Quantcast 3 inch lift 1 inch bl and 35's? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 3 inch lift 1 inch bl and 35's?
Old 10-11-2007, 11:48 AM   #1
rubicon35
I think i want to swap out my re 4.5 coils for 3 inch bds coils. i have a 1.25 bl and plan on running a 3/4 inch spacer up front with the bds coils. will this clear 35's? and have enough room to flex out. I am no mall crawler so i dont want to tear my fenders off but at the same time i would like to keep my center of gravity as low as possible. what is everyones thought on bds coils? ive talked with their tech suppost and they claim to be a very soft spring. any input is appreciated!
rubicon35 is offline   Reply With Quote
Old 10-11-2007, 12:09 PM   #2
RnEmOvr
Never Forget
RnEmOvr's Avatar
you will need to adjust your bump stops but other wise yes, i am about to run 36" iroks on 5" so your 35s and 4" will be fine
My Jeep 2.5-4.0 Motor Swap, Very detailed Military Jeepers
Guns have only two enemies; rust and politicians.
www.cityprofile.com
RnEmOvr is offline   Reply With Quote
Old 10-11-2007, 01:22 PM   #3
rubicon35
come on any other input??????
Old 10-11-2007, 01:27 PM   #4
Chris_
There is a shop around here that routinely builds Jeeps with 3" suspension, and 2" body lifts on 35s. Call and ask them about it.
http://www.diamondoffroad.com/jeep_pictures
Personally, I wouldn't do it.
'02 TJ X Apex Edition
'00 XJ Sport
Chris_ is offline   Reply With Quote
Old 10-11-2007, 01:36 PM   #5
M.DURITZ
all my 4x4 shops in my area do not stack lifts (body and sus). I wish they did around here.
2001 Yellow TJ Wrangler | 4" Superlift | 33 x 12.50 x 15 BFG's | Front and Rear WARN Bumpers | XeNoN Flat Fenders
M.DURITZ is offline   Reply With Quote
Old 10-11-2007, 02:33 PM   #6
TheBoogieman
Demonic Jeep Freak!
TheBoogieman's Avatar
It sure will clear.I've got 3" coils/1" BL/1" spacers up front to level it out.I still have over 6" of fender clearance with 35's.Go for it
TheBoogieman is offline   Reply With Quote
Old 10-11-2007, 02:55 PM   #7
rubicon35
looks good, i think i might go with the 3 inch coils
Old 10-11-2007, 03:35 PM   #8
planman
Thanks to all Mod erators
planman's Avatar
I have a 3" BDS lift with a JKS 1.25" BL, and I'm adding RE 0.75" spring spacers, for a total of 5". Then I'll add adjustable control arms to regain my wheelbase and JKS adjustable bumpstops with the plan of running 35" Pro Comp Xtreme MTs on 4" backspaced Cragar Soft 8s, and a JKS HD tie rod. I'll post in a couple weeks when I'm done. If the total 5" with bumpstopping is not enough, I'll try either wider flares, trimming the flares, or going with tube fenders.
planman is offline   Reply With Quote
Old 10-11-2007, 03:38 PM   #9
rubicon35
cool, were in the same boat, how are the bds coils? im seriously considering buying them
Old 10-11-2007, 05:38 PM   #10
planman
planman's Avatar
I really like them. I'm keeping my 3" BDS springs and adding 0.75" spring spacers instead of buying taller springs from another manufacturer.
Old 10-11-2007, 09:41 PM   #11
halltrail
BDS does make a 4.5" spring. With that said, I have the 3" BDS springs and re 3/4" spacers on all four corners. I love the springs the ride feels very good on and off the road. I do plan to switch to the 4.5 springs and new shocks soon though and sell the 3" springs and shocks.
halltrail is offline   Reply With Quote
Old 10-12-2007, 08:47 AM   #12
CCrew
Hope you're going to run radial IROK's s at that lift. 6" FTLA and 1" of BL I can rub the heck out of 36" IROK bias's, but if you look at the spec they're actually a 37" (36.8 to be precise)
-Roger
CCrew is offline   Reply With Quote
Old 10-12-2007, 10:43 AM   #13
ASUsax
Don't know about the 3" coils, but the 2" coils ROCK.
Blue Jeep Club Member #197
'02 TJ - 31" BFG AT's, some armor, yadda yadda. 2" BDS lift.
'94 ZJ - May it rest in pieces.
ASUsax is offline   Reply With Quote
Old 10-12-2007, 11:05 AM   #14
newbs
Jeepaholic
I ran my 35's with 4 inch springs and only at full flex would my tires rub the flares a little bit and ever hit any sheet metal. Honestly on my girlfriends she only has 3 inch bds coils and we ran a set of 35's for one trip and when she flexed she rubbed some not horrible but nothing a 1 inch body lift would not have fixed.
newbs is offline   Reply With Quote
Old 10-12-2007, 11:09 AM   #15
newbs
Jeepaholic
BDS 3 inch coils no body lift with 35's
Glock Forum
