3 questions with easy answers !?! - JeepForum.com
post #1 of 20 Old 10-01-2008, 05:05 AM Thread Starter
jeep2008
1)i ordered some Adjustable Rear Cam Bolts from 4wd.can you tell me their use?i mean installing them is easy but how would you know how much to adjust if at all your differential angle?i have a re 2'' bb and a tc 1'' drop from ome but i still have some slight vibe at certain cases and speed.will these help at all? 2)are the front lower arms the same as the back lower arms in the tj?i have these in the front http://www.rubiconexpress.com/Produc...=687DEA7556458 can i use these also for the rear? 3)i've ordered these http://www.quadratec.com/products/56214_100.htm to upgrade my brakes and my faded pads.are they any good,noise ,dust etc?anyone have them? thats it!!thank you
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #2 of 20 Old 10-01-2008, 05:23 AM
robncar
robncar's Avatar
1. I wouldn't use cam bolts in an attempt to remove driveline vibes. You have to slot your control arm mounts. Not worth it for the limited adjustment you'll get. I'd try a couple washers with the t-case drop. Next, perhaps a 1" MML.
2. The RE3705 on a TJ is front and rear.
3. Seems like many folks are liking the Centric Rotors and EBC "Yellow Stuff" pads for the front. For the rear, Centric Rotors (if you have rear discs) and EBC "Green Stuff" pads.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #3 of 20 Old 10-01-2008, 02:52 PM Thread Starter
jeep2008
ok about no 2 but about no1:what do you mean slot the control arm mounts?do you know where i can find pictures or instructions on how to do the adjustment?on no 3 now anyone with feedback about the hawk pads?
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #4 of 20 Old 10-01-2008, 07:16 PM
DRZAP
I got sucked into buying the both front and rear because I am replaceing control arms. The bolts from 4wd Hardware for the front were right but the 2 for the rear which my 98 does not have adjusters (I now know) are half the diameter.
DRZAP is offline
post #5 of 20 Old 10-02-2008, 02:07 PM Thread Starter
jeep2008
bump for some more answers!thank you
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #6 of 20 Old 10-02-2008, 02:25 PM
otisdog
2008 WK
On #1 what he means is to try putting a few washers between the big transfer case skid and the frame. This will drop the rear of the engine/tranny/t-case lessening the angle on the rear driveshaft. Do you already have a t-case drop that came with the lift? If so there will be a space between the skid and the frame. The MML he speaks of is a 1" motor mount lift that raises the front of the engine etc haviong the same effect.
I'd send the cam bolts back and get your money back.
NOTE - I see that you already have a 1" drop on there - are you sure that you don't have too much drop or if you are really getting driveline vibes? Doesn't seem like it with only a 2" budget boost. Generally a few washers to get a 1/2" drop will do the trick for that.
Jim
Your driveshaft angles should look something like this
08 Grand Cherokee Overland
otisdog is offline
post #7 of 20 Old 10-02-2008, 03:17 PM
durango-bob
2006 WK
I agree that you should do everything and anything needed to avoid using the cam bolts. The do not hold their adjustment and then you have to weld to fix it. The rear axle has holes with embossments that are provided as a location for you to knock out metal to make a slot. The knock-outs, however, do not just knock out, you have to drill and grind to make the slots. Then after you finally realize that the bolts don't stay put, you have to weld washers on the brackets to restablish the holes.
durango-bob is offline
post #8 of 20 Old 10-03-2008, 02:04 AM Thread Starter
jeep2008
ok,i got it now,i really thought it was going to be as easy as the fronts !anyway ,does anyone has put them on and done the slots?is there a write up of some kind anywhere for the installation of the rear adjustable cam bolts?
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #9 of 20 Old 10-03-2008, 04:26 AM
durango-bob
2006 WK
I did install a set. Here are the steps:
1. Remove the lower control arms.
2. Drill out the metal for the slots and grind them into the correct slot shape.
3. Reinstall the lower arms with the new cam bolts.
4. Set them as far as you can to adjust the pinion the way you want.
5. Scratch your head and think because they don't provide enough adjustment.
6. Tighten it and drive it and find you still have vibs.
7. Check them out after a week and find that they have loosened and are way out of adjustment.
8. Repeat steps 6 and 7 until you convince yourself that you should have listened to this forums advice in the first place.
9. Weld washers on the axles to eliminate the slots and drop the tcase a bit more to eliminate the vibs.
10. Throw the cam bolts in the trash.
post #10 of 20 Old 10-03-2008, 04:37 AM Thread Starter
jeep2008
what can i say,you are a fun guy
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #11 of 20 Old 10-03-2008, 05:01 AM
vector6
the rear cam bolts go in the UPPER axle mounts.... not the lower.
i ran them for 3 years in my 01 sport, they never came loose.
vector6 is offline
post #12 of 20 Old 10-03-2008, 06:28 AM Thread Starter
jeep2008
oops!
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
post #13 of 20 Old 10-03-2008, 06:36 AM
ssdude
Is your vib. when you take off and put torq. on the axle or when you are up to speed ? I had a vib. only when I took off hard from a dead stop after I installed a 2 1/2" lift. I found that the rear pinion angle and the driveshaft were perfectly aligned so there was no preload on the U joint causing the vib. I installed longer lower control arms to bring the pinion angle down and the vib. went away. I installed the cam bolts first and they didn't have enough adj. so I agree they seem to be a waist of time.
ssdude is offline
post #14 of 20 Old 10-03-2008, 07:50 AM
chichum
Originally Posted by jeep2008 View Post
oops!
haha i hate it when that happens
chichum is offline
post #15 of 20 Old 10-03-2008, 01:46 PM Thread Starter
jeep2008
vector6 can you be more specific?do they go to the rear upper control arms then?please more answers!!
No Jeep right now
04TJ (SOLD)
01TJ (SOLD)
jeep2008 is offline
Herculiner How To, with questions and answers!! Jeebs YJ Wrangler Technical Forum 222 11-29-2014 01:03 PM
lift questions , ive searched but no definite answers XlostJeepX TJ Wrangler Technical Forum 5 09-01-2009 06:45 AM
350 conversion questions (hopefully answers) demoguru YJ Wrangler Technical Forum 1 11-25-2008 10:07 AM
Frequently Asked Questions (FAQ) Your Answers Are Usually Here! NaeKid YJ Wrangler Technical Forum 16 12-16-2007 11:10 PM
Three quick questions I couldnt find answers to redline73 JK Wrangler Technical Forum 12 12-07-2007 12:58 PM
