33" MTR on stock tire carrier?? - Page 2 - JeepForum.com
post #16 of 37 Old 12-21-2005, 12:03 PM
Tobey
Originally Posted by SYRubi
Uh-oh, DC better not hear this, just the 245/75/16 MT/R tire alone weighs 50 lbs. It must be rated for a tad more.............
add to this the weight of the OEM rubicon wheel and i would bet you are close to 80lbs total.
does the rubicon have an uprated carrier or hinges for the tailgate?
Tobey is offline
post #17 of 37 Old 12-21-2005, 03:26 PM
Windsor
Mobil 1, not Mobile 1
Windsor's Avatar
All 2003+ Jeeps have the redesigned tailgate / carrier.
2004 Wrangler Rocky Mountain Edition
BF Goodrich 31x10.50 Mud Terrain KM2
Rusty's 3" front springs and Skyjacker 2" rear spacers
Skyjacker Hydro 7000 shocks and steering stabilizer
JKS Quicker Disconnects
Tuffy glove box, full console
WARN D30 skid & Nth Degree Mobility oil pan skid
WARN front and rear Rock Crawler bumpers, winch plate and grill guard
WARN 9.5ti winch w/ Optima Blue Top D34M - X-Line rope & fairlead
KC Daylighter Slimlights on windshield
IPF H4 w/ FatBoy bulbs
Windsor is offline
post #18 of 37 Old 12-21-2005, 04:44 PM
JFiorentino
JFiorentino's Avatar
A 33" MTR will fit on the stock carrier, but it will cover your third brake light, and you will have to cut down or remove your bump stops. I drove around for a few months with the stock carrier with a 33x12.5 MTR mounted. I may have gone off road once or twice in that time (Nothing rough).
I recently removed the tire and discovered that my tailgate doesn't shut very well anymore. It leaves a gap big enough to slip my fingers through, and sometimes I have to slam it 2 and 3 times to get it to latch. Also, when I look at the latch, I can clearly see wear marks in the metal. I was fortunate that the sheetmetal didn't bend or that the screws didn't pull through. I know a guy where his tailgate sheetmetal gave out and it just tore. He has 6 inch gashes where the stock tire carrier used to sit.
John
"When approaching a four-way stop, the vehicle with the largest tires always has the right of way"
2004 TJ, Auto w/ OD, 4.0L, Off-Road 36x13.5 Super Swamper IROK's on MT Classic II Rims, SYE, CV Driveshaft, 4:56 Gears, ARB Locker, 3.5" RE Superflex, 2" Body Lift, JKS Quicker Disco's, 9,000# Winch, Toys-by-Troy step-sliders, The Source OBA. And lots more....
JFiorentino is offline
post #19 of 37 Old 12-21-2005, 10:13 PM
rock dawg
I've been running a 35" mtr on a steel wheel for two years on my 02 TJ.
30k on road and heavy wheeling once a month. all I did was space out the rubber bumps to keep the tire from rocking. no problems so far
Maybe I'm just lucky
rock dawg is offline
post #20 of 37 Old 12-22-2005, 07:34 AM
ckp_hokie
Where can I get an aftermarket tire carrier? I am just running 31's, but don't have enough lugs on the stock. Any brand recommended?
ckp_hokie is offline
post #21 of 37 Old 12-22-2005, 07:41 AM
WR4NGLER
Originally Posted by JeepJay3279
I ran that same setup for about 6 months. All I did was extend (or remove) the third brake light and space out the rubber bumpers. The stock carrier is fine for a short time while you save for a more robust option.
I've been offroading maybe 3-4 times since I extended the bumpers and raised the light. This includes some high speed mudding and Blue-3 rock crawling at PAP. I've been driving it for like 3-4 months this way, no problems.
I ahve 33x12.5R15 TrXus MT's.
You can extend the brake light for like $5 using some home depot hardware.
http://www.jeepguide.com/tutorial.php?id=36
EDIT: Forgot to mention that I have a 1.25" BL and 4.5" wheel backspacing.
WR4NGLER is offline
post #22 of 37 Old 12-22-2005, 07:46 AM
WR4NGLER
My buddy just got a Jeeperman and it was fabbed incorrectly. The latch doesn't even hit the striker. I don't like it.
