31's and rear tire carrier bumpers - JeepForum.com
post #1 of 9 Old 02-24-2005, 06:18 AM Thread Starter
kaybone
So when putting a 31x10.5 with 4.5 Backspacing, black rockcrawler wheel on the stock rear carrier what do you have to do? Do you add more to the rubber bumper thingys, cut them down thinner, or are the just right?
Gun Metal Blue Jeep Club Member #99
kaybone is offline
post #2 of 9 Old 02-24-2005, 06:56 AM
onlyone
onlyone's Avatar
2014 JK Wrangler
31's should fit fine on your tire carrier.
Thank you Jesus
2014 Wrangler Sport 1.5" spacers in front .75 rear, 1" BL 255/80/17 BFG KM2
onlyone is offline
post #3 of 9 Old 02-24-2005, 07:41 AM Thread Starter
kaybone
Did you do anything with the rubber thingies?
kaybone is offline
post #4 of 9 Old 02-24-2005, 07:41 AM
Joe-K
I had to cut my Rubber bumpers down by about 1/2" as the wheel studs on the tire carrier were too short to reach through the spare tire wheel. That was with 31x10.5 tires on the stock 15x7 steelies. I couldn't get the lug nuts on to hold the wheel
Now I just picked up a set of 15x7 MT classic wheels with 3 1/2 BS and I'll most likely have to extend the black bumpers since the wheel will be further out
Joe-K is offline
post #5 of 9 Old 02-24-2005, 08:06 AM
doubleA
doubleA's Avatar
i have 31 x 10.5 on my stock carrier and have no problems with it at all. if it doesn't fit just shave back those bumper stops and it will fit.
97 TJ 4.0
32" MTR
Cragar 397
2" RE BB
1" M.O.R.E. Body Lift
XD9000i Warn Winch
Lockright Rear Lockers
Dual Optima Batteries
Mean Green Alternator
Rancho Steering Stabilizer
doubleA is offline
post #6 of 9 Old 02-24-2005, 08:34 AM
ColoradoTJ
ColoradoTJ's Avatar
I have 31x10.5's on my stock carrier but mounted on stock wheels. It's a tight fit, with that much back spacing you will need to cut the rubber stops or get longer bolts.
Clint
"If we weren't all crazy we would go insane" J.B.
ColoradoTJ is offline
post #7 of 9 Old 02-24-2005, 03:36 PM
davenjeip
davenjeip's Avatar
I run 31x10.5's on stock Canyons. With my backspacing, my problems were worse than yours would be.
They would not allow my tailgate to close completely so I just removed the lower bumpstop under the tailgate.
I will add that the tailgates and tire carriers seem different on different Jeeps. I was at a meeting spot for a ride i was going on and we started comparing spare tires on different Jeeps. I was amazed to see that, even with same sized tires, some only missed the bumper by a hair and some had an inch or more of clearance. This was all with stock carriers and stock bumpers.
2003 TJ
www.davenjeip.com
davenjeip is offline
post #8 of 9 Old 02-24-2005, 05:59 PM
Penuche
Penuche's Avatar
I second that - i've got the same setup as you and i've had no issue keeping the wheel on the carrier, and i've got about 3/4 inch between bumper and bottom of tire. Go figure!
00 Sport ...black, of course
Penuche is offline
post #9 of 9 Old 02-24-2005, 06:34 PM
Ludoc
Ludoc's Avatar
If the rubber stops are not touching the tire, do you recommend extending them? And if you do recommend extending them, any suggestions like washers or something cheap? Im running 31x10.5x15s on American Racing Bursts.
RED 04' TJ - 2.4 4 In Lift, 31" Courser M/Ts, 4.56 gears, JKS Discos, Aussie Auto Locker
Just a basic Jeep... nothing special.
Ludoc is offline
Spare tire carrier bumpers - how much contact with tire is enough? aberrant TJ Wrangler Technical Forum 11 01-23-2010 05:52 PM
Tailgate tire carrier and 31's? Dantheshan YJ Wrangler Technical Forum 6 07-09-2009 09:10 AM
Stock Tire carrier: 31's and cragar soft 8s in 15x8. Will it be okay? Sia Bani TJ Wrangler Technical Forum 20 03-09-2008 05:15 PM
Stock Tire Carrier and 31's ryobi TJ Wrangler Technical Forum 19 05-05-2007 09:34 PM
Extensions for Rubber Rear Tire Carrier Bumpers? twofish TJ Wrangler Technical Forum 4 08-05-2005 11:43 AM
