Quantcast 32x10.5 - JeepForum.com
EGGERS BROS. INC YOUR JEEP SOURCE
CALL 1-800-274-2460
Competitive pricing!
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 32x10.5
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 10-13-2004, 08:28 AM   #1
waterlogged
32x10.5
Does anyone know of any tire manufacturer that makes an A/T in 32x10.5. I have only seen 32x11.5 by both Bridgestone and BFG. I have a 2BB with stock canyon rims 15x8 and am afraid the 11.5's will rub.
waterlogged is offline   Reply With Quote
Old 10-13-2004, 08:52 AM   #2
jeephreak
That makes two of us, I dont want to go 33s b/c its my DD and I do more street then dirt, however Id like to gain a little height...skip over the 31s. Would they look too much like tall pizza cutters? Anyone have pics of 32x10s
2005 Rubicon
lifted, some big tires, some of this, some of that...
MY RIG
r.i.p. Cap'n Crunch
jeephreak is offline   Reply With Quote
Old 10-13-2004, 09:45 AM   #3
merlin969
Looks like Super Swamper does
2001 TJ Sport
Kumho 31X10.5X15 Venture M/T
Dana 44, 4.0L, 5 sp
Mopar Nerf Bars, K&N filter, Cobra CB, Firestik II antenna, 2.5 lb Fire Extinguisher
[COLOR=White]White Jeep Club Member 969[/COLOR]
[COLOR=DarkRed]What's Next?: 2" BB lift and a New Top.[/COLOR]
merlin969 is offline   Reply With Quote
Old 10-13-2004, 11:48 AM   #4
Drjones266
I dont think your 11.5 will rub on a 15x8 canyon.. I had grizzly 15x7 with 11.5 and it rubbed very little. Even if they do rub a little you can stop that kind of tire rub with a washer or two under each of your two steering stop bolts. Go to http://www.imajeep.com/Steering_Sto...eering_stop.htm for complete instructions on how to do this easy adjustment. -- Thanks to Jerry Bransford --
Drjones266 is offline   Reply With Quote
Old 10-13-2004, 11:57 AM   #5
red99tj
ur gonna rub your control arms (at full turn) and rear spring perch unless you get wheel spacers. Then with only a bb, if u get wheel spacers, your gonna rub your flares....either get:
31x10.50's
32x10.50 SS
1 inch body to accomadate you 32x11/50s;
or a 1 inch body and 33x10.50's
Frank
PS only look at this if you wheel your jeep, if you dont wheel then youll be fine with 32x11.50s and wheel spacers
Frank
Frank
red99tj is offline   Reply With Quote
Old 10-13-2004, 12:25 PM   #6
waterlogged
My offroad consits of the beach and a few trails. Nothing major. Shortly I will add a 1" BL so I am not worried about rubbing when flexed. I am just concerned with the control arms. It is strange that BFG makes a 33x10.5-15 and not a 32x10.5-15. I guess they don't think the market is that good for them. How bad do you think the rubbing would be in the back without spacers?
Old 10-13-2004, 12:41 PM   #7
sulldoggy
Go metric! 285/75/r16 But you'll have to change your wheel size..
Equates to around 33"X11.2
2000 TJ, BLACK, 3" Teraflex lift, 32" BFG ALL-TERRAINS ON BLACK ROCKCRAWLERS. Yakima roof cargo basket, Okele seat covers.custom mats, Patriot rear tire carrier/bumper
sulldoggy is offline   Reply With Quote
Old 10-13-2004, 01:43 PM   #8
lupinsea
32x11.50's are real close in the back. You might be ok, but you might not, it really depends on the slight variation from tire to tire. Also you just might want the clearance back there for full suspension flex and "mud clearance". Here's a pick from Wayoflife's 4x4xplor.com site showing the "before" tolerances with the stock Canyon rims:
I'd recommend the Spidertrax wheel spacers if you want to run the 32x11.50's on your stock Canyons. With these on the tire extends past the fender flare about 1.5" and broadens your TJ's stance by 4 1/2" for better stablity. Plus you don't need to shim your front steering stops. Here are pictures of clearance with with spacers:
Rear tire clearance with the spacers
Front tire clearance with the spacers
I used to run only a RE 2" BB with the 32x11.50's and the Spidertrax spacers and had no rubbing under full flex. Granted, I did keep my swaybar connected but I didn't have too much difficulty running the trails. If you are going to be installing a body lift soon for full flex clearance then I wouldn't worry around running for a little while with your swaybar hooked up.
Even at full stuff with the stock swaybar the tires never rubbed with the Spidertrax spacers:
While the tires stick out 1.5", they tuck nicely into the fender flares without rubbing
- Jay
lupinsea is offline   Reply With Quote
Old 10-13-2004, 05:58 PM   #9
RedSoxFan
Greetings from another newbie, first post
I've been lurking here for two weeks ever since I purchased my 2002 Wrangler Sport, it's my first Jeep and I LOVE IT! Lupinsea, based upon previous posts of yours I'm modifying mine exactly as you have described. In fact, my Jeep is also yellow and I'm using yours as my reference point for how I want it to look. How's that for flattery?! I've ordered the 2"BB with EMU shock upgrade, spidertrax wheel spacers, and I'll be going with BFG ATs, 32 x 11.5 x 15. My question is: will the 1.5" extension beyond the fenders require wider flares, or might I still pass inspections without them? And I assume I will need adapters for mounting the spare? Didn't mean to hijack this thread, and thanks in advance, this forum is great.
RedSoxFan is offline   Reply With Quote
Old 10-13-2004, 11:21 PM   #10
MikeTheVike
I sure wish more companies made this size. I want larger than 31", but would like the 10.5 size for snow...oh well
MikeTheVike is offline   Reply With Quote
Glock Forum
