33s, how much lift? - JeepForum.com
post #1 of 28 Old 10-14-2004, 10:05 AM Thread Starter
Hanzo
33s, how much lift?
I know it's probably been covered a thousand times, but I did a search and with these two things, I pulled up every post ever made.
So, quick, easy question.
The OME deluxe kit with the 2.5 sus lift and 1.x BL...will it fit 33s disco'd at full articulation?
Hanzo is offline
post #2 of 28 Old 10-14-2004, 10:07 AM
red99tj
red99tj's Avatar
3 inces for 33x10.50s
4 inches for a wider tire
Frank
red99tj is offline
post #3 of 28 Old 10-14-2004, 11:19 AM
BigJeepJay
BigJeepJay's Avatar
No, you will rub a bit.
Pics...
TJ Stretch Thread...
BigJeepJay is offline
post #4 of 28 Old 10-14-2004, 11:22 AM Thread Starter
Hanzo
Thank you Jeep Jay.
Hanzo is offline
post #5 of 28 Old 10-14-2004, 11:38 AM
GzrGlide
GzrGlide's Avatar
You'll be fine! We've got 3 inches with 33x10.5s! No issues yet.
Mike
<<< ya know ya want to!
98 TJ SE
RE 4.5SF with 3.5 springs & Tera QDFTs
Super 35 & Detroit in back w/4.88s
33x10.5 BFG KM2's
Cobra 75WXST w/4' Wilson Antenna
Warn M8000
(1) Rubber Ducky
GzrGlide is offline
post #6 of 28 Old 10-14-2004, 11:43 AM
BigJeepJay
BigJeepJay's Avatar
right you have 3 inches of lift but Hanzo is talking about a 2.5 kit from OME. THat 2.5 kit will rub with 33's at full articulation.
Pics...
post #7 of 28 Old 10-14-2004, 11:53 AM
red99tj
red99tj's Avatar
yea but with a 1 inch body hell be fine
Frank
red99tj is offline
post #8 of 28 Old 10-14-2004, 12:01 PM
bam9382
OME is that the same as OEM ... i know that jeep puts a 2.5 lift on some of their jeeps to sale it with 33s on it.... how do you buy that lift were is it ? how much ? is it the same as the OME one you are talking about?
bam9382 is offline
post #9 of 28 Old 10-14-2004, 12:36 PM Thread Starter
Hanzo
No, OME, Old Man Emu.
Hanzo is offline
post #10 of 28 Old 10-14-2004, 12:42 PM
DaveFL
DaveFL's Avatar
So 33x12.5 will rub with 3" of lift?
what about with RE SF 3.5? no body lift? 33x12.5? rub?
Sorry to Hijack
working on final lift decisions now and trying to garner info.
______________________________
03 Rubicon
Nth 6"LA lift, TT, Stinger/Slider Combo, Superwinch EPI9000, Durango Front & Rear, ORF Tire Carrier, Independent Locker Mod, 15x8 Crager Locks, 35" MT MTZ,Rock Hard Parts trail Cage, AEM Dry Flow, Viking Fastback Top.
DaveFL is offline
post #11 of 28 Old 10-14-2004, 02:02 PM
doorocks
doorocks's Avatar
33's with 3" of lift.....................I do barely touch the fenders when I'm flexed, but 4" would be nice.
LIFE IS TOUGH ENOUGH ALREADY, IT'S EVEN TOUGHER WHEN YOU'RE STUPID.
RE 3.5 and all kinds of other relevant goodies, you know winch and stuff.
Life is like walking into the No Chance Bar full of Future Darwin Stories........
More mods than a hillbilly's set of teeth..
doorocks is offline
post #12 of 28 Old 10-14-2004, 02:10 PM
FlexyTJ
FlexyTJ's Avatar
It depends totally on the kit. My 3" kit clears 33x12.50 no rub at all, discod, full stuff...
MK Motorsport & Fabrication
FlexyTJ is offline
post #13 of 28 Old 10-14-2004, 02:25 PM
BigJeepJay
BigJeepJay's Avatar
FlexyTj is completley correct. Each Lift kit will react differently. For example a RE 3.5 will typically produce 4.5 inches of lift when all is said and done. It depends on how the manufacturer measures the amount of lift their springs give...is it right out of the box or after X years of compression. Each case is different and that is why you need to just give it a try and see what happens.
Pics...
post #14 of 28 Old 10-14-2004, 02:29 PM Thread Starter
Hanzo
OK, well, not trying to be a jerk here, but since I can't afford to do this wrong, does anyone know if 33s will fit with the OME deluxe package?
Oh yeah, another question...I've been looking all over the place, does anyone know what kind of axles the 04SE has and will they hold up to 33s?
Hanzo is offline
post #15 of 28 Old 10-14-2004, 02:56 PM
BigJeepJay
BigJeepJay's Avatar
The 04 SE has a D30 in the front and an M35 in the rear. You can run 33's on them but it is highly advisable you upgrade to a Super 35 Rear axle if you are going to do any serious wheeling.
Also are you going to put in 4.56's or 4.88's?
Pics...
Newbie Lift ? - Body lift vs. suspension lift yj_ryn TJ Wrangler Technical Forum 25 10-09-2013 07:51 PM
FT 3" economy lift overkill? Help me decide on lift/tire combo. Black Hole TJ Wrangler Technical Forum 25 02-04-2013 06:46 AM
Finish my education on budget lift solutions, shackles and body lift for 31s 01TJfuntime YJ Wrangler Technical Forum 2 06-20-2009 06:32 PM
New Rough Country 2.5 Progressive rate Spring Lift and 1.25 Body Lift qf4phlyer JK Wrangler Technical Forum 7 11-24-2008 05:59 PM
2" Coil Spring lift, can body lift be added without ill effects ? Scuba Jeepster TJ Wrangler Technical Forum 2 02-22-2005 09:04 AM
