3" Lift - Trackbar relocation bracket - front - JeepForum.com
post #1 of 8 Old 10-19-2007, 09:56 AM Thread Starter
azcoyote
azcoyote's Avatar
Seems like it would bring the axle back to spot on center.
Anyone seen one of these or know how well they work?
http://www.4wd.com/productdetails.aspx?partID=8781
also, would you really need a new dropped pitman?
Thanks,
JEEPLESS... :(
azcoyote is offline
post #2 of 8 Old 10-19-2007, 10:33 AM
TheBoogieman
Deeply Disturbed
TheBoogieman's Avatar
They work fine.An adjustable track bar is better if you want to spend the money.NO dropped pitman arm! It will screw things up
TheBoogieman is offline
post #3 of 8 Old 10-19-2007, 10:38 AM Thread Starter
azcoyote
azcoyote's Avatar
Have you seen this specific product or are you commenting on relocation brackets in general?
Figured an adjustable is better but sometimes cheaper is the need...
JEEPLESS... :(
azcoyote is offline
post #4 of 8 Old 10-19-2007, 10:43 AM
Nikos
you need a pitman arm. this bracket relocate the front track bar mounting location at the frame 3" , you need to make your drag link parallel to track bar again.
2000 tj 2.5l 4.56 dana 30 aussie locker /super35 ARB, 35s maxxis crawlers, RE3.5sf, RE monotubes, 1"BL, currie anti-rock, currie steering, or-fab cage,ARB bull bar, warn m8000
Nikos is offline
post #5 of 8 Old 10-19-2007, 10:50 AM
TheBoogieman
Deeply Disturbed
[QUOTE=azcoyote]Have you seen this specific product or are you commenting on relocation brackets in general?
In general.
post #6 of 8 Old 10-19-2007, 11:14 AM Thread Starter
azcoyote
azcoyote's Avatar
Sounds like adjustable front track bar is the better way AND more cost effective then... Well, I guess now to find a erasonably priced front track bar....
Thanks,
JEEPLESS... :(
azcoyote is offline
post #7 of 8 Old 10-19-2007, 11:22 AM
DaOne
DaOne's Avatar
True. This specific bracket requires the use of a dropped pitman arm. Personally, I wouldn't use it, but there is a guy I work with that runs this and likes it.
EDIT: I agree that an adjustable track bar is the way to go...
...Sometimes, the more you see, the less you understand...
I miss my Jeep. On the hunt for a replacement.
DaOne is offline
post #8 of 8 Old 10-19-2007, 12:35 PM
archer75
It will screw things up if you don't use one, you have to keep that track bar parallel and if you drop the track bar you must also use a drop pitman arm.
archer75 is offline
Front trackbar relocation by drill and rear trackbar relocation bracket install? loudog3114 TJ Wrangler Technical Forum 20 10-26-2014 07:01 PM
Front Trackbar Relocation Bracket Jeep1067 TJ Wrangler Technical Forum 19 01-28-2010 05:32 AM
skyjacker 4" rear trackbar relocation bracket? 01solartj TJ Wrangler Technical Forum 1 03-16-2009 03:23 PM
Will I need a trackbar relocation bracket with rear adjustable trackbar FLATFENDER54 TJ Wrangler Technical Forum 3 02-05-2009 03:35 PM
JKS trackbar relocation bracket (front) BNovak TJ Wrangler Technical Forum 0 11-16-2006 05:55 PM
