33's no lift, tube fenders? - JeepForum.com
post #1 of 10 Old 07-12-2010, 10:37 AM Thread Starter
witness
Is it possible?
I got a 2001 Sahara, and I really like the idea of running stock suspension.
I'd rather have tube fenders than a suspension lift. Has anyone done this? Any draw backs to running stock suspension and 33's?
witness is offline
post #2 of 10 Old 07-12-2010, 10:42 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
damn right its possible. -sean- on this forum runs 35s at roughly stock height (well...for the most part...his rig is highly modified).
but based on the educated folks i've talked to running the stock springs with big tires, they're a little disappointed in the uptravel and downtravel. with shock mount relocation and long travel shocks, the stock springs unseat because they aren't long enough uncompressed, and with stock shocks they just don't flex a ton.
if you just want to fit 33s on completely stock suspension, then slap on a set of highline fenders (DIY, Rokmen, Gen-Right, AEV, TnT Customs, etc), hack up the rear with a sawzall and you're done.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 10 Old 07-12-2010, 10:48 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
TheBoogieman is offline
post #4 of 10 Old 07-12-2010, 11:19 AM Thread Starter
witness
Would tube fenders up front and flares in the rear be ok? Our would I have to take a saw to my rear quarter panel? I'd like to keep as much of the stock sahara look as possible. I know tube fenders are as far from stock look as possible but you get the idea. I'd really like for it to be a sleeper that I can drive everyday
witness is offline
post #5 of 10 Old 07-12-2010, 11:27 AM
DevilDogDoc
The front will be ok you will rub a little but the back will rub every bump you hit I did that with my 285's roughly 33 11 or hits in the front of the rear wheel well ...
An ugly Jeep with some stuff.
DevilDogDoc is offline
post #6 of 10 Old 07-12-2010, 11:48 AM
Unlimited04
yes you need to cut the rear, and not the flares - the steel body. you can keep the stock flares. lots of people DIY highline their rigs and reuse the stock flares.
KWIT YNIN, git ta cuttin.. stuffin 37's under 2.5" lift. - JeepForum.com
otherwise you would need to add 2" of bumpstop to your rear axle to keep the tires out of the fenders (again, not the flares, the steel body), which would basically eliminate the uptravel you have now, making the Jeep ride like a go kart.
http://www.jeepforum.com/forum/f9/bu...points-734737/
Useful Write-Ups:
Funny:
post #7 of 10 Old 07-12-2010, 11:57 AM Thread Starter
witness
Would a small body lift solve rubbing problems in the rear? Maybe a smaller tire would work out better
witness is offline
post #8 of 10 Old 07-12-2010, 12:05 PM
Unlimited04
a 1.25" BL will just barely clear 32s (given proper backspacing). works really good with 31s.
Useful Write-Ups:
Funny:
post #9 of 10 Old 07-12-2010, 12:14 PM Thread Starter
witness
I really wanted to avoid a suspension lift but maybe a small one might be in order
witness is offline
post #10 of 10 Old 07-13-2010, 03:21 PM
tjallday
go bb, cheap, easy
tjallday is offline
tj , wrangler , tube , fenders , 33 , suspension , stock
TNT tube fenders -vs- overkill eng tube fenders CCJ TJ Wrangler Technical Forum 44 12-02-2011 03:24 PM
33's, Tube fenders, 1.25 JKS body lift? possible? 00_jeep_sport TJ Wrangler Technical Forum 2 11-26-2011 10:54 AM
about how much tube will i need for diy basic tube fenders??? nathan2034 YJ Wrangler Technical Forum 17 01-17-2010 05:12 PM
For those of you with tube fenders or chopped fenders....? wmeyer116 TJ Wrangler Technical Forum 4 11-01-2009 04:39 PM
tube fenders & 2" BB on 33's carpekd TJ Wrangler Technical Forum 6 02-20-2008 05:26 PM
