3 inch zone lift install problem help please - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 3 inch zone lift install problem help please
RuffStuff Memorial Day Sale!Poison Spyder to donate 10% of Memorial Day W/E Sales to RNEW JK All Terrain Bumper and X-Style Stryker Stinger - 20
Unread 04-14-2012, 10:12 AM   #1
jeepguner
ok instaling my lift on the back the shocks came with the top bushing and bracket installed so i cant get the boot over it and cant get the metal braket out at a stand still help
jeepguner is offline   Reply With Quote
Unread 04-14-2012, 10:25 AM   #2
dieselcrackel
Did mine the other day. used some soap and water and stretched it over the bar pin. pain in the butt but got it without ripping the boots.
dieselcrackel is offline   Reply With Quote
Unread 04-14-2012, 10:26 AM   #3
jeepguner
tried that and no luck any way to get the bar pin ont
Unread 04-14-2012, 01:11 PM   #4
Maxxram
I personally never run shock boots anymore. They can actually trap dirt in them and that could lead to shock damage.
I would say leave them off and problem is solved.
Maxxram is offline   Reply With Quote
Unread 04-14-2012, 01:24 PM   #5
TINSTAR
I used a vice to push the bar pin out. Slide the boot on and press the bar pin back in with the vice. You might be able to use a c clamp.
TINSTAR is offline   Reply With Quote
Unread 04-14-2012, 06:43 PM   #6
drewtj05
x2
drewtj05 is offline   Reply With Quote
Unread 04-14-2012, 06:48 PM   #7
2003Sahara
I have also pushed mine thru with a c clamp and a socket but honestly I would just run without the boots. I agree they just gather dirt inside them hardly worth the work to get them on.
2013 JKUR Red Lobster
Michigan
www.OffroadJeepers.com
ORJ4x4.com
2003Sahara is offline   Reply With Quote
Unread 04-14-2012, 06:49 PM   #8
jeepguner
got them on from the other end what a pain