My other buddy has a wilderness rack, but has told me the powdercoating guy they use is bad and both his wilderness racks have started to rush.
My other OTHER buddy has a currie. It's very weak in the receiver area, can't tow with it.
My other OTHER OTHER buddy has an AtoZ Fabrication carrier. You can pretty much tell Zach what you want and he'll make it. Good stuff, is holding up great. He tows an M416 with it too, full of wood. Never had a problem. The bumper is more than solid. He's landed on rocks with it before, naturally dinged it, but it's hardcore. The carrier my friend had Zach design is awesome. Very strong. The hinge is rated high and the latch he got with it is a screw in, which would be my very first choice as others I've seen blow open on the trail.
www.AtoZFabrication.com
WR4NGLER is offline
post #23 of 37 Old 12-22-2005, 07:51 AM
loudog3114
nylon strap it into the back seat when you wheel.
92 YJ, 35's, 6", Locked
97 Honda CBR1100xx
08 336XI
loudog3114 is offline
post #24 of 37 Old 12-22-2005, 07:56 AM
WR4NGLER
That works too, my friend just ratcheted his to the rear floor. Lost a ton of room though and the car smelled like rubber all the time.
WR4NGLER is offline
post #25 of 37 Old 12-22-2005, 08:51 AM
ckp_hokie
What about for street use? Nylon strap is a bit Jed Clampett.
post #26 of 37 Old 12-22-2005, 09:00 AM
WR4NGLER
Throw it on the stock carrier for a few months until you get an aftermarket carrier.
I don't think there's much of a choice. I mean, if you don't care and want to gamble, just LEAVE it on the stock carrier til you start to notice something.
EDIT: My 3rd light extension cost me $5 and the piece of wood I used to extend the bumpers cost me $0.50.
WR4NGLER is offline
post #27 of 37 Old 12-22-2005, 09:24 AM
ckp_hokie
Whats the name of the aftermarket carrier? Not the swing type, maybe just an additonal thing that I can attach to clear the light and have more than 1" of lug? Where did you get the light extension. Thanks.
Sorry for the hi-jack original poster.
post #28 of 37 Old 12-22-2005, 09:29 AM
WR4NGLER
Wr
Read my previous posts for information on tire carriers. I prefer:
www.atozfabrication.com
To extend the light:
Go to home depot, buy 4 longer bolts and 4 coupler nuts that are liek 1.5" long and BIGGER than the bolts, so they can slide right over.
Tutorial: http://www.jeepguide.com/tutorial.php?id=36
WR4NGLER is offline
post #29 of 37 Old 12-22-2005, 09:42 AM
ckp_hokie
Gotcha. Thanks!
post #30 of 37 Old 12-22-2005, 12:12 PM
bradleyfitz
I cut the lugs off the stock carrier, dropped some new ones in (longer), and had a shop weld 'em to the carrier. Cost? $3.
98 Sahara, hp44/hp60, warn 5x5.5 premium hub conversion, 4.88, arb's, hydro assist, RE 4.5 SF /w 3.5 springs, Novak / Teraflex SS SYE, currie anti-rock, JKS 1.25" BL, 36" bias iroks, PSC Tube fenders /w 3" flare, PSC Ricochet Rockers, custom rear bumper, btf front bumper / winch plate, warn 9.5ti, full cage, TwistedStitch seats, RCI-2161a fuel cell
bradleyfitz is offline
Pics of stock tire carrier with 35" tire JLCJ7 JK Wrangler Technical Forum 15 02-15-2010 07:55 PM
15x8 with a 30" tire on stock tire carrier? MC_NickP TJ Wrangler Technical Forum 12 02-08-2009 09:31 PM
Stock spare tire carrier adjustment for 31" tire? citRon YJ Wrangler Technical Forum 5 09-11-2008 06:42 PM
33" tire on stock spare tire carrier...possible? meanmp70 TJ Wrangler Technical Forum 25 12-01-2005 07:44 AM
31" tire on stock spare tire carrier? Wolfpack97 TJ Wrangler Technical Forum 2 08-10-2002 08:43 PM
