damn right its possible. -sean- on this forum runs 35s at roughly stock height (well...for the most part...his rig is highly modified).
but based on the educated folks i've talked to running the stock springs with big tires, they're a little disappointed in the uptravel and downtravel. with shock mount relocation and long travel shocks, the stock springs unseat because they aren't long enough uncompressed, and with stock shocks they just don't flex a ton.
if you just want to fit 33s on completely stock suspension, then slap on a set of highline fenders (DIY, Rokmen, Gen-Right, AEV, TnT Customs, etc), hack up the rear with a sawzall and you're done.
Would tube fenders up front and flares in the rear be ok? Our would I have to take a saw to my rear quarter panel? I'd like to keep as much of the stock sahara look as possible. I know tube fenders are as far from stock look as possible but you get the idea. I'd really like for it to be a sleeper that I can drive everyday
The front will be ok you will rub a little but the back will rub every bump you hit I did that with my 285's roughly 33 11 or hits in the front of the rear wheel well ...
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
