Quantcast 33/12.5/15 Will it clear W;2' lift? TJ - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 33/12.5/15 Will it clear W;2' lift? TJ
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 02-22-2008, 12:19 PM   #1
dequity
A guy has a set of four 33/12.5/15 tires at a Great price. And he is local. I was wondering if these will fit my 97 TJ. I'm running a rubicon Express 2' lift and 10' wide rims that stick out pretty far.
If they rub, what will they rub first? I don't mind taking a hack saw to my TJ. I got it for having fun, and that is exactly what I do with it.
00 TJ 4.0 / 98 5.9 Liter Grand / 98 C5 Corvette (set up for SCCA racing)
dequity is offline   Reply With Quote
Old 02-22-2008, 12:28 PM   #2
1BadJeepX06
The easiest thing to do would be to install a 1" BL and then you will clear them for sure..... Just :my2c: but putting 33's on a 2" lift will be a problem...
DH
Coming soon: 2000 Jeep Sport (modifications soon after) :-)
1BadJeepX06 is offline   Reply With Quote
Old 02-22-2008, 12:30 PM   #3
LeftoverSalmon
Your probably pushing it with 33's. I tend to rub a little on the trail if disco'd and thats only with 31's. perhaps a 1"BL? you gonna be taking it offroad?
LeftoverSalmon is offline   Reply With Quote
Old 02-22-2008, 12:36 PM   #4
dequity
What gears do I have? It's a stock 5 speed 4.0. I'm thinking 3.73. Is this going to be a problem for axles?
FYI: Here is how I wheel.
http://s186.photobucket.com/albums/x164/dequity/?action=view&current=THIRDGEAR.flv
http://s186.photobucket.com/albums/x164/dequity/?action=view&current=almost.flv
http://s186.photobucket.com/albums/x164/dequity/?action=view&current=P9290566.flv
Old 02-22-2008, 12:54 PM   #5
snakester14
Originally Posted by dequity View Post
In that 3rd video why did you turn it off in that much water/mud or did you stall? Did you suck water in through your exhaust and into your engine?
1998 ZJ 5.2/2inch bb/265 a/ts/Flowmaster SOLD
1996 Stock XJ 4.0/ax-15/231 Traded
1998 4.0/ax-15/231 TJ on 33s SOLD
snakester14 is offline   Reply With Quote
Old 02-22-2008, 01:00 PM   #6
dequity
Because a more "Experienced" 4 wheeler. Told me to. Just listen.
I swear to god nothing burns my *** like some dumb ars spitting out bad advice with authority.
Old 02-22-2008, 01:07 PM   #7
snakester14
I was just wondering b/c I had heard that you are supposed to keep it running when the exhaust is under water and if I am ever in the same situation I would like to know what to do . Some of these pits in Carolina are a lot deeper than they look.
By the way what happened when you shut it off?
Jake
Old 02-22-2008, 01:24 PM   #8
dequity
Jake
Water then went on up inside my exhaust. I had to tow the jeep out and leave it parked nose up on a hill side. After a while it started and ran fine.
Old 02-22-2008, 03:57 PM   #9
claytonandson
claytonandson's Avatar
i've been running 33's for years and do some similar wheeling and so far no problems,thats w/2" susp.lift.....but i only run 33/9.50/15 bfg radial at's.
yellow jeep club #343
IAFF /FF's OF WASH. D.C. EMERALD SOCIETY/CHARLES COUNTY RESCUE SQUAD 51
claytonandson is offline   Reply With Quote
Old 02-22-2008, 04:16 PM   #10
randonlee25
I run 33x12.50's on a 2" BB with 4" of backspacing and have never rubbed.
If you were afraid to open that little bag and look inside, don't even think about opening the hood. There's a whole bunch of complicated crap hidden under it.
randonlee25 is offline   Reply With Quote
Old 02-22-2008, 08:24 PM   #11
snakester14
not tryin to hijack thread but where do you wheel in NC I can't find anywhere besides uhwarrie
Old 02-25-2008, 01:33 PM   #12
dequity
Thanks for the input. I think I'll go ahead and get these tires.
Old 04-09-2009, 08:59 PM   #13
Oaktree
two inch coil spacer lift will clear 33's by 12.50 with no problem..i dont rub. and I have the truxus m/t..thick tire...
and I did the black trails at rausch creek with no problem.
Oaktree is offline   Reply With Quote
Old 04-09-2009, 09:04 PM   #14
BP88
I rubbed a tiny bit with 33x12.50r15 tires on my 2.5" OME HD lift. After I had my JKS 1.25" body lift installed - no more rubbing!
BP88 is offline   Reply With Quote
Old 04-10-2009, 06:17 PM   #15
mdawg4x4
33X12.50 on 15X8 not sure about BS, but stick out further than I want. Extended bump stops and not disconnected. I only rub slightly on the rear flares when fully flexed. If I ever get to add some flat flares, Xenon or Bushwacker, I'll be clear.
98 TJ Sport: 2" Skyjacker spacers w/Rubicon coils, Rancho RSX shocks, 33-12.50 BFG MT on 15X8 Mickey Thompson Classic Locks, Borla header, Flowmaster Mufler, Pioneer sound W/12" RF P3 sub and MTX amp
06 Nissan Frontier NISMO CC 4X4: 2.5" lift with Rancho RS9000X shocks, 285/75-16 BFG ATs, Alpine sound
Mdawg's 98TJ @ Cardomain, http://www.mississippi-mud.com/forums/index.php?
mdawg4x4 is offline   Reply With Quote
Glock Forum
