3" BDS Lift Install - JeepForum.com
post #1 of 63 Old 08-17-2011, 09:10 PM Thread Starter
Dew88fan
3" BDS Lift Install
I'm working on putting my order together for a 3" lift for my TJ. I'm going with a BDS setup and plan to replace the front and rear lower control arms in the install my question is, what are everyone's thoughts on also replacing the front original track bar with a BDS adjustable? Not sure how necessary it would be?
Dew88fan is offline
post #2 of 63 Old 08-17-2011, 10:14 PM
smotrs
If your looking to save money and yours are in good condition, clean them up and paint to match. Use the money elsewhere.
Shaun
Sent from my PC36100 using JeepForum
Shaun
smotrs is offline
post #3 of 63 Old 08-18-2011, 08:02 AM
parrotparty
I'm planning on doing the same Lift, so keep updating this
bump
Originally Posted by 243 View Post
....I don't know that my way is the right way, it is just the way I did it.
Originally Posted by freedommachine View Post
If it makes you paranoid and requires forum discussions it belongs on a Jeep.
"Well boss, a diesel needs its oil like a sailor needs his rum."- Capt. Ron
parrotparty is offline
post #4 of 63 Old 08-18-2011, 08:12 AM
explorerlyon
When I did my 3" BDS lift, I replaced the trac bar with the BDS adjustable. It was part of the kit and necessary. I did not replace any of the control arms and was fine for over a year. The price of the BDS control arms was more than Rokman and Currie.
I have since replaced all 8 arms with Savvy/Currie. Not becuase I needed to for the lift, but I am working towards a tummy tuck.
05 Rubicon Unlimited, Automatic
explorerlyon is offline
post #5 of 63 Old 08-18-2011, 08:52 AM
parrotparty
Question
How's it holding up? Any pics or a thread on it? (Didn't mean to hijack)
post #6 of 63 Old 08-18-2011, 08:56 AM
explorerlyon
There is a parallel thread to this one where I posted some pictures.
http://www.jeepforum.com/forum/f9/lj...cerns-1254212/
post #7 of 63 Old 08-18-2011, 12:18 PM Thread Starter
Dew88fan
Explorerlyon, did you run into any issues not changing the lower control arms? BRA recommended them for this install. I hadn't checked out currie but will. Thanks!
Dew88fan is offline
post #8 of 63 Old 08-18-2011, 12:44 PM
explorerlyon
I had no issues. I never understood why BDS recommends replacing the front lowers only. I highly recommend the Savvy/Currie control arms. Better priced than BDS and I think a much better arm. Lots of discussions on these forums about the Currie arms.
post #9 of 63 Old 08-18-2011, 03:34 PM Thread Starter
Dew88fan
Thanks. Need to take another look at the CA's. By the way, meant "BDS" not "BRA"! My Droid thinks its a mind reader!
Dew88fan is offline
post #10 of 63 Old 08-18-2011, 03:42 PM
del_TJ
I did the exact same thing and was fine on and off-road for over a year. Eventually my stock front lowers were shot - bad bushings - and I upgraded my front arms. The new arms improved the ride.
del_TJ is offline
post #11 of 63 Old 08-18-2011, 03:49 PM Thread Starter
Dew88fan
Thoughts on the transfer drop kit at the same time as lift install? Also, I'm liking the Fox shocks that BDS has but anyone had any experience with them?
Dew88fan is offline
post #12 of 63 Old 08-18-2011, 03:55 PM
del_TJ
I ran the BDS drop kit with adjustable rear lower arms and stock uppers. No vibes. Did that for over a year and then went with a belly-up and still have stock rear uppers.
del_TJ is offline
post #13 of 63 Old 08-18-2011, 04:09 PM
explorerlyon
I have an LJ with the longer wheel base and drive shaft so did not need the transfer case drop.
Now that you are talking Fox shocks, you should also look at the Savvy 3" lift. I think that thread had a discussion about the Fox shocks they are using. That may be a better kit for you once you start talking about control arms, Fox shocks, etc. Start with post #303 http://www.jeepforum.com/forum/f9/sa...20/index8.html
Good luck!
post #14 of 63 Old 08-19-2011, 02:06 PM Thread Starter
Dew88fan
Explorerlyon, what was your ride quality of the BDS product?
Dew88fan is offline
post #15 of 63 Old 08-19-2011, 05:30 PM
explorerlyon
The ride was better than stock. More solid through corners and handles bumps on the road well. I have had no issues offroad with the suspension. When I added the Currie control arms, the ride got even better.
JKS 1.25" Body Lift and 1" BMML Install sgrim80 TJ Wrangler Technical Forum 20 05-15-2014 02:21 PM
undercover fab "no body lift" belly skid install and write up stoneytj TJ Wrangler Technical Forum 9 10-16-2010 08:21 PM
Rcx 3.25" Lift install junder28 TJ Wrangler Technical Forum 47 06-14-2010 07:47 PM
4" lift install, the front is 2" lower than rear yellowjp79 TJ Wrangler Technical Forum 6 05-21-2009 06:16 PM
1/2" or 3/4" coil spacers for a full traction lift after winch install? Rescue06 TJ Wrangler Technical Forum 10 08-07-2007 09:23 PM
