33's no lift, tube fenders? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 33's no lift, tube fenders?
ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO 8.8 Swap Kit w/ TRUSS for JeepsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 07-12-2010, 10:37 AM   #1
witness
Is it possible?
I got a 2001 Sahara, and I really like the idea of running stock suspension.
I'd rather have tube fenders than a suspension lift. Has anyone done this? Any draw backs to running stock suspension and 33's?
witness is offline   Reply With Quote Quick reply to this message
Unread 07-12-2010, 10:42 AM   #2
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
damn right its possible. -sean- on this forum runs 35s at roughly stock height (well...for the most part...his rig is highly modified).
but based on the educated folks i've talked to running the stock springs with big tires, they're a little disappointed in the uptravel and downtravel. with shock mount relocation and long travel shocks, the stock springs unseat because they aren't long enough uncompressed, and with stock shocks they just don't flex a ton.
if you just want to fit 33s on completely stock suspension, then slap on a set of highline fenders (DIY, Rokmen, Gen-Right, AEV, TnT Customs, etc), hack up the rear with a sawzall and you're done.
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 07-12-2010, 10:48 AM   #3
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
No Lift 1998 Jeep Wrangler TJ 35 Inch Tires Fitting - Jp Magazine
TheBoogieman is online now   Reply With Quote Quick reply to this message
Unread 07-12-2010, 11:19 AM   #4
witness
Would tube fenders up front and flares in the rear be ok? Our would I have to take a saw to my rear quarter panel? I'd like to keep as much of the stock sahara look as possible. I know tube fenders are as far from stock look as possible but you get the idea. I'd really like for it to be a sleeper that I can drive everyday
Unread 07-12-2010, 11:27 AM   #5
DevilDogDoc
Location: Yucca Valley 20 miles from Johnson Valley, CA
The front will be ok you will rub a little but the back will rub every bump you hit I did that with my 285's roughly 33 11 or hits in the front of the rear wheel well ...
An ugly Jeep with some stuff.
DevilDogDoc is offline   Reply With Quote Quick reply to this message
Unread 07-12-2010, 11:48 AM   #6
Unlimited04
yes you need to cut the rear, and not the flares - the steel body. you can keep the stock flares. lots of people DIY highline their rigs and reuse the stock flares.
KWIT YNIN, git ta cuttin.. stuffin 37's under 2.5" lift. - JeepForum.com
otherwise you would need to add 2" of bumpstop to your rear axle to keep the tires out of the fenders (again, not the flares, the steel body), which would basically eliminate the uptravel you have now, making the Jeep ride like a go kart.
http://www.jeepforum.com/forum/f9/bu...points-734737/
Unread 07-12-2010, 11:57 AM   #7
witness
Would a small body lift solve rubbing problems in the rear? Maybe a smaller tire would work out better
Unread 07-12-2010, 12:05 PM   #8
Unlimited04
a 1.25" BL will just barely clear 32s (given proper backspacing). works really good with 31s.
Unread 07-12-2010, 12:14 PM   #9
witness
I really wanted to avoid a suspension lift but maybe a small one might be in order
Unread 07-13-2010, 03:21 PM   #10
tjallday
go bb, cheap, easy
tjallday is offline   Reply With Quote Quick reply to this message
tj , wrangler , tube , fenders , 33 , suspension , stock
