30's or 31's on Grizzly's? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 30's or 31's on Grizzly's?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineIncome tax season is upon us. We got what u needGet 5% Back On Rugged Ridge-Omix-ADA-Alloy at ExtremeTerra
Unread 11-26-2013, 07:49 AM   #1
kitjunkie
I just picked up a set of Grizzly's for my '05 TJ. I'd like to put 31's on them, but I'm worried that the 7" width of the rim is too narrow. Am I better off with the 9.5" wide 30's? Would there be a substantial difference in how it looks between 30's and 31's?
Thanks
kitjunkie is offline   Reply With Quote Quick reply to this message
Unread 11-26-2013, 07:50 AM   #2
kitjunkie
I should note that I won't be using spacers...thx
Unread 11-26-2013, 07:50 AM   #3
JBTJ
A 7" rim is fine for either 30" or 31" tires.
JBTJ is offline   Reply With Quote Quick reply to this message
Unread 11-26-2013, 07:56 AM   #4
apaTJ
Ya you'll be fine with either. I'd say go 31s. Not a huge difference but you'll notice the width.
apaTJ is offline   Reply With Quote Quick reply to this message
Unread 11-26-2013, 09:27 AM   #5
Cavasar
No Longer DD
Cavasar's Avatar
We ran 31x10.5s on the TJ with Grizzly's for probably 10 years.
Cavasar's TJ
May TJ of the Month 2015
Cavasar is online now   Reply With Quote Quick reply to this message
Unread 11-26-2013, 09:37 AM   #6
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Tire width is the important factor when asking if a tire fits a wheel, not tire height.
Anything up to 10.50 wide is fine when using Grizzly wheels on a TJ without wheel spacers.
Wheelin98TJ is online now   Reply With Quote Quick reply to this message
Unread 11-26-2013, 12:57 PM   #7
kitjunkie
Thanks everyone. It sounds like 31's are the way to go.
Appreciate the feedback.
Unread 11-26-2013, 03:40 PM   #8
Ed209
Heads up - Do some searches in this forum as well as the wheel/tires forum, and you'll see that some guys ran into clearance problems with 31's, which required adding washers to the steering stops to prevent rubbing the control arms.
Ed209 is offline   Reply With Quote Quick reply to this message
