3:73 gears and 35s with a 3 speed Auto - JeepForum.com
post #1 of 7 Old 06-08-2010, 10:17 PM Thread Starter
sethkins88
Im trying to figure out if my gears have been redone. Im running about 3200 rpms at 70mph. My speedo is off my 5mph as well. Just wondering if you guys are running similar rpms with the same setup.
sethkins88 is offline
post #2 of 7 Old 06-08-2010, 11:06 PM
Imped
Imped's Avatar
Going by the math, you should be at ~2500 RPM with 3.73 gears and 35's. It sounds like you have 4.88 gears if you are indeed traveling in the 65-70 mph range.
OlllllllO
IndyORV
Imped is offline
post #3 of 7 Old 06-08-2010, 11:35 PM
LuckRider
LuckRider's Avatar
Indeed. It sounds like the PO regeared it for you. I wonder if you were lucky enough to get a c-clip eliminator kit with the Jeep too.
Support Our Troops!
JFI Member #7:
BESRK Rear Bumper, Hella 500s
LuckRider is offline
post #4 of 7 Old 06-09-2010, 07:45 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Speedo is off 5 MPH which way?
If you are 3,200 RPM at 65 MPH, your gear ratio is probably 4.56.
If you are 3,200 RPM at 75 MPH, your gear ratio is likely 4.10.
Your actual tire height and the innacuracy of your speedo are the (2) unknown factors that are making it impossible to say with certainty.
Wheelin98TJ is offline
post #5 of 7 Old 06-09-2010, 09:41 AM
INEEDZUSERNAME
I was @ ~3Krpm with 4.56gr @ 70mph
INEEDZUSERNAME is offline
post #6 of 7 Old 06-09-2010, 10:03 AM
ssdude
I run 3000 rpm @ 70 mph- 35" tires- 32rH auto- 4.10 gears- I changed my speedo gear a 34 tooth if I remember right. Checked my speed with GPS and with another vehicle.
ssdude is offline
post #7 of 7 Old 06-09-2010, 10:28 AM
cvd
cvd's Avatar
You could jack up the rear, manually twist the drive shaft one turn (put t-case in neutral), and count the wheel rotations.
cvd is offline
tires (32" tires with 2" lift and 3 speed auto w/ 3.07 gears) libertynewyork TJ Wrangler Technical Forum 15 10-20-2009 10:03 AM
Replacing 3 Speed Auto with 4 Speed Auto Chris @ GATR TJ Wrangler Technical Forum 8 10-03-2007 07:04 PM
Running 32's with 3.07 gears and 3 speed auto? zach1288 TJ Wrangler Technical Forum 12 10-08-2005 09:04 AM
What Gears w/ 35s and 6 Cyl. /4-Speed Auto Pog TJ Wrangler Technical Forum 3 06-28-2005 12:04 PM
Anyone kno nething about the 4 speed auto? What year start useing? bolt into 3 speed? jeepcj7 TJ Wrangler Technical Forum 6 06-23-2004 08:33 AM
