 3 11-15-2006 11:28 PM
33x12.50 on a 7 '' rim blevinsbulldog YJ Wrangler Technical Forum 12 09-25-2005 09:10 PM
