3.55 gears and a Rubicon front air locker in a '02 and older D44 rear axle
#1 | |
Under Construction
Yes I know this isn't a TJ, but I figured a few of you might be interested in this cheep alternative to an ARB air locker. It's an MJ D44 that I'm putting in my XJ.
I can't afford to regear right now because I have a Detroit locker up front and it's on the wrong side of the carrier break(I know, I bought it before I knew anything about gearing and carrier breaks), I don't want to loose my front locker so I'm just going to run stock gearing for now. Here is the axle(with TNT u-bolt eliminators) ![]() ![]() The hole ![]() Rubicon front air locker ![]() ![]()
#2 |
want it rite or rite now?
I had a good pump laying around untill tonight.....
the rubi is a good alternative if it's cheap, they are 800 bucks new, so try to keep em under 200 used unless you can pull em apart to inspect, the fronts can have cracked spiders and the rears can have chipped sun gears. I've burned myself a few times thinking I got a good locker, when It needed some parts we just can't get...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 Last edited by mudb8; 02-26-2010 at 12:10 AM.. |
#3 |
Under Construction
The first problem I ran into was with the gearing. Rubicons use thick cut gears, and 7/16" ring gear bolts, where as a standard D44 uses 3/8" ring gear bolts. Dana 44 Trac-loc on the left, Rubicon Tru-loc on the right
![]() ![]() The Rubicon case has a slightly larger bolt hole, leaving about 1/16" of play in the ring gear ![]() ![]() I called up Randy's Ring and Pinion and they hooked me up with these little sleeves to make it a better fit ![]() |
#4 | |
Under Construction
Sleeves installed
![]() Next is the bearing cap. Rubicons use caps specific for these lockers to allow for the air actuator, they are a little narrower, and have a notch for the air line So I modified my stock cap to work. Shaved aprox .010 off of the cap and notched out for the air line: ![]() ![]() Test fit ![]() And in the housing ![]() ![]()
#5 |
Under Construction
Damnit
wish I would have seen this sooner |
#6 |
LOL, that was an edit too! Mrblaine beat ya to it last night for Gerald
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
#7 |
JEEP FREAK
A new Rubi locker pump from the dealer is about $80 if you get a discounted price.
List price is around $120.
98 TJ |
#8 |
Under Construction
Sadly I'm a little tight on budget right now. So far I have got a little over $1100(not including the cost of the chromo shafts that are swapping from my current axle), into an axle that was given to me for free, and it still doesn't even have gears yet(it will have everything but though). I will probably end up buying new, but I figured I would look to see if I could pick up one a little cheeper.
#9 | |
and no gears yet either....thats why I dont count |
#10 |
Under Construction
Yeah some times I wish I didn't count. It's the little stuff that adds up really quick.
Free MJ Dana 44 as a B-day present - Junk yard $30 Sand blasted housing - C&R Sandblasting Free welding - school/buddy $150 1.5" UBEs - TNT Customs $145 EBC Green Stuff brake pads(for Ford Explorer), Centric rotors(for ZJ) - ThePartsBin.com $40 Ford Explorer backing plates and calipers - Junk yard $65 Rubber brake hoses - O'Reilly $12 Steal brake line - Autozone $40 Misc fluids(brake parts cleaner, diff fluid, paint) - Autozone $50 Ring gear bolt sleeves - Randy's Ring and Pinion $120 G2 master instal kit - 4 Wheel Parts $450 Rubi air locker $1102 total |
#11 |
quick question. I'm doing the same thing and I was wondering, did you take off .010 just on the one main cap or did you have to do both caps? Also are those spacers made of brass? I was going to machine my own out of 316 stainless and I was worried that it might be too soft.
#12 | |
#13 | |
Under Construction
The ring gear spacers aren't brass, I got them from Randy's Ring and Pinion. They are steel colored though, thats about all I can tell you. |
#14 |
Under Construction
Relatively speaking yes, they are cheep, about $3 each, but then you also have to buy 10 of them, that comes to about $30.
#15 |
There's at least 30 of em on the floor behind my bearing press, they don't seem to like to stay on the peg board very well....
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
