32x11.50r15 BFG MT's on Gamblers will I need spacer? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 32x11.50r15 BFG MT's on Gamblers will I need spacer?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 05-14-2008, 11:53 AM   #1
teddyg112
Just wondering what the backspacing on the gambler rims are. Will i need to add a spacer to be able to mount these tires?
99 TJ Sahara, 4.0L, Dana 30/35, 2" REBB, 32x11.50r15 BFG MTs on Gamblers
teddyg112 is offline   Reply With Quote Quick reply to this message
Unread 05-14-2008, 01:02 PM   #2
TheBoogieman
Evil Inside.
TheBoogieman's Avatar
5.25" backspacing on Gambler wheels.They will rub in the rear without wheel spacers.
TheBoogieman is offline   Reply With Quote Quick reply to this message
Unread 05-14-2008, 02:18 PM   #3
teddyg112
how big of a spacer will i need?
Unread 05-14-2008, 02:37 PM   #4
Jerry Bransford
Administrator
Jerry Bransford's Avatar
32x11.50 tires will barely rub in the rear, if at all, with 5.25" of BS. If they do, the skinniest wheel spacer you can find is all that would be needed, though I've only seen 1" spacers which is way more than could possibly be needed.
Getting Savvy...
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 05-14-2008, 02:43 PM   #5
speedydave
If your axle is perfectly centered by your track bar it will be fine. I have 32x11.5 BFG's on my Ravine wheels and I had them on my grizzly wheels before on my old TJ.
speedydave is offline   Reply With Quote Quick reply to this message
Unread 05-14-2008, 02:46 PM   #6
erickpl
I have the Spidertrax spacers on my Canyons (same BS) and they are 1.25. Granted, I'm running 33x12.5, but I know I have no rubbing issues. You may also want to adjust your steering stops if you have rubbing at full turn. see www.4x4xplor.com/steerstop.html on steps to do this.
-Paul
Green Jeep Member #155
Low Output 4 Cylinder Jeep Member #35
Keep moving forward. But keep an eye on history, for if you don't, you are doomed to repeat it.
erickpl is offline   Reply With Quote Quick reply to this message
Unread 05-14-2008, 03:09 PM   #7
IslandTJ
Location: where I wheel: N 45º 36.663' W 123º 20.935', Oregon
Although, not your size - I have just started running 33" x 10.5" BFG MTs on my Gamblers. Streetwise, I haven't experienced any rubbing on the rear perches or front lower control arms (however that may be a result of a washer on each steering stop, when I used to run 31” x 11.5 mud terrains). After I break-in my new differential gears after 500+ miles, I'd like to run disconnected and articulate to see if any rubbing occurs on the typical problem areas.
I currently like the tucked-in look with the Gamblers and do not experience instability issues on the highway. The Sahara flares are flushed with the widest part of the MT tires. I also like the facts that when it rains and the roads are wet, I can keep dry if my windows are down. No water sprinklers…no muddy sides.
As such, I would like to avoid adding spacers if possible, but time will tell…
1998 TJ Moss [COLOR=darkgreen][B][SIZE=3]Green[/SIZE][/B][/COLOR] Sahara w/ numerous scratches & dents whose playground is on a tropical island that's 33 miles long and 4-12 miles wide, in year-round 82 degree weather.
[Edit] "Now jeepin in Oregon" [/Edit]
IslandTJ is offline   Reply With Quote Quick reply to this message
Unread 05-14-2008, 04:23 PM   #8
teddyg112
would these work?
Click here for link
And what size bolt circle would i need?
Unread 05-14-2008, 05:01 PM   #9
IslandTJ
Originally Posted by teddyg112 View Post
would these work?
Click here for link
I would rather consider these spacers over the JCWs. Then there's the ever popular Spidertrax spacer option.
Unread 05-14-2008, 05:31 PM   #10
Jerry Bransford
Administrator
would these work?
Click here for link
I'd rather run those than the usual 1" and thicker spacers like Spidertrax sellls. You only need a tad more clearance so the one at http://www.jcwhitney.com/autoparts/I...D:100000222851 would be ideal. Sticking your tires out an inch or more than is necessary with traditional spacers just isn't necessary or even good, at least in my opinion.
You may want to find some "ET" (extended thread) lug nuts though, as the description mentions. 5/16" less engaged thread than stock probably isn't all that significant however, there's plenty of thread so 5/16" less may not make a significant difference. ET lug nuts are easier to find and install than longer wheel studs are, that's for sure. If you decide you want some, the thread size you need is 1/2"x20. They're all over eBay, just look at your wheel's stud openings and determine if you need flat or conical ET nuts to match the base of the lug nut mounting surface.
Getting Savvy...
Unread 05-30-2008, 06:48 PM   #11
teddyg112
Thanks for all the useful info guys, Its been real helpful. One more question how much space do i need? I can fit my fingers between the tire and spring perch in the rear is that enough? Will it rub if i get in a bind?
Unread 05-31-2008, 11:42 AM   #12
teddyg112
ttt.................
Unread 05-31-2008, 12:07 PM   #13
George Dickel
George Dickel's Avatar
Teddy, did you just say "to the top"? I like seeing that from someone right in Mississippi State's backyard!
Go Eagles, SMTTT!
'98 Wrangler Sport, 4.6L Stroker
12 Counterweight 258 Crank (cut snout-casting #3214723), Sealed Power +.030 Hypereutectic Pistons, 5.875" Connecting Rods, CompCams 68-231-4, Ported/Polished Head, Edelbrock Header, 24# Ford Blue-top Injectors, 63mm bored OEM Throttle Body, Port matched Intake, Autolite Platinum plugs, Accel Coil, LiveWires Distributor & Wires, Centerforce Clutch, Hurst Shifter, modified Mustang GT Air Cannister - CAI, 18" Magnaflow and 2 1/2" exhaust, Balanced Rotating Assembly, Custom PCM tune.
Yeah, I built it!
Exhaust clip: http://www.youtube.com/watch?v=bwUOa...ature=youtu.be
'04 Mustang GT, 4.6L
Light modifications
Read more, Post less, Search often
George Dickel is offline   Reply With Quote Quick reply to this message
Unread 06-02-2008, 11:57 AM   #14
teddyg112
Go Eagles, SMTTT!
hehe Go Dawgs
Bump
Unread 06-02-2008, 12:06 PM   #15
otisdog
2008 WK
The tires will probably work ok on the street but offroad..
I put 33 x 10.50's on Gamblers and they were too close to the upper rear spring perchs for my liking so I added Spidertrax 1.25" spacers.
Jim
08 Grand Cherokee Overland
otisdog is offline   Reply With Quote Quick reply to this message
