Quantcast 33 Engineering Tummy Tuck Install Problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 33 Engineering Tummy Tuck Install Problems
Truck-Lite's New LED Headlamp SeriesRuffstuff Axle Simple Swap Kit!Spartan Lockers FREE SHIPPING Excellent Prices
Old 12-20-2008, 11:58 PM   #1
05jeeper
Jeep Enthusiast
05jeeper's Avatar
I have a 05 Rubicon with the Auto. 4" SA lift with a 1.25"BL and ML. I installed a 33 Engineering Tummy Tuck today and now I have a horrible vibration through the floor with light throttle, jeep stationary. I also have a metal grinding? noise when trying to drive. I am using the factory tranny mount. Has anyone installed one of these and did you use the factory tranny mount? Seems like it should have a smaller tranny mount to reduce possibility of the tranny vibrating against the body, and decreasing drive line angles. It didnt come with any kind of instructions. Wouldnt think you would need any as looks strait forward but something is wrong. Please help!
2005 JEEP RUBICON
GROUP MEMBERSHIPS:
BLACK JEEP SOCIETY
TJ OWNERS CLUB
WAR VETERANS JEEP GROUP
WASHINGTON STATE JEEPS
05jeeper is offline   Reply With Quote
Old 12-21-2008, 12:14 AM   #2
thejafe
Are you running a CV/SYE setup with adjustable upper control arms?
Visit My Homepage!
thejafe is offline   Reply With Quote
Old 12-21-2008, 12:15 AM   #3
Mitchin
lmao people dont read
NIGHT CREW #16
Yellow Jeep Club #67
My Build Thread- http://www.jeepforum.com/forum/f22/mitchin-02-tj-sport-973277/
THANK YOU TO 97tjeff, Metalcloak!!!
Mitchin is offline   Reply With Quote
Old 12-21-2008, 12:17 AM   #4
05jeeper
Jeep Enthusiast
05jeeper's Avatar
The rubicon has a factory CV/SYE and I have adj procomp upper arms
2005 JEEP RUBICON
GROUP MEMBERSHIPS:
BLACK JEEP SOCIETY
TJ OWNERS CLUB
Old 12-21-2008, 07:40 AM   #5
wrangler2007
Did you get a new driveshaft when upgraded to the 4" kit?
Other Vehicles:
07 Mustang, Whipple, 465 rwhp, Magnaflow, Hurst , AVIC D3, Spec 3+, BMR CA's, Autometer, FRPP Springs
08 F150 5.4L, Super 40 SIDO, Roush Grille, Edge Evolution, Truxport, 2.5" AS Level, 1.5" AAL, 35x12.5x20 Nitto Trail Grapplers
wrangler2007 is offline   Reply With Quote
Old 12-21-2008, 07:55 AM   #6
Pillswoj
The Rubicon Transfer case is bigger, I would assume it is touching the floor pan in several places. You could try a smaller tranny mount but you may need to clearance the floor pan with a hammer.
You should contact 33 - Eng and ask about fitting the skid on a rubi.
Friends don't let Friends run Bosch
My Wifes Cake Site - Check the Jeep Under Carved & 3D
Pillswoj is offline   Reply With Quote
Old 12-21-2008, 08:22 AM   #7
80 CHOPPER
Mine came with a new tranny mount.
DRAGON
80 CHOPPER is offline   Reply With Quote
Old 12-21-2008, 08:37 AM   #8
JBWood05TJ
Cut to Fit-Paint to Match
JBWood05TJ's Avatar
Look at the top of your t-case. I'm sure that it's against the bottom of your tub. What you need to do is pull the TT off again, get a floor jack under the t-case and lower it down enough to get a block of wood cut from a 4X4 between your t-case and the tub. Then jack the t-case back up and dimple the bottom of the tub. You won't see this inside because the tub is double wall where you're doing this, so don't worry. You need to dimple it enough so that when your t-case is back up to the height it would be when sitting on the new skid, it's not touching. Having another person to help you will make this job a lot easier.
Frankly, I'm surprised that you were able to get the skid bolted up at all without doing this. The 33 tranny mount will help, but you will still have to dimple the tub - just not as much.
We save dogs: http://www.secondchanceshepherds.org/
JBWood05TJ is offline   Reply With Quote
Old 12-21-2008, 09:01 AM   #9
BarneyJEEP
33 sells a low profile tranny mount, its something like $130
http://www.kifourwheelers.com/
BarneyJEEP is offline   Reply With Quote
Old 12-21-2008, 10:55 AM   #10
Imped
TITS
Imped's Avatar
Wrong. You have a fixed yoke on your NP241 but you do not have a CV style shaft. Your fixed yoke won't help prevent vibes any more than the slip yoke style of the TJ NP231. You should probably look into a custom CV shaft. But to answer your question....sounds like your larger NP241 and/or tranny is rubbing the tub. 33 Eng. sells a lower profile tranny mount that you should give a try. I know there is a great, in depth install on the 33 Eng. unit on here...search for it.
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Old 12-21-2008, 11:13 AM   #11
05jeeper
Jeep Enthusiast
05jeeper's Avatar
I thought one of the advantages to the Rubi package was that it had the cv style shaft. Wouldnt be the first time I was wrong. In any event I am convinced that I need to get the lower tranny mount and I may even have to lower the TT. I will call 33 Engineering in the morning for their assistance.
2005 JEEP RUBICON
GROUP MEMBERSHIPS:
BLACK JEEP SOCIETY
TJ OWNERS CLUB
Old 12-21-2008, 11:51 AM   #12
thejafe
Exactly . Beat me to it.
Visit My Homepage!
Old 12-21-2008, 12:53 PM   #13
wrangler2007
Why don't you just get the CV driveshaft and adjust your UCA's?
Other Vehicles:
Old 12-21-2008, 06:53 PM   #14
05jeeper
Jeep Enthusiast
05jeeper's Avatar
Well after carefully looking I have discovered that the transfer case it hitting the tub. Looking at the chart on 33 engineering the new tranny mount should solve that problem. I will call them in the morning. I also discovered that the air locker bracket was hitting the transfer case. A couple of minuetes with the cut off wheel fixed that. I do not see that the drive lines are binding but after I get the other issue fixed I will be able to tell more. Lastley I have to adjust the t-case lever as it is bound up. I am wondering if I should remove the bracket that came with the body lift. Any thoughts on that?
2005 JEEP RUBICON
GROUP MEMBERSHIPS:
BLACK JEEP SOCIETY
TJ OWNERS CLUB
Old 12-21-2008, 07:35 PM   #15
LJlunatic
Yeah I would remove that bracket and put the shift lever back to stock...That should help some.
If not Novak adapters sells the best transfercase bracket for your application.
LJlunatic is offline   Reply With Quote
Glock Forum
