3'' offset on rims, good or bad??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 3'' offset on rims, good or bad???
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 12-28-2009, 04:32 PM   #1
hulud44
Im looking into these rims.(link on bottom) i have a small rubbing problem hitting the driverside lover control arm on left hand turns. i have the crager soft 8s now with a 4.25 in offset. i want the 3 in offset for the wider stance but will it be too much ware and tear on ball joints, u joints, ect.....???????
Aero Race Wheels 50-184530S - Aero 50 Series Roll Formed Wheels - Overview - SummitRacing.com
hulud44 is offline   Reply With Quote
Unread 12-28-2009, 04:46 PM   #2
Border Dave
Got Sand?
Originally Posted by hulud44 View Post
... i have a small rubbing problem hitting the driverside lover control arm on left hand turns. i have the crager soft 8s now with a 4.25 in offset. i want the 3 in offset for the wider stance but will it be too much ware and tear on ball joints, u joints, ect.....???????
The number you're referring to is called backspacing. Anywhere between 3.75 and 4.5 inches of backspacing seems to be the norm with 35x12.50s and 33x12.50s. Three inches of backspacing isn't horrible, but you do want to avoid it if you can. Like you said, too much stress on the hub/ball joints, etc. In order to stop your rubbing, just add a washer or two under your steering stops. It's very easy and only takes about two minutes.
edit: Here's a link on how to adjust your steering stops. http://www.stu-offroad.com/steering/...teerstop-1.htm
Border Dave is offline   Reply With Quote
Unread 12-28-2009, 08:56 PM   #3
BlueFlame
3" will be really wide.
You don't want to use those wheels anyway - you did notice they aren't even DOT approved for highway use?
BlueFlame is offline   Reply With Quote
Unread 12-29-2009, 07:36 AM   #4
hulud44
thanks . ended up going with US wheels series 84. 3.75 in offset.
