33" with 4.11 should I feel any powerloss? - JeepForum.com
post #1 of 14 Old 02-06-2014, 02:34 PM Thread Starter
SandMan24
hi, i live in mexico and im new to jeeps a year ago i bught my first jeep, wich is a bone stock 2000 tj 6cil with freshly rebuild 32rh tranny with 3.07 gears and 235/75r15 goodyear wrangler. After a year of dreaming im ready to make the firt mods to my jeep, i have 2 2006 dana 44 rubicon axles with 4.11 gears ready to go in, with a NP241OR transfer. my question is should i notice any loss in throttle response when i put 33" tires with the 4.11 ? or should i go with 32 for more power.
Ruben Garcia
SandMan24 is offline
post #2 of 14 Old 02-06-2014, 02:50 PM
A4LiterV8eater
Nope, thats a good gearing/tire size combo
A4LiterV8eater is offline
post #3 of 14 Old 02-06-2014, 04:17 PM
JBTJ
The 4.0L with the 32RH coupled with 4.11 gears on 33" tires is the best optimal setup.
JBTJ is offline
post #4 of 14 Old 02-06-2014, 04:49 PM Thread Starter
SandMan24
with that combo the final ratio is higher or lower than stock?
thanks
post #5 of 14 Old 02-06-2014, 05:40 PM
Lrasser
pretty close to stocks
Lrasser is offline
post #6 of 14 Old 02-06-2014, 05:52 PM Thread Starter
SandMan24
close on the lower side?
post #7 of 14 Old 02-07-2014, 06:35 AM
JBTJ
Probably so.
JBTJ is offline
post #8 of 14 Old 02-07-2014, 10:40 AM
Mulvihill64
Your rpm's will be a little higher than stock. Right now, you should be turning somewhere around 2500 RPM at 70 MPH. With 33's and 4.11's, you will be at roughly 3k. Your final drive ratio currently is 16.89 (in 4lo), with 4.11's it will be 22.61.
check out this site
http://www.grimmjeeper.com/gears.html
Mulvihill64 is offline
post #9 of 14 Old 02-07-2014, 11:25 AM
TJ-Tera
Not to hijack this thread, but in another thread people were telling me to go with 4.10's and I only have 31" tires?
TJ-Tera is offline
post #10 of 14 Old 02-07-2014, 11:28 AM
JBTJ
You have a different transmission.
JBTJ is offline
post #11 of 14 Old 02-07-2014, 11:30 AM
rchase559
Note that the OP has the 32RH. This is a 3 speed auto with the highest gear having a 1:1 ratio.
You have an AX-15 according to your profile. This is a 5 speed manual with an overdrive gear.
Since you have an overdrive gear and the OP doesn't, you would want deeper gearing relative to the tire size than them.
rchase559 is offline
post #12 of 14 Old 02-07-2014, 11:49 AM
TJ-Tera
DUH. Sorry, I guess I missed that .
Thanks guys
TJ-Tera is offline
post #13 of 14 Old 02-07-2014, 02:08 PM Thread Starter
SandMan24
the gear ratio calculator says that im gonna be doing 2929 RPM at 70 MPH with 4.11 and 33
post #14 of 14 Old 02-07-2014, 02:18 PM
Mulvihill64
Just for comparison that's roughly what I'm running with 3.73 and 31's... Works pretty well
Instagram: Mulvihill64
