304 swap or Stroker kit - JeepForum.com
post #1 of 13 Old 08-10-2010, 07:50 PM Thread Starter
rinoz10
Sorry if this is a dead horse, I did a search on here and didn't find much. I can get a AMC 304 really cheap would that be better than doing a stroker kit? Also has anyone done the 304 swap?
rinoz10 is offline
post #2 of 13 Old 08-10-2010, 08:03 PM
cpleasant
cpleasant's Avatar
Check your emission laws. Odds are that the 304 won't be legal.
Originally Posted by liredneck View Post
I know your rite I seid the dealer seid the same thing as you and that I don't want them there , but I was asking another qeustin as in what do I do about the slots in the brackets couse if I just put a bolt in there it will slide back and fourth but again thank you all knowing and powerfull jeep god sorry us lesser jeep peeons might have some more qeustins in the future , so please if there to much for you sit back relax go to the next post
cpleasant is offline
post #3 of 13 Old 08-10-2010, 08:20 PM
chris142
x2. Plus I don't think a 304 would be a good choice over the 4.0L. A 360 or 401 is the same size as a 304 and would be a better choice.
chris142 is offline
post #4 of 13 Old 08-10-2010, 08:56 PM
RickyR
You won't find any company offering an engine/transmission mount for a TJ/AMC swap.
How do I know? I put a 401 in my LJ
If your state has any type of emissions inspection program, I doubt it will pass.
A 304 sounds a lot better than a 4.0, but in reality the 4.0 is much more durable and is already fuel injected.
Cheap isn't always the best way to go. For me, I already had the entire running gear from my CJ (engine, trans, tcase, and axles). and it still cost me mucho dinero. One thing always leads to another......
If that doesn't scare you, start collecting parts and dollar bills. The AMC engines will bolt to the Jeep stuff, but newer jeep stuff won't hold up to too much abuse.
Good luck, Ricky
RickyR is offline
post #5 of 13 Old 08-10-2010, 09:29 PM
Sundowner
Stroker, if you have to have it in the first place. Better to spend your money on gears, suspension and ground clearance, though...
Sundowner is offline
post #6 of 13 Old 08-10-2010, 09:30 PM
WILLY348
Stroker all the way man.. why take a step back in time
2003 Jeep Wrangler Sport: Current Jeep
2006 Jeep Wrangler Unlimited: (Sold and missed!)
2004 Ford Mustang Cobra
WILLY348 is offline
post #7 of 13 Old 08-10-2010, 11:28 PM
LJameson
Stroker. I have a 304 and a 4.0 equipped Jeeps in my driveway and the 4.0 would run circles around the 304.
1990 YJ-The wheeler
2015 JK- The DD
LJameson is offline
post #8 of 13 Old 08-11-2010, 12:07 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Ohio does not have smog laws.
I can't imagine a 4.0 I6 ever running better than a 304.
Every 304 I have ever drove or owned has run much better than all the 4.0 I6 motors I have owned.
The big downside with the 304 is the carb.
Wheelin98TJ is online now
post #9 of 13 Old 08-11-2010, 12:13 AM
fratis
fratis's Avatar
bazaar ive had the opposite expereince. the 304 always needed something and it was a dog of a v8. ive done nothing to the 4.0 in 15 years. cant imagine ever going back to a carb offroad.
fratis is offline
post #10 of 13 Old 08-11-2010, 10:17 PM Thread Starter
rinoz10
I guess what it will really come down to then will be if its hard to find parts for the 304, thanks for the insight guys!
rinoz10 is offline
post #11 of 13 Old 08-11-2010, 10:22 PM
pmccoy9876
It depends on what county in Ohio you live in. Medina county (where I live) has a required e-check using your OBD II port every 2 years, therefore I could not do this swap. Cuyahoga county (Friend in Strongsville) has no e-check, so you could (probably) legally do the swap. That's definitely something to check out with your county before you pull the trigger on the 304.
As for the "V8 vs. 4.0" debate, I can't say, having never driven a 304, but I will say my little brother's 305 camaro isn't that impressive to me as far as V8s go. I know of several V6 cars that would handily outperform it. But then again, it does sound great, being a V8 and all. At the end of the day, I'd say spend the money elsewhere, like lockers, if you already have it and wheel it.
Originally Posted by MrNate View Post
Are you insane? Do you have any idea how many slip-and-fall accidents are caused by carelessly discarded banana peels? This is a crime of Vaudevillian proportions and must not be tolerated in a civilized society.
Originally Posted by RyanCJ2A View Post
I have no input of any value to this thread but those are awesome.
pmccoy9876 is offline
post #12 of 13 Old 08-11-2010, 11:00 PM
Wheelin98TJ
JEEP FREAK
I never knew that about the Ohio localities in regards to smog laws.
It makes perfect sense though since Ohio has so many other laws that are specific to the locality. I should have excersied more care when I made that previous incorrect comment.
Thanks for correcting me so politely and for pointing this out.
I'm also thinking more about the 304 V8 and those I have experience with were not stock motors.
Maybe I should check out of this thread.
post #13 of 13 Old 08-11-2010, 11:06 PM
Fropleyqk
Fropleyqk's Avatar
My last CJ5 had a 304 in it. It sounded great and was trouble free but was a dog of a V8. I would definitely recommend against it. Its going to take a lot of $$$ to make that work. You could build a CJ around the 304 for around the same cost of swapping it into your TJ. If there's nothing wrong with your 4.0, spend the money elsewhere. Jeeps arent hotrods.
Fropleyqk is offline
304 , engine swap , stroker
4.7 stroker swap NEED HELP Shalayko94 YJ Wrangler Technical Forum 23 08-20-2010 02:20 PM
Need help planning a v8 swap. Or should I do a stroker? jaminb YJ Wrangler Technical Forum 6 10-04-2009 11:20 PM
STROKER swap?? hatchtegman YJ Wrangler Technical Forum 4 07-26-2009 04:56 PM
4.7 stroker swap SleddinJeeper YJ Wrangler Technical Forum 7 11-15-2008 12:34 PM
V8 swap vs. The STROKER tylerdvdsn TJ Wrangler Technical Forum 30 07-15-2008 08:44 AM
