3 speed auto to 5 Speed Stick Trans Swap - JeepForum.com
post #1 of 11 Old 09-22-2010, 12:41 PM Thread Starter
GPERSCREEPERS99
GPERSCREEPERS99's Avatar
I am thinking about doing this...Has anyone done it? Any write ups? I tried to search but I am not having luck looking for what I want.
I did this in My Mustang a year ago and it was no big deal but I would like to know what I am getting myself into before I start trans shopping.
99 Jeep Wrangler built on 35's
82 Aqualu Aluminum Scrambler Chevy 350 on 33's
14 JKU Rubicon My Daily Driver
12 Grand Cherokee Wife's Daily Driver
GPERSCREEPERS99 is offline
post #2 of 11 Old 09-22-2010, 12:44 PM
turtlerace
Best taken in small doses
turtlerace's Avatar
1979 J-Series Truck
Drive it down here and we will swap parts for parts in my garage!
turtlerace is offline
post #3 of 11 Old 09-22-2010, 12:50 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Why? Most offroaders want to go the other direction, from the 5-speed to the 3-speed automatic. That is what I converted my 5-speed to and the offroad results were worth the time and effort.
Jerry Bransford is online now
post #4 of 11 Old 09-22-2010, 12:55 PM
snowrydr01
your ECU will work but your going to get CEL when the computer tries to activate the TC lockup. No way around this besides reflashing what you have or getting a new ECU and reflashing your vin into it. Im running into the same thing planning for a 32rh to aw4 conversion
snowrydr01 is offline
post #5 of 11 Old 09-22-2010, 01:05 PM
Jerry Bransford
Administrator
No need to reflash the VIN into the ECM. I swapped the ECM to an automatic style when I did my transmission conversion and all I made sure was that it came out of a '97 with the 4.0L and automatic and it worked fine.
post #6 of 11 Old 09-22-2010, 01:06 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
i did this swap in June. it was pretty straight forward.
Mail crawling.
MisfitSeven is offline
post #7 of 11 Old 09-22-2010, 02:10 PM
snowrydr01
How does inspection work in your state? Ours (PA) does OBDII and any "inconsistency" is an automatic fail. I was under the impression that the vin would show up when they plug in.
post #8 of 11 Old 09-22-2010, 02:43 PM
Jerry Bransford
Administrator
My TJ passed California's smog test without a problem after installing the new ECM. From what I can tell, Calif's smog test is the strictest in the U.S.
post #9 of 11 Old 09-23-2010, 06:58 AM
snowrydr01
Thats how NJ was (coppied the Cali one) but in Pa they take an easier route of just plugging in the OBDII slot and failing you if anythings amis. I use to get 02 sensor codes and cleared it before i went. Luckilly the guy was cool enough to tell me to come back the next week because the clear was too recent and would be a fail.
post #10 of 11 Old 09-08-2011, 12:29 PM
kevlarmenace
I know this is a little out of date, but I am planning this as well (the third A/T is on it's last legs, and I don't want to put another one in) and I wanted to know about how much time it took you, or what parts cost. I hate the three speed.
kevlarmenace is offline
post #11 of 11 Old 09-08-2011, 03:01 PM
lukepeterson21
Yeah I am also interested in doing this! Would love to know about your process and all the required parts for all of this?
lukepeterson21 is offline
Idle Speed with Auto trans Nonya TJ Wrangler Technical Forum 5 12-12-2008 12:55 PM
Might Swap 6-speed manual for 4-speed auto... JeepinYahoo TJ Wrangler Technical Forum 14 11-15-2006 07:20 PM
swap from 3 speed auto to 4 speed auto bulldogg TJ Wrangler Technical Forum 5 11-15-2006 05:01 PM
Have 6-speed manual swap in a 4-speed Auto? JeepinYahoo TJ Wrangler Technical Forum 8 11-13-2006 03:18 PM
The 4 Speed Auto Trans? Ragtop_Rob TJ Wrangler Technical Forum 8 07-16-2005 10:32 AM
