#1 | |
30,000 mile service
I had my oil changed at the dealership the other day, and they gave me an estimate on what is recommended at 30K. Front and rear axle service, auto transmission service, and engine tune up. Total was around $550. I think I can do this stuff myself.
1) Front and rear diffs- I've got write ups from Stu's, 4x4explor, and US41.org. Drain, clean off old gasket, new gasket, fill. Some refer to putting a friction modifier additive into the mix. Is that all there is to this? I think my diff 2) I think the transmission write ups I've seen are for manuel, is the auto about the same? Open fill hole, open drain hole and drain. Refill. Is that all there is to that? 3) Besides new spark plugs and air filter is there anything else done in an engine tune up? My motor is a 4.0, The TJ is an 04 auto, D35 axle, I may have to further identify the automatic transmission, unless there is just one standard trans in TJ's. I plan on having all the proper tools; torque wrench, scraper, allen sockets. anything else? thanks for your input.
#2 |
I've got my 30k service interval coming up real soon also. I decided it was a good time to switch all my fluids over to full synthetic. My bill to Amsoil was just over $100 for all the fluids, an oil filter, and a hand pump for filling diffs. I bought a set of Champion 4412 plugs, and an ACDelco air filter a while back. All I need now is a gasket scraper, some brake cleaner, and some RTV. So I figure it's costing me ~$150 and that's going all out.
I've got a manual tranny, so I can't speak to the automatic, but your list sounds pretty good. Don't forget to get under the front end and grease the fittings on the steering components.
'03 Bright Silver Metallic TJ Sport BSMCCEP Club Member #45 Stock: 4.0L I6:5-speed:3.07 gears:D35 with Trac-Loc:15x7 Ecco wheels:Dual Top Group Mods: 30x9.5 BFG A-T T/A KO's:JKS Quicker disconnects:Rock-It Man rocker guards:Jeep Medic oil pan/tranny skid:Kilby steering skid:Warn D30 diff guard:C4x4 D35 diff guard:Rusty's radiator guard:Skid Row LCA skids:SilverStar headlights and fogs:Hidden Hitch class III receiver:Old Realistic 40ch CB:2' Firestik II:Arizona Rocky Road tailgate antenna mount Next : Jeeperman rear bumper '06 Candy Orange Honda Shadow Spirit 750 |
#3 | |
Gun control: "The ability to hit your target" |
#4 |
There is no drain plug on an auto unless you have a aftermarket style pan. Just be sure to use DC atf+4 fluid [dealer only atleast I couldn't find it in any stores]in the trans wouldn't want to void your warranty. The diffs are a peice of cake just jack it up high enough to get under the rear. about 2 qts each f&r. The rest of a tune up is all comoon sense stuff.
#5 |
DC recommends changing spark plugs with only 30,000 miles? Strange.
2002 Wrangler Sport 4.0L 3 Speed Auto DPG Offroad "Ultimate TJ" Old Man Emu lift kit 33x12.50 BFG All Terrains American Racing Diamond Back 15x8" rims 1.25" JKS Body Lift and 1" JKS Budget Motor Mount Lift 4.10 Gears with Alloy USA Grande 35 w/ OX Locker |
#7 | |
#8 | |
#9 | |
03 TJ's should be running NGK's not champion..just FYI |
#10 | |
The fluid won't void the warranty unless DC gives it away for free. That is the only way a manufacturer can legally require you to use their own brand of fluid. However, they can say that whatever fluid you use has to meet certain standards.
2004 Yellow Sport - AA SYE, 4" Long Arm Lift, ARBs front and rear, sPod switch panel, 33x12.50 Goodyear MT/R, SuperWinch EPi9.0 on a dicked up AtoZ mount plate (you suck AtoZ!) Bunch of other small stuff with steel and a mig in the garage for making new bumpers Homebuilt Stroked Hardtail Tons o Guitars Life is Good |
#12 | |
#13 | |
#14 | |
#15 | |
Jepp rccomends flushes untill you reach 100k then a filter change. If my tranny last to 100k with a supercharged 4.0 I will be suprised so I will probably never change my filter. |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
