33" Swampers- do I need spacer? - JeepForum.com
post #1 of 16 Old 07-29-2010, 10:47 AM Thread Starter
losfreddy
Do you guys think 13.5 wide inch tires will rub on the front wheel steering? Just got 33" swampers for my 4 banger. At how wide is it necessary for a spacer?
99 TJ. 5 sp Manual. 4 cylinder. 2.5 liters. airaid intake.
Rock Guards. 32x11.50r15. 4 inch lift. nitro Shocks.
losfreddy is offline
post #2 of 16 Old 07-29-2010, 10:51 AM
zachbh
What rims will you be mounting them on?
zachbh is offline
post #3 of 16 Old 07-29-2010, 10:52 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
whats the wheel backspacing & width?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 16 Old 07-29-2010, 11:03 AM Thread Starter
losfreddy
They are 15" rims that I am mounting them on.
post #5 of 16 Old 07-29-2010, 11:09 AM
TheBoogieman
The Devil's Advocate
TheBoogieman's Avatar
15x10" I hope. Stock wheels need spacers with anything over 10.5" wide tires.
TheBoogieman is offline
post #6 of 16 Old 07-29-2010, 11:18 AM
mmarmouz
I have TSL LTB 33x13.5 r15 mounted on Black Rock Type Series 997 Type 8 15x8 and i have no problem at all ! Got a 4 banger too
mmarmouz is offline
post #7 of 16 Old 07-29-2010, 11:19 AM
Unlimited04
you still didnt answer the questions. backspacing? width?
Useful Write-Ups:
Funny:
post #8 of 16 Old 07-29-2010, 11:21 AM
TheBoogieman
The rules don't apply to Canadians.
post #9 of 16 Old 07-29-2010, 11:29 AM
mmarmouz
mmarmouz is offline
post #10 of 16 Old 07-29-2010, 12:24 PM
Elwood
Elwood's Avatar
2016 JK Wrangler
I run a set of 33x14.50x15 SSR's on 15x10 wheels with 4" of backspacing and only just barely rub my front lower control arm at full turn and full flex. I consider it a "non-issue" as it just puts a small rub spot on the paint and doesn't even rub the paint off. A few thousand miles more on the tires and they won't reach.
A quote from my wife: "I don't even want to know how much it cost, I'm not in the mood to be that pissed off today."
Elwood is offline
post #11 of 16 Old 07-30-2010, 12:15 PM Thread Starter
losfreddy
How do i tell? i think its whatever it is out of factory
Boogieman, my old tires were 32x 11.5 with no spacers.
post #12 of 16 Old 07-30-2010, 12:53 PM
Unlimited04
Did you try measuring them or looking at the size specs on the back?
13.5" wide tires will not fit on stock wheels. not just because of backspacing, but also because the wheel isn't wide enough.
you need new wheels with less backspacing. 15x10 with 3.5-3.75" backspacing should do it.
Useful Write-Ups:
Funny:
post #13 of 16 Old 07-30-2010, 01:40 PM
ElementX
you will need spacers with the factory wheels. Your tires will probably rub the spring perches in the rear, aside from the front tires rubbing on the control arms and loss of overall turning radius
$200 for wheel spacers or $300 for a set of 5 steel wheels with proper backspacing
In the past, I've had 35x13.5 MT baja claws (they only measured out to be a bit over 33") with 15x8 wheels that had 4" backspacing and I had to adjust the steering stops with 2 washers on each side. I currently have 33x12.5 swampers with 15x8 wheels with 4.5" backspacing and needed 2 washers on each side too.
'98 TJ Sport
ElementX is offline
post #14 of 16 Old 08-02-2010, 01:58 PM Thread Starter
losfreddy
Just found out that i have 4 inches of back spacing.. also, my rim is 15x8 i think. its by American Racing. Do i need another rim?
post #15 of 16 Old 08-03-2010, 01:23 AM
ElementX
They'll fit on 15x8 with 4" backspacing as I've done it before, but most will recommend that you use a 10" wide rim. You'll just need to play around with the tire pressure until you figure out what will give you the flattest tire patch.
You'll also want to add washers to your steering stops to prevent rubbing the front control arms.
'98 TJ Sport
ElementX is offline
swampers , 33 , spacers , tj , wrangler
93 YJ on 36" swampers gtome YJ Wrangler Technical Forum 18 06-30-2010 05:15 PM
Will a 3" body lift allow me to run 44" super swampers? Morpheus Wrangler General Discussion 9 01-03-2010 06:45 PM
34" Swampers with the 2.5? Kman1983 YJ Wrangler Technical Forum 2 06-23-2009 11:53 AM
pics of 33x14.5" swampers on yj cvweaver95yj YJ Wrangler Technical Forum 1 07-11-2003 05:06 PM
6" skyjacker w/ 36x12.5 swampers TwinTurboTA TJ Wrangler Technical Forum 1 04-03-2002 04:27 AM
