33's on stock rims, enough backspacing? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 33's on stock rims, enough backspacing?
KrawlOff-Road.com Sale EventFS: Jeep Fog Light LED Bulbs! Several Brightness Options! *STOP UNWANTED LIGHT BAR NOISE* with Pandemic LED Light Ba
Unread 07-11-2011, 11:22 PM   #1
97TJSPRT
If i run a 3 inch lift with 33s on stock rims, will they rub with the 5inch deep backspacing? if so how bad, will it rub at full turn? thanks
*******q[ _\ _\_ ]p********
******._(|||||||)_.******
******III"""""'''''""""'"'III******
Zombie Outbreak Response Unit #279
97TJSPRT is offline   Reply With Quote Quick reply to this message
Unread 07-11-2011, 11:25 PM   #2
Clem
I've seen 33x9.5's on stock rims. Looked good without any rub. 33x12'...not so much.
Clem is offline   Reply With Quote Quick reply to this message
Unread 07-11-2011, 11:51 PM   #3
Jerry Bransford
Administrator
Jerry Bransford's Avatar
33x12.50 tires will rub the inside sidewalls with factory wheels. You'll have to find a 33x9.50 or 33x10.50 if you want to mount them on the stock wheels without installing wheel spacers.
Getting Savvy...
Jerry Bransford is online now   Reply With Quote Quick reply to this message
Unread 07-12-2011, 12:15 AM   #4
97TJSPRT
my friend gave me a set of BFG MTR-KM for free but theyre 33x12.50, how much will they rub? how much backspacing would be needed to avoid rubbing?
Unread 07-12-2011, 12:41 AM   #5
99_TJ_Wyoming
I just put on 33x12.5 on a 3.25" lift on soft 8s with 4" backspacing and yes, they rub -
I just put 1.5" spacers on and no more rub, looking at wheels you will probably be stuck with 2.5" bs, 3.75" bs wont be enough. With the spacers theres no rubbing at all, but they do still hit the fenders unless you change your bump stops.
99_TJ_Wyoming is offline   Reply With Quote Quick reply to this message
Unread 07-12-2011, 01:00 AM   #6
97TJSPRT
yeh i think im gunna get the bushwacker flat style fender flares so thats an extra 2.5 inches of clearence so that should do the trick for the fender rub.
Unread 07-12-2011, 07:16 AM   #7
biffgnar
biffgnar's Avatar
I run 33x12.5 on wheels with 3.75" backspacing and I don't believe I have any rubbing issues at all.
Thank you Dave Cole, Dynomax, Falken and all the Spec Class sponsors!!
biffgnar is offline   Reply With Quote Quick reply to this message
Unread 07-12-2011, 07:24 AM   #8
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
1. fender flares don't increase your tire clearance. do some research on bumpstop extensions.
2. your 2" lift alone isn't enough for 33s. do some research on bumpstop extensions.
3. 33x12.50R15 on stock rims w/o wheel spacers will not only rub the control arms in front, but the sidewalls will rub the rear spring perch and you won't make it far before the tire is cut apart.
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 07-12-2011, 09:35 AM   #9
Jerry Bransford
Administrator
X2 on the above and you don't want more backspacing, you want less. Your factory wheels have around 5.25" to 5.5" of backspacing which is too much for a 12.5" wide tire. You need a wheel with between 3.75" and 4.5" of backspacing.
Getting Savvy...
Unread 07-12-2011, 09:53 AM   #10
TheBoogieman
Congrats DENVER BRONCOS!
TheBoogieman's Avatar
WRONG!
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 07-12-2011, 09:57 AM   #11
element54
I have 33x10.5x15 BFG All Terrain with my stock steel rims and they don't rub.
Why is there so much space down here?
element54 is offline   Reply With Quote Quick reply to this message
Unread 07-12-2011, 10:15 AM   #12
KevinR
1983 CJ7
LJ, 2 in BDS suspension lift (with appropriate bumpstop extensions), running 33x10.5 BFG All Terrains on stock wheels. Front tires contact the control arms at full turn. In the rear, there is about a fingers width of clearance (.5 in. give or take some) between the tire and the coil perch. For the street, I'm comfortable with this set up, I'm just conscious of the issue when parking (avoiding excessive amounts of tight maneuvers). I'm thinking that I will adding 1.25" spacers to give me a little bit more clearance and peace of mind.
KevinR is offline   Reply With Quote Quick reply to this message
Unread 07-12-2011, 06:36 PM   #13
motojunkie
4" lift with 33x10.50's on Canyon wheels. I get some rubbing at full lock, but otherwise they are fine.
03 TJ sport, 4" Procomp lift running 33x10.50 BFG KM2's--09 dodge 6.7 cummins QC/SB 3500--08 Yamaha Nytro with a Boondocker Turbo
Air Force Jeep Club member #92
motojunkie is offline   Reply With Quote Quick reply to this message
Unread 07-12-2011, 09:59 PM   #14
dlysle
'06 LJ, V8 ZJ springs in front(2.25" lift) and 1.75" spacers in back, 33x12.50 on the stock ravine rims with 1.25" wheel spacers. as long as the swaybar is hooked up i get no rubbing at all.
'You may not realize it when it happens, but a kick in the teeth may be the best thing in the world for you.' - Walt Disney, Animator, Film Producer
'four wheel drive only allows you to get stuck in more inaccessible places' - George Noll
dlysle is offline   Reply With Quote Quick reply to this message
Unread 07-12-2011, 11:24 PM   #15
99_TJ_Wyoming
WRONG!
Dont just say "wrong" back it up, tell us why its wrong, give us the benefit of your wisdom instead of your judgement.
I know what I have, and I know what doesnt work because I have done it. If you have had a different experiance, tell us about it, tell us what size tires you had, tell us what backspacing you had, tell us what lift you had, tell us how it worked or didnt.
Just saying "wrong" is a waste of your time and ours boggieman, but it helps your post count, so, I guess it works for you (lazy though).
backspace , backspacing , backspacing measurement , rim , rims
