315/75/r16 vs 285/75/r16 on Rubi Moab Wheels fit? - JeepForum.com
post #1 of 11 Old 08-16-2012, 07:58 AM Thread Starter
emart
Im sure this question has been asked before, but I have been looking into and haven't found anything conclusive.
I currently have 33x12.5xr15 BFG TA/KO's on my Wrangler. I have a 4" lift and almost everything done to this that would need upgraded as far as adding a 35" tire to it. My question is will I be able to fit the 315/75/r16 tire on my vehicle without adding spacers? I recently bought 5 Rubi moab wheels (16") and am buying new tires. I am buying the treadwrights, but wasnt sure if I ordered the 315's, if I would have any rubbing. Does anyone have any experience with this size tire/lift combo? The specs from Treadwright only show a 1 lb difference between the 285's and 315's and a little over an inch more of actual height and width. I feel like they should fit.
Thanks in advance for the help, and I love pics if anyone has any with this set up.
‎2000 Jeep Wranger Sahara. 36,500 miles, 4.0l, 6-cylinder, Automatic. Hard top, soft top, and bikini safari top. 4" Teraflex lift and suspension all around, rock guards, custom front end, hitch, safari rack, 9000lb Warn wench, vinyl aftermarket seats. Front and rear air lockers. Kenwood DVD, stereo, and custom sub enclosure. Stereo sound bar.
emart is offline
post #2 of 11 Old 08-16-2012, 08:14 AM
Benderff
Benderff's Avatar
The 285's on Moab rims will rub a little even when the axle is perfectly centered. 315's will rub a lot without spacers. Be careful with the load range of those tires. The side walls can be heavy/stiff which really helps make for a ****ty ride.
Benderff is offline
post #3 of 11 Old 08-16-2012, 08:53 AM
Sundowner
You're fine on lift as far as clearance is concerned...I've got 2.5" plus a 1" BL and I run the 315/75R16 Falkens. However, you will need spacers in either case - with either tire size - to eliminate rubbing, and you'll need to adjust your steering stops. The big issue that you'll have is uptravel on your front tires; you need to either start thinking about how you'd like to high-line the fenders, or you need to bumpstop the **** out the spring perches...and now that I think about it, you'll actually need to go ahead and do both of those things if you want your suspension to actually work. Once you have the tires mounted, set the air pressure at about 23 lbs, cold...anything more than that and you start getting a jarring ride in the front.
Sundowner is offline
post #4 of 11 Old 08-16-2012, 09:00 AM
Eatlessdirt
I'm running 305/70 R16s on a 4" lift and 1.5" spacers with no rubbing issues at all. I will tell you that the the tires really stuff into the wheel wells at full flex. If you're going the size up, I second Sundowners comments about the fenders.
Eatlessdirt is offline
post #5 of 11 Old 08-16-2012, 10:14 AM
Punisher8738
Before I swapped wheels I had 315 Discoverer STT om stock moabs. Rubbed at full turn but washers placed on the steering stops fixed that..
Punisher8738 is offline
post #6 of 11 Old 08-16-2012, 12:59 PM
Fingers302
I've got 315 STTs on stock Rubi wheels - I used 1.25" spacers in the front and nothing in the rear. Your rear axle will need to be very centered because without any spacers it is close, but mine havent rubbed.
1.25" WHEEL spacers. The other spacers in my sig are spring spacers.
Fingers
06 LJ Rubicon, not stock
83 CJ 7, all stock
84 CJ7, dang near stock - Daily Driver!
Fingers302 is offline
post #7 of 11 Old 08-16-2012, 03:43 PM Thread Starter
emart
Great, thank you for all the info. I guess I will try the 1.25" spacers and go ahead and get the 315's. I guess the only thing i was worried about was rubbing on the outside lip of the fender with the spacers on there. It sounds like I should be ok though. Just makes me nervous ordering tires online and have them possibly not fit...
emart is offline
post #8 of 11 Old 08-16-2012, 06:56 PM
Sundowner
They'll fit... but if you want to control them you'd better get ready to spend a lot more money.
post #9 of 11 Old 08-21-2012, 07:14 AM
Fingers302
They will stick outside the fender flares, but the lift keeps them off. Its a no-go if they rub on the inside side wall against the spring perch.
Fingers
83 CJ 7, all stock
post #10 of 11 Old 08-21-2012, 09:35 AM
tommyduncan
I'm running 285/75/16s on Moab wheels. When I had a 2" front spring spacer they would rub at full turn in both directions in the front. I could never feel the rears rub but they left a mark on the fender wells so I guess they did at full stuff.
Now with a 4" lift and no wheel spacers they don't rub at all.
My spare is a 305/70/16. I'm curious if it will rub but they I haven't tried it yet.
tommyduncan is offline
post #11 of 11 Old 08-21-2012, 12:43 PM Thread Starter
emart
Im supposed to have them shipped next week. I went with the 285's just to be safe. I really wanted the 315's but I think this is the safer route. I will update once I get them installed.
emart is offline
2006 Rubi Moab Wheels Fit My 2000? Hunta TJ Wrangler Technical Forum 8 01-20-2009 08:55 PM
Can I rent JK Rubi in Moab? Meir10 JK Wrangler Technical Forum 13 09-20-2008 05:55 AM
Newb question...and my first post! (tire width on Rubi Moab wheels) zx5go TJ Wrangler Technical Forum 7 08-12-2008 12:20 PM
Pics of new JK Rubi Unlimited@ Moab (not in action though) m(a)ce JK Wrangler Technical Forum 15 05-16-2006 09:19 PM
05 Rubi sticking with the MOAB XRussoX TJ Wrangler Technical Forum 17 05-15-2006 09:38 PM
