31" spare on 4" offset steel wheel - already tried search - JeepForum.com
post #1 of 9 Old 02-20-2008, 06:25 PM Thread Starter
redsoxski
redsoxski's Avatar
I'll be putting on a set of 31" BFG ATs 15 X 10.5 on black steelies with a 4" offset. My question is - with this offset will I have any trouble mounting the spare on the stock carrier. I read the gazillion posts on 31" spares but couldn't find any talk about a 4" offset wheel. A few ID'd offset wheels as possibly requiring some mod to the rubber bumpers but they didn't specify the degree of the offset. Thanks for the help...
redsoxski is offline
post #2 of 9 Old 02-20-2008, 06:38 PM
CrunchTJ
My 33x12.5 on a 15x10 with 4" backspacing wouldn't fit on the stock carrier. There wasn't enough thread on the lugs to get the nuts on, and it was hitting the bumper. I had to buy an extension (then strapped it down with a ratchet strap because it bounced all over the place). Hated the extension, and finally replaced it with a bumper/tire carrier recently.
It's not a 31, but similar as the BS and the wheel size are the same as yours. Hope maybe that helps.
Try it and see. If it doesn't work, the extension is not that expensive.
'97 TJ: 2.5L, 4" Lift, 1" BL, 1" MML, 35's, 4.88's, Locker & Trutrac, Snorkel, Winch, Rockers, Snorkel, etc...
'06 XK: Limited HEMI 4x4 with QDII - DD
CrunchTJ is offline
post #3 of 9 Old 02-20-2008, 06:40 PM
92icbm
no problem
I have a 31x10.5x15 SSR on a cragar rim with 4" BS. It fits the stock spare tire carrier just fine. I didn't even have to space the 3rd brake light to clear it.
2000 TJ Sport, 4.0L, 5sp, 31x10.5 SSR, 3.73 gears, Warn M8000
92icbm is offline
post #4 of 9 Old 02-20-2008, 06:47 PM
92icbm
oops, I just noticed you asked about a 15x10. I doubt that would fit.
92icbm is offline
post #5 of 9 Old 02-20-2008, 06:50 PM
CrunchTJ
I think the 10.5 was for the tire width, not the wheel. I think 'I' was confused. He's probably in good shape, assuming the wheel is 8" or less.
CrunchTJ is offline
post #6 of 9 Old 02-20-2008, 07:00 PM Thread Starter
redsoxski
redsoxski's Avatar
Sorry - its a 15 X 8" wheel with 4" offset
post #7 of 9 Old 02-20-2008, 07:07 PM
TOP HVY
With steel wheels you shouldn't have a problem. If it were an alloy wheel you would, as the alloy wheel is much thicker which would cause you to run out of threads.
John
98 Jeep Wrangler Sahara
_______
--(O|||||||O)--
White Jeep Club Member #93
TOP HVY is offline
post #8 of 9 Old 02-20-2008, 07:35 PM
Death_Valley_TJ
4" of backspacing is 4" from rear of rim to the hub mounting surface. So it doesn't much matter the width of the wheel. If the tire gets too wide then that is a different story. I had 31x10.50x15 BFG AT/TA mounted on alloy 15x7's with 3.75 bs and it fit fine. The stock wheels have more backspacing than your steelies. The rub comes with the 3rd brake light. At the most you may need a coulple of washers to lift the light a little.
Death_Valley_TJ is offline
post #9 of 9 Old 02-21-2008, 03:09 PM
JoeyOPA
I have the same exact setup. No problems. Works fine.
JoeyOPA is offline
jk steel wheel offset wj03grandy JK Wrangler Technical Forum 4 05-27-2009 05:41 PM
OEM 16" steel wheel cap Matthew Davis JK Wrangler Technical Forum 5 06-13-2008 02:06 PM
stock 17" rubi wheel offset? GIJoe Driver JK Wrangler Technical Forum 2 03-08-2008 11:00 AM
7" stock wheel and 31" spare tire govols TJ Wrangler Technical Forum 7 06-21-2007 09:11 AM
31" with a steel wheel on tailgate? wingman TJ Wrangler Technical Forum 1 06-29-2003 09:39 AM
