Quantcast 31x10.50x15's on 15x7 rims - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 31x10.50x15's on 15x7 rims
Old 07-21-2006, 11:49 PM   #1
kawa500fastred
i own a 2003 jeep wrangler x and have stock 225x75r15's on it, my question is i am going to put 31x10.50x15's on and was wandering if this will run without any problems other than maybe having to extend the bump stops?
kawa500fastred is offline   Reply With Quote
Old 07-21-2006, 11:54 PM   #2
nicolas-eric
if you don΄t want to use swaybar disconnects the 31s will work without any rubbing. with discos i would install a 2" BB. then you can drive off the road without rubbing tires.
think about buying some 0.75"-1" wheel spacers. then your tires are as wide as the fender flares. that looks much better.
nicolas
P.S. sorry for my bad english...
2.5" OME & 2" Spacer & LT Shocks • 2" BL • 1" MML • JKS Discos • JKS Rear Links • OME Steering Stabilizer
35x12.5x15 Cooper STT @ 8.5x15 • ARB Airlockers • ARB Diff Covers • 4.56 Gears • SS Brake Lines
Warn Skids • Genright Rock Slider • Smittybilt Rock Crawler Rear Bumper • Safari Snorkel • OBA
12.000 lbs Winch • Synthetic Winch Line • 4x 130W Hellas • 4x 200W Hellas @ Lightbar • E-Fan
Jeep TJ Runicon Pics www.timbercrawler.de
nicolas-eric is offline   Reply With Quote
Old 07-21-2006, 11:57 PM   #3
Rocky529
Jeep
Rocky529's Avatar
You won't have any problems.
At the MOST, you may have to add a few washers to your steering stops if you get any rub at full turn. You'll be fine
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 07-22-2006, 05:16 AM   #4
hoosier724
I'm running 31's on stock Grizzlies and have no problem except when I turn to full lock it rubs a bit, just haven't put on those washers yet.
'03 TJ Sport,Light Tan Metallic,, Superlift 4" with BFG 33x12.5x15
Honk if you love Jesus...text while driving if you want to meet him!
hoosier724 is offline   Reply With Quote
Old 07-22-2006, 05:58 AM   #5
davenjeip
I ran 31x10.5's on my stock TJ for over a year.
When the springs were good it didn't rub anywhere. After they sagged, I got a little rubbing here and there, but it was nothing to be concerned about.
I wheeled it often and always ran disconnected. I also never adjusted my steering stops.
2003 TJ
1967 M715
[URL=http://www.davenjeip.com][b][color=red]www.davenjeip.com[/color][/b][/URL]
davenjeip is offline   Reply With Quote
Old 07-22-2006, 10:22 AM   #6
kawa500fastred
thanks for the info, very helpful
Old 07-22-2006, 10:25 AM   #7
kawa500fastred
My next question would be, how hard is it to put coil spring spacers on or would a body lift be best to give it a little rise
Old 07-22-2006, 10:57 AM   #8
COBRA COMMAND
I have Cragar Soft 8's coming Tuesday, want to thrown some 31's on too...I am wondering the same on the above. I dont want to get into a lot of work, I am keeping her near-stock while I am still making the $400/month payment...but a little lift and some disco's would sure be sweet!
[center][FONT="Impact"][SIZE="6"][COLOR="Red"][B]Metalhead Jeep Club Member #666[/B][/COLOR]
[/CENTER][/SIZE][/FONT] [CENTER][FONT="Garamond"][SIZE="3"][I][B]I am an elitist metalhead who is highly opinionated on the subject of music,
but by no means does that mean I am right about what music is good and what isn't![/I][/B][/FONT][/SIZE][/center]
[SIZE="5"][CENTER][B][COLOR="White"][COLOR="Black"]([/COLOR]O[/COLOR]|||||||[COLOR="White"]O[/COLOR])[/B][/CENTER][/SIZE]
COBRA COMMAND is offline   Reply With Quote
Old 07-22-2006, 11:57 AM   #9
bryans98tj
SPring spacers are pretty easy to install and a better option then a BL IMO. With a little knowledge, basic hand tools, some good jack stands and a floor jack you and a buddy can get it done in a couple hours. I think the last time I put a set on it took about 1.5 hrs and that was screwing around too. Some opt to use spring compressors but I just undo the LCA on that corner and sway bar so you will get max drop out of it and be able to get them in no problem. If it were me, I would wait to put in the spring spacers until I have both the spacers and discos. No point in doing the same thing twice.
[SIZE="1"][B]98 TJ-bought-not built
[url]www.PNWJeep.com[/url]
كافر - Infidel[/B][/SIZE]
bryans98tj is offline   Reply With Quote
Old 07-22-2006, 12:00 PM   #10
COBRA COMMAND
Vedrt good point. I wont be able to get the ok on spending from the better half until the fall for all of this...aarrggh...too expensive. Wheels, discos, spacers, winch, mounting plate, battery, etc etc...I wish I was made of money!
Old 07-22-2006, 12:05 PM   #11
bryans98tj
rocky road outfitters sells a BB kit for about $120. Then discos depending will run you upwards of $170 (JKS shipped). I have litterally bought parts and waited 3 months with them sitting in the 'pile' while waiting for funds for everything else. Married, 2 kids-yeah i'm broke too!
Old 07-22-2006, 12:34 PM   #12
sardog12
sardog12's Avatar
I just put on some 31" Cooper Discoverer STTs on my stock steelies (X model) and have no rubbing at all. Haven't had a chance to take it off-road yet, but it looks like there is plenty of room as long as I don't disco. They do stick out of the flares a little (1" - 1 1/2") but that is the sidewall. Other than that they are great. Can post some pics if you want.
U.S. NAVY JEEP HULL # 980
GEAUX TIGERS
P.S. The plane will fly!
sardog12 is offline   Reply With Quote
Old 07-22-2006, 01:22 PM   #13
kawa500fastred
thanks everyone for all the good info, ahhhhhh the joys of owning a jeep wrangler, i think a person could spend there life savings doing odds and ends to one lol, so much you can do with one. i will most likely do the spring spacers a little later, does anyone know with a body lift if there as anything you have to do with the air conditioning unit if you put a body lift on, i know i see them advertised for vehicles with automatic trannys or manual trannys but also i see without airconditioning, just curious.
Old 07-22-2006, 04:11 PM   #14
otisdog
Here's what 33 x 10.50's look like on stock steel 7" wheels with 4" of lift. Works great for me.
jim
03 Sport
otisdog is offline   Reply With Quote
Old 07-22-2006, 06:25 PM   #15
kawa500fastred
AWESOME LOOKING jeep Jim
Glock Forum
