3 inch zone suspension lift - JeepForum.com
post #1 of 56 Old 10-05-2011, 10:03 PM Thread Starter
04rockymnttj
I bought a 3in zone lift and im just wondering if I need anything that isnt with lift kit I have the alinement cam bolts from my 2in zone bb lift. also i bought quick discos with the two inch im just wondering if i can use those as well.
04rockymnttj is offline
post #2 of 56 Old 10-06-2011, 05:33 AM
durango-bob
2006 WK
The quick discos should still work but I would ditch the cam bolts. My experience with them is that they do not hold their adjustment for even a few days. I tried them and ended up welding plates over the slots and using adjustable arms. Does the kit have a T-case drop?
durango-bob is offline
post #3 of 56 Old 10-06-2011, 06:33 AM Thread Starter
04rockymnttj
Yes it does 3/4 inch
Lets go UK!
post #4 of 56 Old 10-06-2011, 07:06 AM
cjkwiatk
I just installed the Zone 3". The kit comes with everything you need. The only thing I had to purchase is new bolts for the rear shocks...
cjkwiatk is offline
post #5 of 56 Old 10-06-2011, 07:11 AM
youngjeepguy
yep, I just put that lift in mine last week. Only thing I needed to buy was sway bar disco's, other then that everything is there and it rides way better then it was before.
youngjeepguy is offline
post #6 of 56 Old 10-06-2011, 09:04 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
I had that lift and installed a MML instead of the t case drop.I added 3/4" spacers up front for a more level stance and re-drilled the axle side front track bar bracket instead of buying an adjustable track bar.
TheBoogieman is offline
post #7 of 56 Old 10-06-2011, 09:11 AM Thread Starter
04rockymnttj
Awesome I can't wait to install it so has anyone had problems with it
Lets go UK!
post #8 of 56 Old 10-06-2011, 09:11 AM
NAlbertaTJ
I;ve had the Zone 3" lift in for a little over a year now. For the most part I am satisfied, the ride is a little rough, but for the most part its good. As far as everything you need, yeah the basics are all there. However, I just ordered a full set of Savvy adjustable CA's because I wanted to get my pinion angles right again. Also, I will be doing the MML and losing the TC drop. I still have vibes with the TC drop.
NAlbertaTJ is offline
post #9 of 56 Old 10-06-2011, 03:40 PM
Bomber65
I just purchased the Zone 3" kit, JKS front adjustable track bar and steering stabilizer. But I didn't purchase the cam bolts. Should I order these? The lift isnt installed yet.
Bomber65 is offline
post #10 of 56 Old 10-06-2011, 04:19 PM
alex211
1995 XJ Cherokee
I didn't use cam bolts when I did the 3" lift, it could use a little more caster in the front but it's good enough for now. I'm going to get some rokmen control arms anyhow. The rear shaft is fine with a mml and stock arms, I have a rubi though.
95 xj bone stock for now
alex211 is offline
post #11 of 56 Old 10-06-2011, 04:32 PM Thread Starter
04rockymnttj
Well I be ok if I just use the stuff in the kit And get other stuff as I need it down the road
Lets go UK!
post #12 of 56 Old 10-06-2011, 06:49 PM
NAlbertaTJ
Yeah you should be. The cam bolts are needed though. I didn't have them when I installed the lift but when I went to get an alignment they installed them for me.
post #13 of 56 Old 10-06-2011, 07:06 PM
Bomber65
When you doing the install? I should have mine done next Monday or Tuesday. I didn't like the idea of drilling the hole for the trackbar so I got the adjustable front trackbar also. Hopefully that works out.
Bomber65 is offline
post #14 of 56 Old 10-06-2011, 07:19 PM Thread Starter
04rockymnttj
I will be getting the lift the 11th or so and will hopefully put it on that Saturday cause im going with outback adventure on Sunday. I have the cam bolts on there from my previous lift and I have quick discos that I hope I can still use
Lets go UK!
post #15 of 56 Old 10-06-2011, 07:35 PM
alex211
1995 XJ Cherokee
I might go to the out back adventure, here's what I did at the last one. I got it fixed though, new rad, fenders, and some other stuff.
alex211 is offline
3 inch zone lift jeepguner TJ Wrangler Technical Forum 15 03-08-2012 04:59 AM
Zone Suspension 3 or 4 inch kit LiveAndLearn TJ Wrangler Technical Forum 27 03-26-2011 08:01 AM
ZONE OFFROAD 3 inch LIFT Mccoy11x TJ Wrangler Technical Forum 0 03-14-2011 08:36 AM
4 inch ZONE lift kit jeepNB JK Wrangler Technical Forum 3 04-20-2010 06:37 AM
3 inch zone suspension, 3/4 spring spacer and BFD 33x10.5's smokediver1975 TJ Wrangler Technical Forum 13 04-07-2010 06:36 PM
