07-27-2007, 08:41 PM
#1
32" tire won't fit on stock carrier.
Ok, I thought I had read on these pages that a 32" tire would fit on a stock carrier. Well I must have misread something because it will not fit. It hits the stock bumper.
So, outside of a rear bumper with carrier what can be done to allow for a 32x11.5r15 tires on the stock carrier and stock bumper.
The only thing i can this of is to modify the stock bracket to raise it some how.
Any ideas.
[URL=http://www.thehighroad.org]The High Road[/URL]
[URL=http://www.usdoj.gov/olc/secondamendment2.htm]Do I have the right to own a gun?[/URL]
[URL=http://www.a-human-right.com/]Make a choice![/URL]
Malon Labe
07-27-2007, 09:05 PM
#2
My 32" spare fit with the stock bumper. In fact, others have sent pictures of their 33's on the stock carrier and bumper.
2003 SE, 4.88's, Yukon axles, Rancho springs, JKS Disco's & MML, RE trackbars, ZJ steering, and a bunch of other stuff my wife hasn't found out about...
07-27-2007, 09:06 PM
#3
DelmarvaOffroad.com
x2... No problems (even before the BL)
Michael Ferrari
Team 120 - DOR Racing - Racing for Operation Homefront
Operation Homefront (OHF) provides emergency financial and other assistance to the families of our service members and wounded warriors.
Thanks to our Sponsors:
Delmarva Offroad - F-O-A Shocks - BD Turnkey Engine - Under Cover Fab - Jer-C Transmissions - Quigley Driveshafts
Delmarva Offroad
You call it rolling, we call it R&D! 443-951-JEEP
07-27-2007, 09:19 PM
#4
it depends on the backspacing of the rim.
on the stock TJ rim a 32s will not fit. but with a wheel spacer under it there should be enough space for a 32" tire on the stock rim.
2.5" OME & 2" Spacer & LT Shocks • 2" BL • 1" MML • JKS Discos • JKS Rear Links • OME Steering Stabilizer
35x12.5x15 Cooper STT @ 8.5x15 • ARB Airlockers • ARB Diff Covers • 4.56 Gears • SS Brake Lines
Warn Skids • Genright Rock Slider • Smittybilt Rock Crawler Rear Bumper • Safari Snorkel • OBA
12.000 lbs Winch • Synthetic Winch Line • 4x 130W Hellas • 4x 200W Hellas @ Lightbar • E-Fan
Jeep TJ Runicon Pics www.timbercrawler.de
07-27-2007, 09:25 PM
#5
i have a nice beefy tubular tire carrier, so i wouldnt know!
07-27-2007, 10:00 PM
#6
You need a one inch body lift. Then space up the third brake light with washers. I also had to trim some of the plastic with a reciprocating saw and reroute the third brake light wiring.
If a girl can figure it out, Im sure you can too
Tam
07-27-2007, 10:26 PM
#7
Tam
dang, that is good for a girl! call that reciprocating saw a sawzall and you're set!
07-27-2007, 10:47 PM
#8
Heheheehe...Sawzall is a name brand for Milwaukee Tools reciprocating saw  Mine wasnt a Milwaukee.
I was fairly self sufficient in those days, now I have a husband who manages most of my Jeep stuff  (We actually met here on JeepForum.)
Tam
07-27-2007, 11:57 PM
#9
Tam
who needs eharmony? lol. I'm having problem actually with my 33's on stock tire carrier. I'm going to just order a wheel spacer and put on there.
07-28-2007, 12:23 AM
#10
My 32 is on a Ford Ranger wheel. I mounted it backwards. Try that
07-28-2007, 03:39 AM
#11
hey
4wheeldrive hardware has some little brackets pretty cheap that allow you to fit like a 35 that go on there
Living the high life back in the states
2003 Wrangler X With custom dana 44 front and 8.8 rear 4.88 gears detroit rear tru trac front RE 5.5 40 12.50 MTRS walker evans beadlocks LOD bumper rear poision spider trail front
07-28-2007, 02:42 PM
#12
x100  I have 32x11.5R15 BFG ATs (could be the same tire as the OP?) and it fits fine, and the 3rd brake light still fit as well (although it doesn't look like a bigger tire will fit).
I think you're talking about the tire hitting the rubber tailgate stops. The OP's problem is the tire hitting the bumper - it doesn't sound like the OP had any problems mounting the spare on the stock carrier. My wheels have 3.75" BS, and I had to space out my tailgate stops with blocks of wood so the sidewall will hit the stops.
As for actually answering the OP's question, there are two things you can do: 1) The relocators that codymparmy mentioned or 2) a body lift.
07-28-2007, 04:56 PM
#13
My new tires are BFG MTs.
Took the rear bumper off and it fit ok then. The backspacing on my aftermarket steel wheels are almost like the factory wheels.
I'll run it like that until I can get a rear bumper with carrier.
Thanks for the replies.
Malon Labe
07-28-2007, 05:28 PM
#14
Not to hijack, but I am about to put 265/75/16 with Moab rims on my Rubicon. Does anyone know if they will fit on the stock carrier??
07-28-2007, 05:55 PM
#15
265/75 is about 31.6", so you shouldn't have any problems whatsoever as far as height goes. Assuming the Moabs are your stock wheels (they come on Rubi's right?), then the tailgate stops should work out fine.
